usrp.h
2 // Copyright 2015-2016 Ettus Research LLC
4 //
6 //
7
8 #ifndef INCLUDED_UHD_USRP_H
9 #define INCLUDED_UHD_USRP_H
10
11 #include <uhd/config.h>
12 #include <uhd/error.h>
13 #include <uhd/types/metadata.h>
14 #include <uhd/types/ranges.h>
15 #include <uhd/types/sensors.h>
17 #include <uhd/types/tune_request.h>
18 #include <uhd/types/tune_result.h>
19 #include <uhd/types/usrp_info.h>
20 #include <uhd/usrp/mboard_eeprom.h>
21 #include <uhd/usrp/dboard_eeprom.h>
22 #include <uhd/usrp/subdev_spec.h>
23 /* version.hpp is safe to include in C: */
24 #include <uhd/version.hpp> /* Provides UHD_VERSION */
25
26 #include <stdbool.h>
27 #include <stdlib.h>
28 #include <stdint.h>
29 #include <time.h>
30
32 typedef struct {
33  size_t bitwidth;
34  bool readable;
35  bool writable;
37
38 /*
39  * Streamers
40  */
41
43
46 typedef struct {
48  char* cpu_format;
50  char* otw_format;
52  char* args;
54  size_t* channel_list;
58
60
63 typedef enum {
73
75
78 typedef struct {
82  size_t num_samps;
84  bool stream_now;
90
91 struct uhd_rx_streamer;
92 struct uhd_tx_streamer;
93
95
98 typedef struct uhd_rx_streamer* uhd_rx_streamer_handle;
99
101
104 typedef struct uhd_tx_streamer* uhd_tx_streamer_handle;
105
106 #ifdef __cplusplus
107 extern "C" {
108 #endif
109
110 /*
111  * RX Streamer
112  */
113
115
121 );
122
124
130 );
131
135  size_t *num_channels_out
136 );
137
141  size_t *max_num_samps_out
142 );
143
145
158  void** buffs,
159  size_t samps_per_buff,
161  double timeout,
162  bool one_packet,
163  size_t *items_recvd
164 );
165
167
172  const uhd_stream_cmd_t *stream_cmd
173 );
174
176
186  char* error_out,
187  size_t strbuffer_len
188 );
189
190 /*
191  * TX Streamer
192  */
193
195
201 );
202
204
210 );
211
215  size_t *num_channels_out
216 );
217
221  size_t *max_num_samps_out
222 );
223
225
237  const void **buffs,
238  size_t samps_per_buff,
240  double timeout,
241  size_t *items_sent
242 );
243
245
251  double timeout,
252  bool *valid
253 );
254
256
266  char* error_out,
267  size_t strbuffer_len
268 );
269
270 #ifdef __cplusplus
271 }
272 #endif
273
274 /****************************************************************************
275  * Public Datatypes for USRP / streamer handling.
276  ***************************************************************************/
277 struct uhd_usrp;
278
280 /*
281  * See uhd::usrp::multi_usrp for more details.
282  *
283  * NOTE: You must pass this handle into uhd_usrp_make before using it.
284  */
285 typedef struct uhd_usrp* uhd_usrp_handle;
286
287 /****************************************************************************
288  * USRP Make / Free API calls
289  ***************************************************************************/
290 #ifdef __cplusplus
291 extern "C" {
292 #endif
293
295
299  const char* args,
300  uhd_string_vector_handle *strings_out
301 );
302
304
309  uhd_usrp_handle *h,
310  const char *args
311 );
312
314
319  uhd_usrp_handle *h
320 );
321
324  uhd_usrp_handle h,
325  char* error_out,
326  size_t strbuffer_len
327 );
328
331  uhd_usrp_handle h,
332  uhd_stream_args_t *stream_args,
334 );
335
338  uhd_usrp_handle h,
339  uhd_stream_args_t *stream_args,
341 );
342
343 /****************************************************************************
344  * multi_usrp API calls
345  ***************************************************************************/
346
348
352  uhd_usrp_handle h,
353  size_t chan,
354  uhd_usrp_rx_info_t *info_out
355 );
356
358
362  uhd_usrp_handle h,
363  size_t chan,
364  uhd_usrp_tx_info_t *info_out
365 );
366
367 /****************************************************************************
368  * Motherboard methods
369  ***************************************************************************/
370
372
376  uhd_usrp_handle h,
377  double rate,
378  size_t mboard
379 );
380
382
386  uhd_usrp_handle h,
387  size_t mboard,
388  double *clock_rate_out
389 );
390
392
396  uhd_usrp_handle h,
397  char* pp_string_out,
398  size_t strbuffer_len
399 );
400
402
406  uhd_usrp_handle h,
407  size_t mboard,
408  char* mboard_name_out,
409  size_t strbuffer_len
410 );
411
413
417  uhd_usrp_handle h,
418  size_t mboard,
419  int64_t *full_secs_out,
420  double *frac_secs_out
421 );
422
424
428  uhd_usrp_handle h,
429  size_t mboard,
430  int64_t *full_secs_out,
