filters.hpp
4 //
6 //
7
8 #ifndef INCLUDED_UHD_TYPES_FILTERS_HPP
9 #define INCLUDED_UHD_TYPES_FILTERS_HPP
10
11 #include <uhd/config.hpp>
12 #include <uhd/utils/log.hpp>
13 #include <stdint.h>
14 #include <boost/scoped_array.hpp>
15 #include <boost/shared_ptr.hpp>
16 #include <iostream>
17 #include <ostream>
18 #include <sstream>
19 #include <string>
20 #include <vector>
21
22 namespace uhd {
23
25 {
26 public:
27  typedef boost::shared_ptr<filter_info_base> sptr;
28  enum filter_type { ANALOG_LOW_PASS, ANALOG_BAND_PASS, DIGITAL_I16, DIGITAL_FIR_I16 };
29
30  filter_info_base(filter_type type, bool bypass, size_t position_index)
31  : _type(type), _bypass(bypass), _position_index(position_index)
32  {
33  // NOP
34  }
35
36  UHD_INLINE virtual bool is_bypassed()
37  {
38  return _bypass;
39  }
40
42  {
43  return _type;
44  }
45
47  {
48  // NOP
49  }
50
51  virtual std::string to_pp_string();
52
53 protected:
55  bool _bypass;
57 };
58
59 UHD_API std::ostream& operator<<(std::ostream& os, filter_info_base& f);
60
62 {
63  std::string _analog_type;
64
65 public:
66  typedef boost::shared_ptr<analog_filter_base> sptr;
68  bool bypass,
69  size_t position_index,
70  const std::string& analog_type)
71  : filter_info_base(type, bypass, position_index), _analog_type(analog_type)
72  {
73  // NOP
74  }
75
76  UHD_INLINE const std::string& get_analog_type()
77  {
78  return _analog_type;
79  }
80
81  virtual std::string to_pp_string();
82 };
83
85 {
86  double _cutoff;
87  double _rolloff;
88
89 public:
90  typedef boost::shared_ptr<analog_filter_lp> sptr;
92  bool bypass,
93  size_t position_index,
94  const std::string& analog_type,
95  double cutoff,
96  double rolloff)
97  : analog_filter_base(type, bypass, position_index, analog_type)
98  , _cutoff(cutoff)
99  , _rolloff(rolloff)
100  {
101  // NOP
102  }
103
105  {
106  return _cutoff;
107  }
108
110  {
111  return _rolloff;
112  }
113
114  UHD_INLINE void set_cutoff(const double cutoff)
115  {
116  _cutoff = cutoff;
117  }
118
119  virtual std::string to_pp_string();
120 };
121
122 template <typename tap_t> class UHD_API digital_filter_base : public filter_info_base
123 {
124 protected:
125  double _rate;
126  uint32_t _interpolation;
127  uint32_t _decimation;
129  uint32_t _max_num_taps;
130  std::vector<tap_t> _taps;
131
132 public:
133  typedef boost::shared_ptr<digital_filter_base> sptr;
135  bool bypass,
136  size_t position_index,
137  double rate,
138  size_t interpolation,
139  size_t decimation,
140  double tap_full_scale,
141  size_t max_num_taps,
142  const std::vector<tap_t>& taps)
143  : filter_info_base(type, bypass, position_index)
144  , _rate(rate)
145  , _interpolation(interpolation)
146  , _decimation(decimation)
147  , _tap_full_scale(tap_full_scale)
148  , _max_num_taps(max_num_taps)
149  , _taps(taps)
150  {
151  // NOP
152  }
153
155  {
156  return (_bypass ? _rate : (_rate / _decimation * _interpolation));
157  }
158
160  {
161  return _rate;
162  }
163
165  {
166  return _interpolation;
167  }
168
170  {
171  return _decimation;
172  }
173
175  {
176  return _tap_full_scale;
177  }
178
179  UHD_INLINE std::vector<tap_t>& get_taps()
180  {
181  return _taps;
182  }
183
184  virtual std::string to_pp_string()
185  {
186  std::ostringstream os;
187  os << filter_info_base::to_pp_string() << "\t[digital_filter_base]" << std::endl
188  << "\tinput rate: " << _rate << std::endl
189  << "\tinterpolation: " << _interpolation << std::endl
190  << "\tdecimation: " << _decimation << std::endl
191  << "\tfull-scale: " << _tap_full_scale << std::endl
192  << "\tmax num taps: " << _max_num_taps << std::endl
193  << "\ttaps: " << std::endl;
194
195  os << "\t\t";
196  for (size_t i = 0; i < _taps.size(); i++) {
197  os << "(tap " << i << ": " << _taps[i] << ")";
198  if (((i % 10) == 0) && (i != 0)) {
199  os << std::endl << "\t\t";
200  }
201  }
202  os << std::endl;
203  return std::string(os.str());
