8 #ifndef INCLUDED_UHD_TYPES_SERIAL_HPP     9 #define INCLUDED_UHD_TYPES_SERIAL_HPP    13 #include <boost/shared_ptr.hpp>    38     typedef boost::shared_ptr<i2c_iface>
sptr;
    50     virtual void write_i2c(uint16_t addr,
const byte_vector_t& buf) = 0;
    58     virtual byte_vector_t read_i2c(uint16_t addr,
size_t num_bytes) = 0;
    66     virtual void write_eeprom(uint16_t addr, uint16_t offset,
const byte_vector_t& buf);
    75     virtual byte_vector_t read_eeprom(uint16_t addr, uint16_t offset,
size_t num_bytes);
    88     enum edge_t { EDGE_RISE =
'r', EDGE_FALL =
'f' };
   117     typedef boost::shared_ptr<spi_iface>
sptr;
   130     virtual uint32_t transact_spi(
int which_slave,
   144     virtual uint32_t read_spi(
   145         int which_slave,
const spi_config_t& config, uint32_t data,
size_t num_bits);
   154     virtual void write_spi(
   155         int which_slave,
size_t num_bits);
   164     typedef boost::shared_ptr<uart_iface>
sptr;
   172     virtual void write_uart(
const std::string& buf) = 0;
   179     virtual std::string read_uart(
double timeout) = 0;
 size_t divider
Optionally set the SPI clock divider for this transaction.
Definition: serial.hpp:100
Definition: serial.hpp:114
Definition: serial.hpp:35
bool use_custom_divider
Set the clock speed for this transaction.
Definition: serial.hpp:97
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:91
Definition: build_info.hpp:13
Definition: serial.hpp:82
boost::shared_ptr< spi_iface > sptr
Definition: serial.hpp:117
Definition: config.h:68
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:94
Definition: serial.hpp:161
Definition: serial.hpp:164
edge_t
Definition: serial.hpp:88
boost::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:38
Definition: byte_vector.hpp:20