431  double *frac_secs_out
432 );
433
435
439  uhd_usrp_handle h,
440  int64_t full_secs,
441  double frac_secs,
442  size_t mboard
443 );
444
446
450  uhd_usrp_handle h,
451  int64_t full_secs,
452  double frac_secs,
453  size_t mboard
454 );
455
457
461  uhd_usrp_handle h,
462  int64_t full_secs,
463  double frac_secs
464 );
465
468  uhd_usrp_handle h,
469  bool *result_out
470 );
471
473
477  uhd_usrp_handle h,
478  int64_t full_secs,
479  double frac_secs,
480  size_t mboard
481 );
482
485  uhd_usrp_handle h,
486  size_t mboard
487 );
488
490
494  uhd_usrp_handle h,
495  const char* time_source,
496  size_t mboard
497 );
498
500
504  uhd_usrp_handle h,
505  size_t mboard,
506  char* time_source_out,
507  size_t strbuffer_len
508 );
509
512  uhd_usrp_handle h,
513  size_t mboard,
514  uhd_string_vector_handle *time_sources_out
515 );
516
518
522  uhd_usrp_handle h,
523  const char* clock_source,
524  size_t mboard
525 );
526
528
532  uhd_usrp_handle h,
533  size_t mboard,
534  char* clock_source_out,
535  size_t strbuffer_len
536 );
537
540  uhd_usrp_handle h,
541  size_t mboard,
542  uhd_string_vector_handle *clock_sources_out
543 );
544
546
550  uhd_usrp_handle h,
551  bool enb,
552  size_t mboard
553 );
554
556
560  uhd_usrp_handle h,
561  bool enb,
562  size_t mboard
563 );
564
567  uhd_usrp_handle h,
568  size_t *num_mboards_out
569 );
570
573  uhd_usrp_handle h,
574  const char* name,
575  size_t mboard,
576  uhd_sensor_value_handle *sensor_value_out
577 );
578
581  uhd_usrp_handle h,
582  size_t mboard,
583  uhd_string_vector_handle *mboard_sensor_names_out
584 );
585
587
591  uhd_usrp_handle h,
592  uint8_t addr,
593  uint32_t data,
594  size_t mboard
595 );
596
597 /****************************************************************************
598  * EEPROM access methods
599  ***************************************************************************/
600
603  uhd_usrp_handle h,
604  uhd_mboard_eeprom_handle mb_eeprom,
605  size_t mboard
606 );
607
610  uhd_usrp_handle h,
611  uhd_mboard_eeprom_handle mb_eeprom,
612  size_t mboard
613 );
614
617  uhd_usrp_handle h,
618  uhd_dboard_eeprom_handle db_eeprom,
619  const char* unit,
620  const char* slot,
621  size_t mboard
622 );
623
626  uhd_usrp_handle h,
627  uhd_dboard_eeprom_handle db_eeprom,
628  const char* unit,
629  const char* slot,
630  size_t mboard
631 );
632
633 /****************************************************************************
634  * RX methods
635  ***************************************************************************/
636
638
642  uhd_usrp_handle h,
643  uhd_subdev_spec_handle subdev_spec,
644  size_t mboard
645 );
646
649  uhd_usrp_handle h,
650  size_t mboard,
651  uhd_subdev_spec_handle subdev_spec_out
652 );
653
656  uhd_usrp_handle h,
657  size_t *num_channels_out
658 );
659
662  uhd_usrp_handle h,
663  size_t chan,
664  char* rx_subdev_name_out,
665  size_t strbuffer_len
666 );
667
670  uhd_usrp_handle h,
671  double rate,
672  size_t chan
673 );
674
677  uhd_usrp_handle h,
678  size_t chan,
679  double *rate_out
680 );
681
684  uhd_usrp_handle h,
685  size_t chan,
686  uhd_meta_range_handle rates_out
687 );
688
691  uhd_usrp_handle h,
692  uhd_tune_request_t *tune_request,
693  size_t chan,
694  uhd_tune_result_t *tune_result
695 );
696
699  uhd_usrp_handle h,
700  size_t chan,
701  double *freq_out
702 );
703
705
709  uhd_usrp_handle h,
710  size_t chan,
711  uhd_meta_range_handle freq_range_out
712 );
713
716  uhd_usrp_handle h,
717  size_t chan,
718  uhd_meta_range_handle freq_range_out
719 );
720
722 UHD_UNUSED(static const char* UHD_USRP_ALL_LOS) = "all";
723
725 /*
726  * See uhd::usrp::multi_usrp::get_rx_lo_names() for more details.
727  */
729  uhd_usrp_handle h,
730  size_t chan,
731  uhd_string_vector_handle *rx_lo_names_out
732 );
733
735 /*
736  * See uhd::usrp::multi_usrp::set_rx_lo_source() for more details.
737  */
739  uhd_usrp_handle h,
740  const char* src,
741  const char* name,
742  size_t chan
743 );
744
747  uhd_usrp_handle h,
748  const char* name,
749  size_t chan,
750  char* rx_lo_source_out,
751  size_t strbuffer_len
752 );
753
756  uhd_usrp_handle h,
757  const char* name,
758  size_t chan,
759  uhd_string_vector_handle *rx_lo_sources_out
760 );
761
763 /*
764  * See uhd::usrp::multi_usrp::set_rx_lo_enabled() for more details.
