dboard_iface.hpp
2 // Copyright 2010-2013,2015-2016 Ettus Research LLC
4 //
6 //
7
8 #ifndef INCLUDED_UHD_USRP_DBOARD_IFACE_HPP
9 #define INCLUDED_UHD_USRP_DBOARD_IFACE_HPP
10
11 #include <uhd/config.hpp>
12 #include <uhd/types/serial.hpp>
13 #include <uhd/types/time_spec.hpp>
15 #include <uhd/usrp/gpio_defs.hpp>
16 #include <uhd/utils/pimpl.hpp>
17 #include <stdint.h>
18 #include <boost/shared_ptr.hpp>
19 #include <boost/thread/thread.hpp>
20 #include <string>
21 #include <vector>
22
23 namespace uhd { namespace usrp {
27 {
35
45 };
46
54 {
55 public:
56  typedef boost::shared_ptr<dboard_iface> sptr;
58
60  enum unit_t {
61  UNIT_RX = int('r'),
62  UNIT_TX = int('t'),
63  UNIT_BOTH = int('b'),
64  };
65
67  enum aux_dac_t {
68  AUX_DAC_A = int('a'),
69  AUX_DAC_B = int('b'),
70  AUX_DAC_C = int('c'),
71  AUX_DAC_D = int('d')
72  };
73
75  enum aux_adc_t { AUX_ADC_A = int('a'), AUX_ADC_B = int('b') };
76
78
79  virtual ~dboard_iface(void){};
80
87  virtual special_props_t get_special_props(void) = 0;
88
96  virtual void write_aux_dac(unit_t unit, aux_dac_t which_dac, double value) = 0;
97
105  virtual double read_aux_adc(unit_t unit, aux_adc_t which_adc) = 0;
106
114  virtual void set_pin_ctrl(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
115
122  virtual uint32_t get_pin_ctrl(unit_t unit) = 0;
123
132  virtual void set_atr_reg(
133  unit_t unit, atr_reg_t reg, uint32_t value, uint32_t mask = 0xffff) = 0;
134
142  virtual uint32_t get_atr_reg(unit_t unit, atr_reg_t reg) = 0;
143
151  virtual void set_gpio_ddr(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
152
159  virtual uint32_t get_gpio_ddr(unit_t unit) = 0;
160
168  virtual void set_gpio_out(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
169
176  virtual uint32_t get_gpio_out(unit_t unit) = 0;
177
184  virtual uint32_t read_gpio(unit_t unit) = 0;
185
194  virtual void write_spi(
195  unit_t unit, const spi_config_t& config, uint32_t data, size_t num_bits) = 0;
196
206  virtual uint32_t read_write_spi(
207  unit_t unit, const spi_config_t& config, uint32_t data, size_t num_bits) = 0;
208
215  virtual void set_clock_rate(unit_t unit, double rate) = 0;
216
223  virtual double get_clock_rate(unit_t unit) = 0;
224
231  virtual std::vector<double> get_clock_rates(unit_t unit) = 0;
232
239  virtual void set_clock_enabled(unit_t unit, bool enb) = 0;
240
248  virtual double get_codec_rate(unit_t unit) = 0;
249
257  virtual void set_fe_connection(unit_t unit,
258  const std::string& fe_name,
259  const uhd::usrp::fe_connection_t& fe_conn) = 0;
260
263  virtual bool has_set_fe_connection(const unit_t)
264  {
265  return false;
266  }
267
272  virtual uhd::time_spec_t get_command_time(void) = 0;
273
278  virtual void set_command_time(const uhd::time_spec_t& t) = 0;
279
284  virtual void sleep(const boost::chrono::nanoseconds& time);
285 };
286
287 }} // namespace uhd::usrp
288
289 #endif /* INCLUDED_UHD_USRP_DBOARD_IFACE_HPP */
Definition: dboard_iface.hpp:79
aux_adc_t
Definition: dboard_iface.hpp:75
Definition: serial.hpp:35
uhd::usrp::gpio_atr::gpio_atr_reg_t atr_reg_t
Definition: dboard_iface.hpp:77
Definition: time_spec.hpp:29
aux_dac_t
Definition: dboard_iface.hpp:67
Definition: build_info.hpp:13
Definition: dboard_iface.hpp:53
bool soft_clock_divider
Definition: dboard_iface.hpp:34
Definition: serial.hpp:82
Definition: fe_connection.hpp:17
gpio_atr_reg_t
Definition: gpio_defs.hpp:13
Definition: config.h:68
Definition: soft_register.hpp:88
Definition: dboard_iface.hpp:56
Definition: dboard_iface.hpp:57
Definition: dboard_iface.hpp:26
Definition: dboard_iface.hpp:263
unit_t
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:44
