8 #ifndef INCLUDED_UHD_UTILS_LOG_HPP     9 #define INCLUDED_UHD_UTILS_LOG_HPP    12 #include <boost/current_function.hpp>    13 #include <boost/thread/thread.hpp>    97 namespace uhd {
namespace log {
   123         const std::string& file_,
   124         const unsigned int& line_,
   125         const std::string& component_,
   126         const boost::thread::id& thread_id_)
   128         , verbosity(verbosity_)
   131         , component(component_)
   132         , thread_id(thread_id_)
   177 #define _UHD_LOG_INTERNAL(component, level) \   178     uhd::_log::log(level, __FILE__, __LINE__, component, boost::this_thread::get_id())   182 #if UHD_LOG_MIN_LEVEL < 1   183 #    define UHD_LOG_TRACE(component, message) \   184         _UHD_LOG_INTERNAL(component, uhd::log::trace) << message;   186 #    define UHD_LOG_TRACE(component, message)   189 #if UHD_LOG_MIN_LEVEL < 2   190 #    define UHD_LOG_DEBUG(component, message) \   191         _UHD_LOG_INTERNAL(component, uhd::log::debug) << message;   193 #    define UHD_LOG_DEBUG(component, message)   196 #if UHD_LOG_MIN_LEVEL < 3   197 #    define UHD_LOG_INFO(component, message) \   198         _UHD_LOG_INTERNAL(component, uhd::log::info) << message;   200 #    define UHD_LOG_INFO(component, message)   203 #if UHD_LOG_MIN_LEVEL < 4   204 #    define UHD_LOG_WARNING(component, message) \   205         _UHD_LOG_INTERNAL(component, uhd::log::warning) << message;   207 #    define UHD_LOG_WARNING(component, message)   210 #if UHD_LOG_MIN_LEVEL < 5   211 #    define UHD_LOG_ERROR(component, message) \   212         _UHD_LOG_INTERNAL(component, uhd::log::error) << message;   214 #    define UHD_LOG_ERROR(component, message)   217 #if UHD_LOG_MIN_LEVEL < 6   218 #    define UHD_LOG_FATAL(component, message) \   219         _UHD_LOG_INTERNAL(component, uhd::log::fatal) << message;   221 #    define UHD_LOG_FATAL(component, message)   224 #ifndef UHD_LOG_FASTPATH_DISABLE   229 #    define UHD_LOG_FASTPATH(message) uhd::_log::log_fastpath(message);   231 #    define UHD_LOG_FASTPATH(message)   235 #define UHD_LOGGER_TRACE(component) _UHD_LOG_INTERNAL(component, uhd::log::trace)   236 #define UHD_LOGGER_DEBUG(component) _UHD_LOG_INTERNAL(component, uhd::log::debug)   237 #define UHD_LOGGER_INFO(component) _UHD_LOG_INTERNAL(component, uhd::log::info)   238 #define UHD_LOGGER_WARNING(component) _UHD_LOG_INTERNAL(component, uhd::log::warning)   239 #define UHD_LOGGER_ERROR(component) _UHD_LOG_INTERNAL(component, uhd::log::error)   240 #define UHD_LOGGER_FATAL(component) _UHD_LOG_INTERNAL(component, uhd::log::fatal)   243 #if defined(__GNUG__)   244 #    define UHD_HERE()            \   246         UHD_LOGGER_DEBUG("DEBUG") \   247             << __FILE__ << ":" << __LINE__ << " (" << __PRETTY_FUNCTION__ << ")";   249 #    define UHD_HERE() UHD_LOGGER_DEBUG("DEBUG") << __FILE__ << ":" << __LINE__;   254 #define UHD_VAR(var) UHD_LOGGER_DEBUG("DEBUG") << #var << " = " << var;   257 #define UHD_HEX(var)                                                              \   258     UHD_LOGGER_DEBUG("DEBUG") << #var << " = 0x" << std::hex << std::setfill('0') \   259                               << std::setw(8) << var << std::dec;   266 void UHD_API log_fastpath(
const std::string&);
   273         const std::string& file,
   274         const unsigned int line,
   275         const std::string& component,
   276         const boost::thread::id thread_id);
   282 #define INSERTION_OVERLOAD(x) \   292     template <
typename T>
   293     INSERTION_OVERLOAD(T val)
   296     INSERTION_OVERLOAD(std::ostream& (*val)(std::ostream&))
   297         INSERTION_OVERLOAD(std::ios& (*val)(std::ios&))
   298             INSERTION_OVERLOAD(std::ios_base& (*val)(std::ios_base&))
   301     std::ostringstream _ss;
 boost::posix_time::ptime time
Definition: log.hpp:136
std::string file
Definition: log.hpp:138
unsigned int line
Definition: log.hpp:139
logging_info()
Definition: log.hpp:120
severity_level
Definition: log.hpp:103
Definition: build_info.hpp:13
UHD_API void set_file_level(uhd::log::severity_level level)
uhd::log::severity_level verbosity
Definition: log.hpp:137
UHD_API void set_log_level(uhd::log::severity_level level)
UHD_API void set_logger_level(const std::string &logger, uhd::log::severity_level level)
Definition: log.hpp:141
Definition: config.h:68
std::string message
Definition: log.hpp:142
UHD_API void set_console_level(uhd::log::severity_level level)
std::string component
Definition: log.hpp:140
logging_info(const boost::posix_time::ptime &time_, const uhd::log::severity_level &verbosity_, const std::string &file_, const unsigned int &line_, const std::string &component_, const boost::thread::id &thread_id_)
Definition: log.hpp:121