765  */
767  uhd_usrp_handle h,
768  bool enabled,
769  const char* name,
770  size_t chan
771 );
772
775  uhd_usrp_handle h,
776  const char* name,
777  size_t chan,
778  bool* result_out
779 );
780
783  uhd_usrp_handle h,
784  double freq,
785  const char* name,
786  size_t chan,
787  double* coerced_freq_out
788 );
789
792  uhd_usrp_handle h,
793  const char* name,
794  size_t chan,
795  double* rx_lo_freq_out
796 );
797
800  uhd_usrp_handle h,
801  double gain,
802  size_t chan,
803  const char *gain_name
804 );
805
807
811  uhd_usrp_handle h,
812  double gain,
813  size_t chan
814 );
815
817
821  uhd_usrp_handle h,
822  bool enable,
823  size_t chan
824 );
825
828  uhd_usrp_handle h,
829  size_t chan,
830  const char *gain_name,
831  double *gain_out
832 );
833
835
839  uhd_usrp_handle h,
840  size_t chan,
841  double *gain_out
842 );
843
846  uhd_usrp_handle h,
847  const char* name,
848  size_t chan,
849  uhd_meta_range_handle gain_range_out
850 );
851
854  uhd_usrp_handle h,
855  size_t chan,
856  uhd_string_vector_handle *gain_names_out
857 );
858
861  uhd_usrp_handle h,
862  const char* ant,
863  size_t chan
864 );
865
868  uhd_usrp_handle h,
869  size_t chan,
870  char* ant_out,
871  size_t strbuffer_len
872 );
873
876  uhd_usrp_handle h,
877  size_t chan,
878  uhd_string_vector_handle *antennas_out
879 );
880
883  uhd_usrp_handle h,
884  size_t chan,
885  uhd_string_vector_handle *sensor_names_out
886 );
887
890  uhd_usrp_handle h,
891  double bandwidth,
892  size_t chan
893 );
894
897  uhd_usrp_handle h,
898  size_t chan,
899  double *bandwidth_out
900 );
901
904  uhd_usrp_handle h,
905  size_t chan,
906  uhd_meta_range_handle bandwidth_range_out
907 );
908
911  uhd_usrp_handle h,
912  const char* name,
913  size_t chan,
914  uhd_sensor_value_handle *sensor_value_out
915 );
916
918
922  uhd_usrp_handle h,
923  bool enb,
924  size_t chan
925 );
926
929  uhd_usrp_handle h,
930  bool enb,
931  size_t chan
932 );
933
934 /****************************************************************************
935  * TX methods
936  ***************************************************************************/
937
939
943  uhd_usrp_handle h,
944  uhd_subdev_spec_handle subdev_spec,
945  size_t mboard
946 );
947
950  uhd_usrp_handle h,
951  size_t mboard,
952  uhd_subdev_spec_handle subdev_spec_out
953 );
954
957  uhd_usrp_handle h,
958  size_t *num_channels_out
959 );
960
963  uhd_usrp_handle h,
964  size_t chan,
965  char* tx_subdev_name_out,
966  size_t strbuffer_len
967 );
968
971  uhd_usrp_handle h,
972  double rate,
973  size_t chan
974 );
975
978  uhd_usrp_handle h,
979  size_t chan,
980  double *rate_out
981 );
982
985  uhd_usrp_handle h,
986  size_t chan,
987  uhd_meta_range_handle rates_out
988 );
989
992  uhd_usrp_handle h,
993  uhd_tune_request_t *tune_request,
994  size_t chan,
995  uhd_tune_result_t *tune_result
996 );
997
1000  uhd_usrp_handle h,
1001  size_t chan,
1002  double *freq_out
1003 );
1004
1006
1010  uhd_usrp_handle h,
1011  size_t chan,
1012  uhd_meta_range_handle freq_range_out
1013 );
1014
1017  uhd_usrp_handle h,
1018  size_t chan,
1019  uhd_meta_range_handle freq_range_out
1020 );
1021
1023 /*
1024  * See uhd::usrp::multi_usrp::get_tx_lo_names() for more details.
1025  */
1027  uhd_usrp_handle h,
1028  size_t chan,
1029  uhd_string_vector_handle *tx_lo_names_out
1030 );
1031
1033 /*
1034  * See uhd::usrp::multi_usrp::set_tx_lo_source() for more details.
1035  */
1037  uhd_usrp_handle h,
1038  const char* src,
1039  const char* name,
1040  size_t chan
1041 );
1042
1045  uhd_usrp_handle h,
1046  const char* name,
1047  size_t chan,
1048  char* tx_lo_source_out,
1049  size_t strbuffer_len
1050 );
1051
1054  uhd_usrp_handle h,
1055  const char* name,
1056  size_t chan,
1057  uhd_string_vector_handle *tx_lo_sources_out
1058 );
1059
1061 /*
1062  * See uhd::usrp::multi_usrp::set_tx_lo_enabled() for more details.
1063  */
1065  uhd_usrp_handle h,
1066  bool enabled,
1067  const char* name,
1068  size_t chan
1069 );
1070
1073  uhd_usrp_handle h,
1074  const char* name,
1075  size_t chan,
1076  bool* result_out
1077 );
1078
1081  uhd_usrp_handle h,
1082  double freq,
1083  const char* name,
1084  size_t chan,
1085  double* coerced_freq_out
1086 );
1087
1090  uhd_usrp_handle h,
1091  const char* name,
1092  size_t chan,
1093  double* tx_lo_freq_out
1094 );
1095
1098  uhd_usrp_handle h,
1099  double gain,
1100  size_t chan,
1101  const char *gain_name
1102 );
1103
1105
1109  uhd_usrp_handle h,
1110  double gain,
1111  size_t chan
1112 );
1113
1116  uhd_usrp_handle h,
1117  const char* name,
1118  size_t chan,
1119  uhd_meta_range_handle gain_range_out
1120 );
1121
1124  uhd_usrp_handle h,
1125  size_t chan,
1126  const char *gain_name,
1127  double *gain_out
1128 );
1129
1131
1135  uhd_usrp_handle h,
1136  size_t chan,
1137  double *gain_out
1138 );
1139
1142  uhd_usrp_handle h,
1143  size_t chan,
1144  uhd_string_vector_handle *gain_names_out
1145 );
1146
1149  uhd_usrp_handle h,
1150  const char* ant,
1151  size_t chan
1152 );
1153
1156  uhd_usrp_handle h,
