8 #ifndef INCLUDED_UHD_TYPES_FILTERS_HPP     9 #define INCLUDED_UHD_TYPES_FILTERS_HPP    14 #include <boost/scoped_array.hpp>    15 #include <boost/shared_ptr.hpp>    27     typedef boost::shared_ptr<filter_info_base>
sptr;
    28     enum filter_type { ANALOG_LOW_PASS, ANALOG_BAND_PASS, DIGITAL_I16, DIGITAL_FIR_I16 };
    31         : _type(type), _bypass(bypass), _position_index(position_index)
    51     virtual std::string to_pp_string();
    63     std::string _analog_type;
    66     typedef boost::shared_ptr<analog_filter_base>
sptr;
    69         size_t position_index,
    70         const std::string& analog_type)
    81     virtual std::string to_pp_string();
    90     typedef boost::shared_ptr<analog_filter_lp>
sptr;
    93         size_t position_index,
    94         const std::string& analog_type,
   119     virtual std::string to_pp_string();
   133     typedef boost::shared_ptr<digital_filter_base>
sptr;
   136         size_t position_index,
   138         size_t interpolation,
   140         double tap_full_scale,
   142         const std::vector<tap_t>& taps)
   145         , _interpolation(interpolation)
   146         , _decimation(decimation)
   147         , _tap_full_scale(tap_full_scale)
   148         , _max_num_taps(max_num_taps)
   156         return (_bypass ? _rate : (_rate / _decimation * _interpolation));
   166         return _interpolation;
   176         return _tap_full_scale;
   186         std::ostringstream os;
   188            <<
"\tinput rate: " << _rate << std::endl
   189            <<
"\tinterpolation: " << _interpolation << std::endl
   190            <<
"\tdecimation: " << _decimation << std::endl
   191            <<
"\tfull-scale: " << _tap_full_scale << std::endl
   192            <<
"\tmax num taps: " << _max_num_taps << std::endl
   193            <<
"\ttaps: " << std::endl;
   196         for (
size_t i = 0; i < _taps.size(); i++) {
   197             os <<
"(tap " << i <<
": " << _taps[i] <<
   198             if (((i % 10) == 0) && (i != 0)) {
   199                 os << std::endl <<
"\t\t";
   203         return std::string(os.str());
   207 template <
typename tap_t>
   211     typedef boost::shared_ptr<digital_filter_fir<tap_t> >
sptr;
   215         size_t position_index,
   217         size_t interpolation,
   219         size_t tap_bit_width,
   221         const std::vector<tap_t>& taps)
   237         std::size_t num_taps = taps.size();
   238         if (num_taps < this->_max_num_taps) {
   240                                              "coefficients. Appending zeros";
   241             std::vector<tap_t> coeffs;
   242             for (
size_t i = 0; i < this->_max_num_taps; i++) {
   244                     coeffs.push_back(taps[i]);
   249             this->_taps = coeffs;
boost::shared_ptr< digital_filter_fir< tap_t > > sptr
Definition: filters.hpp:211
filter_type _type
Definition: filters.hpp:54
Definition: filters.hpp:208
UHD_INLINE std::vector< tap_t > & get_taps()
Definition: filters.hpp:179
std::vector< tap_t > _taps
Definition: filters.hpp:130
boost::shared_ptr< analog_filter_base > sptr
Definition: filters.hpp:66
Definition: filters.hpp:184
UHD_INLINE const std::string & get_analog_type()
Definition: filters.hpp:76
UHD_INLINE double get_decimation()
Definition: filters.hpp:169
UHD_INLINE double get_interpolation()
Definition: filters.hpp:164
uint32_t _decimation
Definition: filters.hpp:127
virtual UHD_INLINE bool is_bypassed()
Definition: filters.hpp:36
tap_t _tap_full_scale
Definition: filters.hpp:128
Definition: filters.hpp:122
bool _bypass
Definition: filters.hpp:55
Definition: filters.hpp:61
UHD_INLINE void set_cutoff(const double cutoff)
Definition: filters.hpp:114
Definition: build_info.hpp:13
void set_taps(const std::vector< tap_t > &taps)
Definition: filters.hpp:235
digital_filter_base(filter_type type, bool bypass, size_t position_index, double rate, size_t interpolation, size_t decimation, double tap_full_scale, size_t max_num_taps, const std::vector< tap_t > &taps)
Definition: filters.hpp:134
Definition: filters.hpp:24
UHD_INLINE double get_rolloff()
Definition: filters.hpp:109
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:27
UHD_INLINE double get_input_rate()
Definition: filters.hpp:159
Definition: filters.hpp:84
UHD_INLINE double get_tap_full_scale()
Definition: filters.hpp:174
analog_filter_base(filter_type type, bool bypass, size_t position_index, const std::string &analog_type)
Definition: filters.hpp:67
virtual ~filter_info_base()
Definition: filters.hpp:46
#define UHD_INLINE
Definition: config.h:53
digital_filter_fir(filter_info_base::filter_type type, bool bypass, size_t position_index, double rate, size_t interpolation, size_t decimation, size_t tap_bit_width, size_t max_num_taps, const std::vector< tap_t > &taps)
Definition: filters.hpp:213
analog_filter_lp(filter_type type, bool bypass, size_t position_index, const std::string &analog_type, double cutoff, double rolloff)
Definition: filters.hpp:91
size_t _position_index
Definition: filters.hpp:56
Definition: config.h:68
filter_type
Definition: filters.hpp:28
filter_info_base(filter_type type, bool bypass, size_t position_index)
Definition: filters.hpp:30
boost::shared_ptr< analog_filter_lp > sptr
Definition: filters.hpp:90
uint32_t _interpolation
Definition: filters.hpp:126
UHD_INLINE double get_cutoff()
Definition: filters.hpp:104
boost::shared_ptr< digital_filter_base > sptr
Definition: filters.hpp:133
UHD_INLINE double get_output_rate()
Definition: filters.hpp:154
uint32_t _max_num_taps
Definition: filters.hpp:129
double _rate
Definition: filters.hpp:125
#define UHD_LOGGER_WARNING(component)
Definition: log.hpp:238
UHD_INLINE filter_type get_type()
Definition: filters.hpp:41
