Binary Installation
Installation on Windows
We provide UHD software installers for Windows users who do not wish to install UHD from source.
LibUSBx
All Windows installers are built with LibUSBx to enable USB3 support.
Installer Packages
Installer packages are built from release tags of the maint branch.
Please find the latest installer here: http://files.ettus.com/binaries/uhd/latest_release
Post-Install Tasks
Using a USB-based device?
Install the MSVC Redistributable Package:
Building from source
  • MinGW
Installation on Linux
Using your package manager
sudo apt-get install libuhd-dev libuhd003 uhd-host
We provide UHD binary installers for Ubuntu and Fedora users for every stable release. Typically, we will provide binaries for latest two LTS versions of Ubuntu, and for the latest two versions of Fedora.
Ubuntu
sudo apt-get update
Fedora
yum clean metadata all
[ettus-uhd-stable-repo]
gpgcheck=0
Run the following commands:
Using PyBOMBS
Installation on Mac OS X
Via MacPorts
sudo port install uhd
sudo port install uhd-devel