1157  size_t chan,
1158  char* ant_out,
1159  size_t strbuffer_len
1160 );
1161
1164  uhd_usrp_handle h,
1165  size_t chan,
1166  uhd_string_vector_handle *antennas_out
1167 );
1168
1171  uhd_usrp_handle h,
1172  double bandwidth,
1173  size_t chan
1174 );
1175
1178  uhd_usrp_handle h,
1179  size_t chan,
1180  double *bandwidth_out
1181 );
1182
1185  uhd_usrp_handle h,
1186  size_t chan,
1187  uhd_meta_range_handle bandwidth_range_out
1188 );
1189
1192  uhd_usrp_handle h,
1193  const char* name,
1194  size_t chan,
1195  uhd_sensor_value_handle *sensor_value_out
1196 );
1197
1200  uhd_usrp_handle h,
1201  size_t chan,
1202  uhd_string_vector_handle *sensor_names_out
1203 );
1204
1205 /****************************************************************************
1206  * GPIO methods
1207  ***************************************************************************/
1208
1211  uhd_usrp_handle h,
1212  size_t mboard,
1213  uhd_string_vector_handle *gpio_banks_out
1214 );
1215
1217
1221  uhd_usrp_handle h,
1222  const char* bank,
1223  const char* attr,
1224  uint32_t value,
1225  uint32_t mask,
1226  size_t mboard
1227 );
1228
1230
1234  uhd_usrp_handle h,
1235  const char* bank,
1236  const char* attr,
1237  size_t mboard,
1238  uint32_t *attr_out
1239 );
1240
1243  uhd_usrp_handle h,
1244  size_t mboard,
1245  uhd_string_vector_handle *registers_out
1246 );
1247
1250  uhd_usrp_handle h,
1251  const char* path,
1252  size_t mboard,
1253  uhd_usrp_register_info_t *register_info_out
1254 );
1255
1258  uhd_usrp_handle h,
1259  const char* path,
1260  uint32_t field,
1261  uint64_t value,
1262  size_t mboard
1263 );
1264
1267  uhd_usrp_handle h,
1268  const char* path,
1269  uint32_t field,
1270  size_t mboard,
1271  uint64_t *value_out
1272 );
1273
1274 #ifdef __cplusplus
1275 }
1276 #endif
1277
1278 #endif /* INCLUDED_UHD_USRP_H */
Stream samples indefinitely.
Definition: usrp.h:65
UHD_API uhd_error uhd_usrp_set_tx_freq(uhd_usrp_handle h, uhd_tune_request_t *tune_request, size_t chan, uhd_tune_result_t *tune_result)
Set the given channel&#39;s center TX frequency.
UHD_API uhd_error uhd_usrp_set_clock_source(uhd_usrp_handle h, const char *clock_source, size_t mboard)
Set the given device&#39;s clock source.
UHD_API uhd_error uhd_usrp_set_tx_antenna(uhd_usrp_handle h, const char *ant, size_t chan)
Set the TX antenna for the given channel.
UHD_API uhd_error uhd_usrp_set_time_next_pps(uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard)
Set the USRP device&#39;s time to the given value upon the next PPS detection.
UHD_API uhd_error uhd_usrp_get_time_source(uhd_usrp_handle h, size_t mboard, char *time_source_out, size_t strbuffer_len)
Get the time source for the given device.
bool stream_now
Stream now?
Definition: usrp.h:84
UHD_API uhd_error uhd_usrp_set_rx_agc(uhd_usrp_handle h, bool enable, size_t chan)
Enable or disable the given channel&#39;s RX AGC module.
struct uhd_rx_metadata_t * uhd_rx_metadata_handle
RX metadata interface for describing sent IF data.
Definition: metadata.h:52
UHD_API uhd_error uhd_usrp_get_tx_lo_freq(uhd_usrp_handle h, const char *name, size_t chan, double *tx_lo_freq_out)
Get the current Tx LO frequency.
UHD_API uhd_error uhd_usrp_enumerate_registers(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *registers_out)
Enumerate the full paths of USRP registers available for read/write.
UHD_API uhd_error uhd_usrp_set_gpio_attr(uhd_usrp_handle h, const char *bank, const char *attr, uint32_t value, uint32_t mask, size_t mboard)
Set a GPIO attribute for a given GPIO bank.
UHD_API uhd_error uhd_usrp_set_rx_lo_freq(uhd_usrp_handle h, double freq, const char *name, size_t chan, double *coerced_freq_out)
Set the RX LO frequency.
UHD_API uhd_error uhd_usrp_set_tx_rate(uhd_usrp_handle h, double rate, size_t chan)
Set the given RX channel&#39;s sample rate (in Sps)
UHD_API uhd_error uhd_usrp_get_rx_antenna(uhd_usrp_handle h, size_t chan, char *ant_out, size_t strbuffer_len)
Get the RX antenna for the given channel.
UHD_API uhd_error uhd_usrp_get_rx_antennas(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *antennas_out)
Get a list of RX antennas associated with the given channels.
A struct of parameters to construct a stream.
Definition: usrp.h:46
UHD_API uhd_error uhd_usrp_get_tx_sensor_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *sensor_names_out)
Get a list of TX sensors associated with the given channels.
UHD_API uhd_error uhd_usrp_get_rx_stream(uhd_usrp_handle h, uhd_stream_args_t *stream_args, uhd_rx_streamer_handle h_out)
Create RX streamer from a USRP handle and given stream args.
bool readable
Definition: usrp.h:34
UHD_API uhd_error uhd_usrp_get_tx_gain_range(uhd_usrp_handle h, const char *name, size_t chan, uhd_meta_range_handle gain_range_out)
Get all possible gain ranges for the given channel and name.
UHD_API uhd_error uhd_usrp_get_rx_lo_export_enabled(uhd_usrp_handle h, const char *name, size_t chan, bool *result_out)
Returns true if the currently selected LO is being exported.
uhd_stream_mode_t stream_mode
How streaming is issued to the device.
