8 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP     9 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP    12 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API    13 #define UHD_USRP_MULTI_USRP_GET_RATES_API    14 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API    15 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API    16 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API    17 #define UHD_USRP_MULTI_USRP_BW_RANGE_API    18 #define UHD_USRP_MULTI_USRP_USER_REGS_API    19 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API    20 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN    21 #define UHD_USRP_MULTI_USRP_GPIO_API    22 #define UHD_USRP_MULTI_USRP_REGISTER_API    23 #define UHD_USRP_MULTI_USRP_FILTER_API    24 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API    25 #define UHD_USRP_MULTI_USRP_TX_LO_CONFIG_API    39 #include <boost/shared_ptr.hpp>    40 #include <boost/utility.hpp>    99     typedef boost::shared_ptr<multi_usrp>
sptr;
   133     virtual bool is_device3(
void) = 0;
   143     virtual boost::shared_ptr<uhd::device3> get_device3(
void) = 0;
   195     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
   202     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
   222     virtual meta_range_t get_master_clock_rate_range(
const size_t mboard = 0) = 0;
   228     virtual std::string get_pp_string(
void) = 0;
   235     virtual std::string get_mboard_name(
   242     virtual time_spec_t get_time_now(
   249     virtual time_spec_t get_time_last_pps(
   262     virtual void set_time_now(
   263         const time_spec_t& time_spec,
   277     virtual void set_time_next_pps(
   278         const time_spec_t& time_spec,
   295     virtual void set_time_unknown_pps(
const time_spec_t& time_spec) = 0;
   303     virtual bool get_time_synchronized(
void) = 0;
   315     virtual void set_command_time(
   323     virtual void clear_command_time(
   337     virtual void issue_stream_cmd(
   338         const stream_cmd_t& stream_cmd,
size_t chan = ALL_CHANS) = 0;
   348     virtual void set_clock_config(
   349         const clock_config_t& clock_config,
   393     virtual void set_time_source(
   394         const std::string& source,
const size_t mboard = ALL_MBOARDS) = 0;
   401     virtual std::string get_time_source(
const size_t mboard) = 0;
   408     virtual std::vector<std::string> get_time_sources(
   452     virtual void set_clock_source(
   453         const std::string& source,
   460     virtual std::string get_clock_source(
   467     virtual std::vector<std::string> get_clock_sources(
   479     virtual void set_sync_source(
const std::string& clock_source,
   480         const std::string& time_source,
   481         const size_t mboard = ALL_MBOARDS) = 0;
   505     virtual void set_sync_source(
   506         const device_addr_t& sync_source,
   513     virtual device_addr_t get_sync_source(
   520     virtual std::vector<device_addr_t> get_sync_sources(
   530     virtual void set_clock_source_out(
   531         const bool enb,
   541     virtual void set_time_source_out(
   542         const bool enb,
   547     virtual size_t get_num_mboards(
void) = 0;
   556         const std::string& name,
   563     virtual std::vector<std::string> get_mboard_sensor_names(
   572     virtual void set_user_register(
   573         const uint8_t addr,
const uint32_t data,
   612     virtual void set_rx_subdev_spec(
   627     virtual size_t get_rx_num_channels(
void) = 0;
   634     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
   641     virtual void set_rx_rate(
double rate,
   648     virtual double get_rx_rate(
   671     virtual double get_rx_freq(
   682     virtual freq_range_t get_rx_freq_range(
   689     virtual freq_range_t get_fe_rx_freq_range(
   707     virtual std::vector<std::string> get_rx_lo_names(
   720     virtual void set_rx_lo_source(
   721         const std::string& src,
const std::string& name = ALL_LOS,
   731     virtual const std::string get_rx_lo_source(
   732         const std::string& name = ALL_LOS,
   745     virtual std::vector<std::string> get_rx_lo_sources(
   746         const std::string& name = ALL_LOS,
   758     virtual void set_rx_lo_export_enabled(
   759         bool enabled,
   766     virtual bool get_rx_lo_export_enabled(
   767         const std::string& name = ALL_LOS,
   792     virtual double set_rx_lo_freq(
   793         double freq,
   805     virtual double get_rx_lo_freq(
   817         const std::string& name,
   831     virtual std::vector<std::string> get_tx_lo_names(
   844     virtual void set_tx_lo_source(
   845         const std::string& name = ALL_LOS,
   846         const size_t chan       = 0) = 0;
   856     virtual const std::string get_tx_lo_source(
   857         const std::string& name = ALL_LOS,
   869     virtual std::vector<std::string> get_tx_lo_sources(
   870         const std::string& name = ALL_LOS,
   882     virtual void set_tx_lo_export_enabled(
   883         const bool enabled,
   890     virtual bool get_tx_lo_export_enabled(
   891         const std::string& name = ALL_LOS,
   916     virtual double set_tx_lo_freq(
   917         const double freq,
   929     virtual double get_tx_lo_freq(
   941         const std::string& name,
   953     virtual void set_rx_gain(
double gain,
   967     virtual std::vector<std::string> get_rx_gain_profile_names(
   974     virtual void set_rx_gain_profile(
   975         const std::string& profile,
   982     virtual std::string get_rx_gain_profile(
   987         return this->set_rx_gain(gain, ALL_GAINS, chan);