204  }
205 };
206
207 template <typename tap_t>
209 {
210 public:
211  typedef boost::shared_ptr<digital_filter_fir<tap_t> > sptr;
212
214  bool bypass,
215  size_t position_index,
216  double rate,
217  size_t interpolation,
218  size_t decimation,
219  size_t tap_bit_width,
220  size_t max_num_taps,
221  const std::vector<tap_t>& taps)
222  : digital_filter_base<tap_t>(type,
223  bypass,
224  position_index,
225  rate,
226  interpolation,
227  decimation,
228  tap_bit_width,
229  max_num_taps,
230  taps)
231  {
232  // NOP
233  }
234
235  void set_taps(const std::vector<tap_t>& taps)
236  {
237  std::size_t num_taps = taps.size();
238  if (num_taps < this->_max_num_taps) {
239  UHD_LOGGER_WARNING("FILTERS") << "digital_filter_fir::set_taps not enough "
240  "coefficients. Appending zeros";
241  std::vector<tap_t> coeffs;
242  for (size_t i = 0; i < this->_max_num_taps; i++) {
243  if (i < num_taps) {
244  coeffs.push_back(taps[i]);
245  } else {
246  coeffs.push_back(0);
247  }
248  }
249  this->_taps = coeffs;
250  } else {
251  this->_taps = taps;
252  }
253  }
254 };
255
256 } // namespace uhd
257
258 #endif /* INCLUDED_UHD_TYPES_FILTERS_HPP */
boost::shared_ptr< digital_filter_fir< tap_t > > sptr
Definition: filters.hpp:211
filter_type _type
Definition: filters.hpp:54
Definition: filters.hpp:208
UHD_INLINE std::vector< tap_t > & get_taps()
Definition: filters.hpp:179
std::vector< tap_t > _taps
Definition: filters.hpp:130
boost::shared_ptr< analog_filter_base > sptr
Definition: filters.hpp:66
Definition: filters.hpp:184
UHD_INLINE const std::string & get_analog_type()
Definition: filters.hpp:76
UHD_INLINE double get_decimation()
Definition: filters.hpp:169
UHD_INLINE double get_interpolation()
Definition: filters.hpp:164
Definition: filters.hpp:127
virtual UHD_INLINE bool is_bypassed()
Definition: filters.hpp:36
tap_t _tap_full_scale
Definition: filters.hpp:128
Definition: filters.hpp:122
bool _bypass
Definition: filters.hpp:55
Definition: filters.hpp:61
Definition: filters.hpp:114
Definition: build_info.hpp:13
void set_taps(const std::vector< tap_t > &taps)
Definition: filters.hpp:235
digital_filter_base(filter_type type, bool bypass, size_t position_index, double rate, size_t interpolation, size_t decimation, double tap_full_scale, size_t max_num_taps, const std::vector< tap_t > &taps)
Definition: filters.hpp:134
Definition: filters.hpp:24
UHD_INLINE double get_rolloff()
Definition: filters.hpp:109
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:27
UHD_INLINE double get_input_rate()
Definition: filters.hpp:159
Definition: filters.hpp:84
UHD_INLINE double get_tap_full_scale()
Definition: filters.hpp:174
analog_filter_base(filter_type type, bool bypass, size_t position_index, const std::string &analog_type)
Definition: filters.hpp:67
virtual ~filter_info_base()
Definition: filters.hpp:46
#define UHD_INLINE
Definition: config.h:53
digital_filter_fir(filter_info_base::filter_type type, bool bypass, size_t position_index, double rate, size_t interpolation, size_t decimation, size_t tap_bit_width, size_t max_num_taps, const std::vector< tap_t > &taps)
Definition: filters.hpp:213
analog_filter_lp(filter_type type, bool bypass, size_t position_index, const std::string &analog_type, double cutoff, double rolloff)
Definition: filters.hpp:91
size_t _position_index
Definition: filters.hpp:56
Definition: config.h:68
filter_type
Definition: filters.hpp:28
Definition: filters.hpp:30
boost::shared_ptr< analog_filter_lp > sptr
Definition: filters.hpp:90
Definition: filters.hpp:126
UHD_INLINE double get_cutoff()
Definition: filters.hpp:104
boost::shared_ptr< digital_filter_base > sptr
Definition: filters.hpp:133
UHD_INLINE double get_output_rate()
Definition: filters.hpp:154
Definition: filters.hpp:129
double _rate
Definition: filters.hpp:125
#define UHD_LOGGER_WARNING(component)
Definition: log.hpp:238
UHD_INLINE filter_type get_type()
Definition: filters.hpp:41