Definition: usrp.h:80
UHD_API uhd_error uhd_usrp_set_time_source(uhd_usrp_handle h, const char *time_source, size_t mboard)
Set the time source for the given device.
Definition: ranges.h:45
UHD_API uhd_error uhd_usrp_get_tx_antenna(uhd_usrp_handle h, size_t chan, char *ant_out, size_t strbuffer_len)
Get the TX antenna for the given channel.
UHD_API uhd_error uhd_usrp_get_gpio_attr(uhd_usrp_handle h, const char *bank, const char *attr, size_t mboard, uint32_t *attr_out)
Get a GPIO attribute on a particular GPIO bank.
UHD_API uhd_error uhd_usrp_set_command_time(uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard)
Set the time at which timed commands will take place.
UHD_API uhd_error uhd_usrp_get_tx_subdev_name(uhd_usrp_handle h, size_t chan, char *tx_subdev_name_out, size_t strbuffer_len)
Get the name for the RX frontend.
UHD_API uhd_error uhd_usrp_set_mboard_eeprom(uhd_usrp_handle h, uhd_mboard_eeprom_handle mb_eeprom, size_t mboard)
Set values in the given motherboard&#39;s EEPROM.
UHD_API uhd_error uhd_usrp_set_user_register(uhd_usrp_handle h, uint8_t addr, uint32_t data, size_t mboard)
Perform a write on a user configuration register bus.
UHD_API uhd_error uhd_usrp_get_tx_lo_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *tx_lo_names_out)
Get a list of possible LO stage names.
double time_spec_frac_secs
If not now, then fractional seconds into future to stream.
Definition: usrp.h:88
bool writable
Definition: usrp.h:35
struct uhd_tx_metadata_t * uhd_tx_metadata_handle
TX metadata interface for describing received IF data.
Definition: metadata.h:61
struct uhd_usrp * uhd_usrp_handle
C-level interface for working with a USRP device.
Definition: usrp.h:285
UHD_API uhd_error uhd_usrp_set_normalized_rx_gain(uhd_usrp_handle h, double gain, size_t chan)
Set the normalized RX gain [0.0, 1.0] for the given channel.
UHD_API uhd_error uhd_tx_streamer_last_error(uhd_tx_streamer_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the TX streamer.
UHD_API uhd_error uhd_usrp_get_num_mboards(uhd_usrp_handle h, size_t *num_mboards_out)
Get the number of devices associated with the given USRP handle.
UHD_API uhd_error uhd_usrp_set_time_now(uhd_usrp_handle h, int64_t full_secs, double frac_secs, size_t mboard)
Set the USRP device&#39;s time.
UHD_API uhd_error uhd_usrp_get_mboard_sensor(uhd_usrp_handle h, const char *name, size_t mboard, uhd_sensor_value_handle *sensor_value_out)
Get the value associated with the given sensor name.
UHD_API uhd_error uhd_usrp_get_time_synchronized(uhd_usrp_handle h, bool *result_out)
Are all motherboard times synchronized?
UHD_API uhd_error uhd_usrp_get_tx_antennas(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *antennas_out)
Get a list of tx antennas associated with the given channels.
UHD_API uhd_error uhd_tx_streamer_num_channels(uhd_tx_streamer_handle h, size_t *num_channels_out)
Get the number of channels associated with this streamer.
UHD_API uhd_error uhd_rx_streamer_make(uhd_rx_streamer_handle *h)
Create an RX streamer handle.
struct uhd_mboard_eeprom_t * uhd_mboard_eeprom_handle
A C-level interface for interacting with a USRP motherboard&#39;s EEPROM.
Definition: mboard_eeprom.h:35
UHD_API uhd_error uhd_usrp_make(uhd_usrp_handle *h, const char *args)
Create a USRP handle.
Stores RF and DSP tuned frequencies.
Definition: tune_result.h:19
UHD_UNUSED(static const char *UHD_USRP_ALL_LOS)
A wildcard for all LO names.
End continuous streaming.
Definition: usrp.h:67
UHD_API uhd_error uhd_usrp_set_rx_lo_source(uhd_usrp_handle h, const char *src, const char *name, size_t chan)
Set the LO source for the USRP device.
size_t bitwidth
Definition: usrp.h:33
char * cpu_format
Format of host memory.
Definition: usrp.h:48
UHD_API uhd_error uhd_usrp_set_normalized_tx_gain(uhd_usrp_handle h, double gain, size_t chan)
Set the normalized TX gain [0.0, 1.0] for the given channel.
Register info.
Definition: usrp.h:32
char * args
Other stream args.
Definition: usrp.h:52
UHD_API uhd_error uhd_usrp_get_rx_sensor(uhd_usrp_handle h, const char *name, size_t chan, uhd_sensor_value_handle *sensor_value_out)
Get the value for the given RX sensor.
UHD_API uhd_error uhd_usrp_get_rx_lo_sources(uhd_usrp_handle h, const char *name, size_t chan, uhd_string_vector_handle *rx_lo_sources_out)
Get a list of possible LO sources.
UHD_API uhd_error uhd_rx_streamer_recv(uhd_rx_streamer_handle h, void **buffs, size_t samps_per_buff, uhd_rx_metadata_handle *md, double timeout, bool one_packet, size_t *items_recvd)
Receive buffers containing samples into the given RX streamer.
UHD_API uhd_error uhd_usrp_get_tx_bandwidth(uhd_usrp_handle h, size_t chan, double *bandwidth_out)
Get the bandwidth for the given channel&#39;s TX frontend.