  1006     virtual void set_normalized_rx_gain(
double gain,
  1016     virtual void set_rx_agc(
bool enable,
  1025     virtual double get_rx_gain(
  1030         return this->get_rx_gain(ALL_GAINS, chan);
  1043     virtual double get_normalized_rx_gain(
  1052     virtual gain_range_t get_rx_gain_range(
  1057         return this->get_rx_gain_range(ALL_GAINS, chan);
  1066     virtual std::vector<std::string> get_rx_gain_names(
  1073     virtual void set_rx_antenna(
const std::string& ant,
  1080     virtual std::string get_rx_antenna(
  1087     virtual std::vector<std::string> get_rx_antennas(
  1094     virtual void set_rx_bandwidth(
double bandwidth,
  1101     virtual double get_rx_bandwidth(
  1108     virtual meta_range_t get_rx_bandwidth_range(
  1125     virtual sensor_value_t get_rx_sensor(
  1132     virtual std::vector<std::string> get_rx_sensor_names(
  1146     virtual void set_rx_dc_offset(
const bool enb,
  1155     virtual void set_rx_dc_offset(
  1156         const std::complex<double>& offset,
  1162     virtual meta_range_t get_rx_dc_offset_range(
  1170     virtual void set_rx_iq_balance(
const bool enb,
size_t chan) = 0;
  1179     virtual void set_rx_iq_balance(
  1180         const std::complex<double>& correction,
  1193     virtual void set_tx_subdev_spec(
  1208     virtual size_t get_tx_num_channels(
void) = 0;
  1215     virtual std::string get_tx_subdev_name(
  1222     virtual void set_tx_rate(
double rate,
  1229     virtual double get_tx_rate(
  1236     virtual meta_range_t get_tx_rates(
  1252     virtual double get_tx_freq(
  1263     virtual freq_range_t get_tx_freq_range(
  1270     virtual freq_range_t get_fe_tx_freq_range(
  1279     virtual void set_tx_gain(
double gain,
  1293     virtual std::vector<std::string> get_tx_gain_profile_names(
  1300     virtual void set_tx_gain_profile(
  1301         const std::string& profile,
  1308     virtual std::string get_tx_gain_profile(
  1313         return this->set_tx_gain(gain, ALL_GAINS, chan);
  1326     virtual void set_normalized_tx_gain(
double gain,
  1335     virtual double get_tx_gain(
  1340         return this->get_tx_gain(ALL_GAINS, chan);
  1353     virtual double get_normalized_tx_gain(
  1362     virtual gain_range_t get_tx_gain_range(
  1367         return this->get_tx_gain_range(ALL_GAINS, chan);
  1376     virtual std::vector<std::string> get_tx_gain_names(
  1383     virtual void set_tx_antenna(
  1390     virtual std::string get_tx_antenna(
  1397     virtual std::vector<std::string> get_tx_antennas(
  1404     virtual void set_tx_bandwidth(
double bandwidth,
  1411     virtual double get_tx_bandwidth(
  1418     virtual meta_range_t get_tx_bandwidth_range(
  1435     virtual sensor_value_t get_tx_sensor(
  1442     virtual std::vector<std::string> get_tx_sensor_names(
  1450     virtual void set_tx_dc_offset(
  1451         const std::complex<double>& offset,
  1457     virtual meta_range_t get_tx_dc_offset_range(
  1466     virtual void set_tx_iq_balance(
  1467         const std::complex<double>& correction,
  1478     virtual std::vector<std::string> get_gpio_banks(
  1496     virtual void set_gpio_attr(
const std::string& bank,
  1497         const std::string& attr,
  1498         const uint32_t value,
  1499         const uint32_t
mask = 0xffffffff,
  1500         const size_t mboard = 0) = 0;
  1532     virtual void set_gpio_attr(
  1533         const std::string& attr,
  1534         const std::string& value,
  1535         const uint32_t
mask = 0xffffffff,
  1536         const size_t mboard = 0) = 0;
  1554     virtual uint32_t get_gpio_attr(
  1555         const std::string& bank,
  1590     virtual std::vector<std::string> get_gpio_string_attr(
  1591         const std::string& bank,
  1608     virtual std::vector<std::string> enumerate_registers(
  1618         const std::string& path,
  1627     virtual void write_register(
  1628         const uint32_t field,
  1629         const uint64_t value,
  1630         const size_t mboard = 0) = 0;
  1639     virtual uint64_t read_register(
  1640         const std::string& path,
  1656     virtual std::vector<std::string> get_filter_names(
  1657         const std::string& search_mask =
"") = 0;
Definition: multi_usrp.hpp:1055
boost::shared_ptr< wb_iface > sptr
Definition: wb_iface.hpp:21
Definition: stream_cmd.hpp:36
Definition: tune_result.hpp:19
Definition: multi_usrp.hpp:1338
Definition: multi_usrp.hpp:1311
Definition: time_spec.hpp:29
static const size_t ALL_MBOARDS
A wildcard motherboard index.
Definition: multi_usrp.hpp:104
bool readable
Definition: multi_usrp.hpp:1599
Definition: device.hpp:31
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:99
Definition: multi_usrp.hpp:1596
Definition: multi_usrp.hpp:1028
Definition: tune_request.hpp:25
Definition: stream.hpp:172
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:110
Definition: build_info.hpp:13
Definition: sensors.hpp:29
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:27
Definition: clock_config.hpp:26
Definition: multi_usrp.hpp:96
Definition: stream.hpp:58
Definition: config.h:68
Definition: soft_register.hpp:88
Definition: dboard_iface.hpp:56
Definition: multi_usrp.hpp:985
static const std::string ALL_LOS
A wildcard LO stage name.
Definition: multi_usrp.hpp:113
Definition: subdev_spec.hpp:60
bool writable
Definition: multi_usrp.hpp:1600
size_t bitwidth
Definition: multi_usrp.hpp:1598
Definition: stream.hpp:247
static const size_t ALL_CHANS
A wildcard channel index.
Definition: multi_usrp.hpp:107
Definition: multi_usrp.hpp:1365