UHD_API uhd_error uhd_usrp_get_rx_bandwidth(uhd_usrp_handle h, size_t chan, double *bandwidth_out)
Get the bandwidth for the given channel&#39;s RX frontend.
UHD_API uhd_error uhd_usrp_set_tx_lo_source(uhd_usrp_handle h, const char *src, const char *name, size_t chan)
UHD_API uhd_error uhd_usrp_get_tx_num_channels(uhd_usrp_handle h, size_t *num_channels_out)
Get the number of TX channels for the given handle.
UHD_API uhd_error uhd_usrp_get_register_info(uhd_usrp_handle h, const char *path, size_t mboard, uhd_usrp_register_info_t *register_info_out)
Get more information about a low-level device register.
UHD_API uhd_error uhd_usrp_get_tx_bandwidth_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle bandwidth_range_out)
Get all possible bandwidth ranges for the given channel&#39;s TX frontend.
UHD_API uhd_error uhd_usrp_set_rx_dc_offset_enabled(uhd_usrp_handle h, bool enb, size_t chan)
Enable or disable RX DC offset correction for the given channel.
UHD_API uhd_error uhd_usrp_get_tx_sensor(uhd_usrp_handle h, const char *name, size_t chan, uhd_sensor_value_handle *sensor_value_out)
Get the value for the given TX sensor.
UHD_API uhd_error uhd_usrp_get_rx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
Get all possible center frequency ranges for the given channel.
Stream some number of samples and finish.
Definition: usrp.h:69
UHD_API uhd_error uhd_usrp_get_tx_gain(uhd_usrp_handle h, size_t chan, const char *gain_name, double *gain_out)
Get the given channel&#39;s RX gain.
UHD_API uhd_error uhd_usrp_get_fe_rx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
Get all possible RF frequency ranges for the given channel&#39;s RX RF frontend.
UHD_API uhd_error uhd_usrp_get_gpio_banks(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *gpio_banks_out)
Get a list of GPIO banks associated with the given channels.
UHD_API uhd_error uhd_usrp_set_tx_gain(uhd_usrp_handle h, double gain, size_t chan, const char *gain_name)
Set the TX gain for the given channel and name.
UHD_API uhd_error uhd_usrp_get_pp_string(uhd_usrp_handle h, char *pp_string_out, size_t strbuffer_len)
Get a pretty-print representation of the USRP device.
UHD_API uhd_error uhd_usrp_set_rx_lo_export_enabled(uhd_usrp_handle h, bool enabled, const char *name, size_t chan)
Set whether the LO used by the USRP device is exported.
UHD_API uhd_error uhd_usrp_get_tx_stream(uhd_usrp_handle h, uhd_stream_args_t *stream_args, uhd_tx_streamer_handle h_out)
Create TX streamer from a USRP handle and given stream args.
UHD_API uhd_error uhd_tx_streamer_make(uhd_tx_streamer_handle *h)
Create an TX streamer handle.
UHD_API uhd_error uhd_usrp_get_rx_sensor_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *sensor_names_out)
Get a list of RX sensors associated with the given channels.
UHD_API uhd_error uhd_usrp_get_rx_freq(uhd_usrp_handle h, size_t chan, double *freq_out)
Get the given channel&#39;s center RX frequency.
UHD_API uhd_error uhd_rx_streamer_max_num_samps(uhd_rx_streamer_handle h, size_t *max_num_samps_out)
Get the max number of samples per buffer per packet.
struct uhd_async_metadata_t * uhd_async_metadata_handle
Interface for describing transmit-related events.
Definition: metadata.h:70
UHD_API uhd_error uhd_usrp_get_tx_freq(uhd_usrp_handle h, size_t chan, double *freq_out)
Get the given channel&#39;s center TX frequency.
UHD_API uhd_error uhd_usrp_get_rx_num_channels(uhd_usrp_handle h, size_t *num_channels_out)
Get the number of RX channels for the given handle.
uhd_error
UHD error codes.
Definition: error.h:21
UHD_API uhd_error uhd_usrp_clear_command_time(uhd_usrp_handle h, size_t mboard)
Clear the command time so that commands are sent ASAP.
UHD_API uhd_error uhd_usrp_get_rx_gain_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *gain_names_out)
Get a list of RX gain names for the given channel.
USRP RX info.
Definition: usrp_info.h:18
struct uhd_dboard_eeprom_t * uhd_dboard_eeprom_handle
A C-level interface for interacting with a daughterboard EEPROM.
Definition: dboard_eeprom.h:35
UHD_API uhd_error uhd_usrp_get_time_last_pps(uhd_usrp_handle h, size_t mboard, int64_t *full_secs_out, double *frac_secs_out)
Get the time when this device&#39;s last PPS pulse occurred.
Define how device streams to host.
Definition: usrp.h:78
UHD_API uhd_error uhd_usrp_get_dboard_eeprom(uhd_usrp_handle h, uhd_dboard_eeprom_handle db_eeprom, const char *unit, const char *slot, size_t mboard)
Get a handle for the given device&#39;s daughterboard EEPROM.
UHD_API uhd_error uhd_usrp_get_tx_lo_sources(uhd_usrp_handle h, const char *name, size_t chan, uhd_string_vector_handle *tx_lo_sources_out)
UHD_API uhd_error uhd_usrp_get_time_sources(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *time_sources_out)
Get a list of time sources for the given device.
UHD_API uhd_error uhd_usrp_set_tx_subdev_spec(uhd_usrp_handle h, uhd_subdev_spec_handle subdev_spec, size_t mboard)
Map the given device&#39;s TX frontend to a channel.
UHD_API uhd_error uhd_usrp_get_rx_info(uhd_usrp_handle h, size_t chan, uhd_usrp_rx_info_t *info_out)
Get RX info from the USRP device.
UHD_API uhd_error uhd_usrp_get_tx_subdev_spec(uhd_usrp_handle h, size_t mboard, uhd_subdev_spec_handle subdev_spec_out)
Get the TX frontend specification for the given device.
UHD_API uhd_error uhd_usrp_get_tx_rate(uhd_usrp_handle h, size_t chan, double *rate_out)
Get the given RX channel&#39;s sample rate (in Sps)
UHD_API uhd_error uhd_usrp_set_tx_bandwidth(uhd_usrp_handle h, double bandwidth, size_t chan)
Set the bandwidth for the given channel&#39;s TX frontend.
UHD_API uhd_error uhd_usrp_set_rx_iq_balance_enabled(uhd_usrp_handle h, bool enb, size_t chan)
Enable or disable RX IQ imbalance correction for the given channel.
UHD_API uhd_error uhd_tx_streamer_free(uhd_tx_streamer_handle *h)
Free an TX streamer handle.
UHD_API uhd_error uhd_rx_streamer_issue_stream_cmd(uhd_rx_streamer_handle h, const uhd_stream_cmd_t *stream_cmd)
Issue the given stream command.
UHD_API uhd_error uhd_usrp_set_rx_gain(uhd_usrp_handle h, double gain, size_t chan, const char *gain_name)
Set the RX gain for the given channel and name.
UHD_API uhd_error uhd_usrp_free(uhd_usrp_handle *h)
Safely destroy the USRP object underlying the handle.
UHD_API uhd_error uhd_usrp_get_fe_tx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
Get all possible RF frequency ranges for the given channel&#39;s TX RF frontend.
UHD_API uhd_error uhd_usrp_read_register(uhd_usrp_handle h, const char *path, uint32_t field, size_t mboard, uint64_t *value_out)
Read a low-level register field from a device register in the USRP hardware.
UHD_API uhd_error uhd_usrp_set_master_clock_rate(uhd_usrp_handle h, double rate, size_t mboard)
Set the master clock rate.
UHD_API uhd_error uhd_usrp_set_tx_lo_export_enabled(uhd_usrp_handle h, bool enabled, const char *name, size_t chan)
UHD_API uhd_error uhd_usrp_get_rx_subdev_name(uhd_usrp_handle h, size_t chan, char *rx_subdev_name_out, size_t strbuffer_len)
UHD_API uhd_error uhd_usrp_get_tx_info(uhd_usrp_handle h, size_t chan, uhd_usrp_tx_info_t *info_out)
Get TX info from the USRP device.
uhd_stream_mode_t
Definition: usrp.h:63
UHD_API uhd_error uhd_usrp_get_rx_lo_freq(uhd_usrp_handle h, const char *name, size_t chan, double *rx_lo_freq_out)
Get the current RX LO frequency.
UHD_API uhd_error uhd_rx_streamer_last_error(uhd_rx_streamer_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the RX streamer.
int64_t time_spec_full_secs
If not now, then full seconds into future to stream.
Definition: usrp.h:86
struct uhd_rx_streamer * uhd_rx_streamer_handle
C-level interface for working with an RX streamer.
Definition: usrp.h:98
UHD_API uhd_error uhd_usrp_set_time_source_out(uhd_usrp_handle h, bool enb, size_t mboard)
Enable or disable sending the time source to an output connector.
UHD_API uhd_error uhd_usrp_get_tx_freq_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle freq_range_out)
UHD_API uhd_error uhd_usrp_set_rx_subdev_spec(uhd_usrp_handle h, uhd_subdev_spec_handle subdev_spec, size_t mboard)
Map the given device&#39;s RX frontend to a channel.
UHD_API uhd_error uhd_usrp_last_error(uhd_usrp_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the USRP handle.
UHD_API uhd_error uhd_usrp_get_rx_lo_source(uhd_usrp_handle h, const char *name, size_t chan, char *rx_lo_source_out, size_t strbuffer_len)
Get the currently set LO source.
UHD_API uhd_error uhd_usrp_get_rx_rates(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle rates_out)
Get a range of possible RX rates for the given channel.
uhd_string_vector_t * uhd_string_vector_handle
Definition: string_vector.h:33
USRP TX info.
Definition: usrp_info.h:41
UHD_API uhd_error uhd_usrp_set_time_unknown_pps(uhd_usrp_handle h, int64_t full_secs, double frac_secs)
Synchronize the time across all motherboards.
Definition: config.h:68
Definition: soft_register.hpp:88
UHD_API uhd_error uhd_usrp_get_rx_gain_range(uhd_usrp_handle h, const char *name, size_t chan, uhd_meta_range_handle gain_range_out)
UHD_API uhd_error uhd_usrp_write_register(uhd_usrp_handle h, const char *path, uint32_t field, uint64_t value, size_t mboard)
Write a low-level register field for a device register in the USRP hardware.
Instructs implementation how to tune the RF chain.
Definition: tune_request.h:29
UHD_API uhd_error uhd_tx_streamer_max_num_samps(uhd_tx_streamer_handle h, size_t *max_num_samps_out)
UHD_API uhd_error uhd_usrp_get_rx_gain(uhd_usrp_handle h, size_t chan, const char *gain_name, double *gain_out)
UHD_API uhd_error uhd_usrp_get_tx_lo_source(uhd_usrp_handle h, const char *name, size_t chan, char *tx_lo_source_out, size_t strbuffer_len)
Stream some number of samples but expect more.
Definition: usrp.h:71
UHD_API uhd_error uhd_usrp_set_tx_lo_freq(uhd_usrp_handle h, double freq, const char *name, size_t chan, double *coerced_freq_out)
Set the Tx LO frequency.
Definition: sensors.h:34
UHD_API uhd_error uhd_usrp_set_rx_rate(uhd_usrp_handle h, double rate, size_t chan)
size_t * channel_list
Array that lists channels.
Definition: usrp.h:54
UHD_API uhd_error uhd_usrp_get_tx_lo_export_enabled(uhd_usrp_handle h, const char *name, size_t chan, bool *result_out)
UHD_API uhd_error uhd_usrp_get_mboard_sensor_names(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *mboard_sensor_names_out)
Get a list of motherboard sensors for the given device.
UHD_API uhd_error uhd_tx_streamer_send(uhd_tx_streamer_handle h, const void **buffs, size_t samps_per_buff, uhd_tx_metadata_handle *md, double timeout, size_t *items_sent)
Send buffers containing samples described by the metadata.
int n_channels
Number of channels.
Definition: usrp.h:56
UHD_API uhd_error uhd_usrp_get_tx_rates(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle rates_out)
UHD_API uhd_error uhd_usrp_set_clock_source_out(uhd_usrp_handle h, bool enb, size_t mboard)
Enable or disable sending the clock source to an output connector.
UHD_API uhd_error uhd_usrp_get_tx_gain_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *gain_names_out)
Get a list of TX gain names for the given channel.
UHD_API uhd_error uhd_tx_streamer_recv_async_msg(uhd_tx_streamer_handle h, uhd_async_metadata_handle *md, double timeout, bool *valid)
Receive an asynchronous message from this streamer.
UHD_API uhd_error uhd_usrp_get_mboard_name(uhd_usrp_handle h, size_t mboard, char *mboard_name_out, size_t strbuffer_len)
Get the motherboard name for the given device.
UHD_API uhd_error uhd_usrp_set_rx_antenna(uhd_usrp_handle h, const char *ant, size_t chan)
Set the RX antenna for the given channel.
UHD_API uhd_error uhd_rx_streamer_num_channels(uhd_rx_streamer_handle h, size_t *num_channels_out)
struct uhd_subdev_spec_t * uhd_subdev_spec_handle
A C-level interface for working with a list of subdevice specifications.
Definition: subdev_spec.h:45
UHD_API uhd_error uhd_usrp_get_rx_lo_names(uhd_usrp_handle h, size_t chan, uhd_string_vector_handle *rx_lo_names_out)
UHD_API uhd_error uhd_usrp_set_rx_freq(uhd_usrp_handle h, uhd_tune_request_t *tune_request, size_t chan, uhd_tune_result_t *tune_result)
Set the given channel&#39;s center RX frequency.
UHD_API uhd_error uhd_usrp_get_normalized_rx_gain(uhd_usrp_handle h, size_t chan, double *gain_out)
Get the given channel&#39;s normalized RX gain [0.0, 1.0].
size_t num_samps
Number of samples.
Definition: usrp.h:82
UHD_API uhd_error uhd_usrp_get_rx_subdev_spec(uhd_usrp_handle h, size_t mboard, uhd_subdev_spec_handle subdev_spec_out)
Get the RX frontend specification for the given device.
UHD_API uhd_error uhd_usrp_get_clock_sources(uhd_usrp_handle h, size_t mboard, uhd_string_vector_handle *clock_sources_out)
Get a list of clock sources for the given device.
UHD_API uhd_error uhd_usrp_get_normalized_tx_gain(uhd_usrp_handle h, size_t chan, double *gain_out)
Get the given channel&#39;s normalized TX gain [0.0, 1.0].
UHD_API uhd_error uhd_usrp_set_rx_bandwidth(uhd_usrp_handle h, double bandwidth, size_t chan)
Set the bandwidth for the given channel&#39;s RX frontend.
struct uhd_tx_streamer * uhd_tx_streamer_handle
C-level interface for working with a TX streamer.
Definition: usrp.h:104
UHD_API uhd_error uhd_usrp_get_rx_rate(uhd_usrp_handle h, size_t chan, double *rate_out)
UHD_API uhd_error uhd_usrp_get_time_now(uhd_usrp_handle h, size_t mboard, int64_t *full_secs_out, double *frac_secs_out)
Get the USRP device&#39;s current internal time.
UHD_API uhd_error uhd_usrp_get_clock_source(uhd_usrp_handle h, size_t mboard, char *clock_source_out, size_t strbuffer_len)
Get the given device&#39;s clock source.
UHD_API uhd_error uhd_usrp_get_rx_bandwidth_range(uhd_usrp_handle h, size_t chan, uhd_meta_range_handle bandwidth_range_out)
Get all possible bandwidth ranges for the given channel&#39;s RX frontend.
UHD_API uhd_error uhd_usrp_find(const char *args, uhd_string_vector_handle *strings_out)
Find all connected USRP devices.
UHD_API uhd_error uhd_usrp_get_mboard_eeprom(uhd_usrp_handle h, uhd_mboard_eeprom_handle mb_eeprom, size_t mboard)
Get a handle for the given motherboard&#39;s EEPROM.
UHD_API uhd_error uhd_usrp_get_master_clock_rate(uhd_usrp_handle h, size_t mboard, double *clock_rate_out)
Get the master clock rate.
UHD_API uhd_error uhd_usrp_set_dboard_eeprom(uhd_usrp_handle h, uhd_dboard_eeprom_handle db_eeprom, const char *unit, const char *slot, size_t mboard)
Set values in the given daughterboard&#39;s EEPROM.
char * otw_format
Over-the-wire format.
Definition: usrp.h:50
UHD_API uhd_error uhd_rx_streamer_free(uhd_rx_streamer_handle *h)
Free an RX streamer handle.
