Generation 3 USRP Build Documentation
Dependencies and Requirements
Dependencies
The USRP FPGA build system requires a UNIX-like environment with the following dependencies
What FPGA does my USRP have?
  • USRP B200: Spartan 6 XC6SLX75
  • USRP B200mini: Spartan 6 XC6SLX75
  • USRP B210: Spartan 6 XC6SLX150
  • USRP X300: Kintex 7 XC7K325T (7 Series)
  • USRP X310: Kintex 7 XC7K410T (7 Series)
  • USRP E310: Zynq-7000 XC7Z020 (7 Series)
  • USRP E320: Zynq-7000 XC7Z045 (7 Series)
  • USRP N300: Zynq-7100 XC7Z035 (7 Series)
  • USRP N310/N320: Zynq-7100 XC7Z100 (7 Series)
Requirements
Build Environment Setup
Download and Install Xilinx Tools
Download and install Xilinx Vivado or Xilinx ISE based on the target USRP.
  • The recommended installation directory is /opt/Xilinx/ for Linux and C:\Xilinx in Windows
  • Please check the Xilinx Requirements document above for the FPGA technology used by your USRP device.
  • You may need to acquire a synthesis and implementation license from Xilinx to build some USRP designs.
  • You may need to acquire a simulation license from Xilinx to run some testbenches
Download and Install ModelSim (Optional)
Download and install Mentor ModelSim using the link above.
  • The recommended installation directory is /opt/mentor/modelsim for Linux and C:\mentor\modelsim in Windows
  • Supported versions are PE, DE, SE, DE-64 and SE-64
  • You may need to acquire a license from Mentor Graphics to run ModelSim
Setting up build dependencies on Ubuntu
sudo apt-get install python bash build-essential doxygen
Setting up build dependencies on Fedora
sudo yum -y install python bash make doxygen
Setting up build dependencies on Windows (using Cygwin)
NOTE: Windows is only supported with Vivado. The build system does not support Xilinx ISE in Windows.
Download the latest version on Cygwin (64-bit is preferred on a 64-bit OS) and install it using these instructions. The following additional packages are also required and can be selected in the GUI installer
python patch patchutils bash make doxygen
Build Instructions (Xilinx Vivado only)
Makefile based Builder
  • Navigate to usrp3/top/{project} where project is:
    • x300: For USRP X300 and USRP X310
    • e300: For USRP E310
    • e320: For USRP E320
    • n3xx: For USRP N300/N310/N320
  • To add vivado to the PATH and to setup up the Ettus Xilinx build environment run
    • source setupenv.sh (If Vivado is installed in the default path /opt/Xilinx/Vivado) OR
    • source setupenv.sh --vivado-path=<VIVADO_PATH> (where VIVADO_PATH is a non-default installation path)
  • To build a binary configuration bitstream run make <target> where the target is specific to each product. To get a list of supported targets run make help.
  • The build output will be specific to the product and will be located in the usrp3/top/{project}/build directory. Run make help for more information.
Environment Utilies
The build environment also defines many ease-of-use utilites. Please use the Vivado Utility Reference page for a list and usage information
Build Instructions (Xilinx ISE only)
  • To add xtclsh to the PATH and to setup up the Xilinx build environment run
    • source <install_dir>/Xilinx/14.7/ISE_DS/settings64.sh (64-bit platform)
    • source <install_dir>/Xilinx/14.7/ISE_DS/settings32.sh (32-bit platform)
    • b200: For USRP B200 and USRP B210
    • b200mini: For USRP B200mini
Targets and Outputs
B2x0 Targets and Outputs
Supported Targets
  • B200: Builds the USRP B200 design.
  • B210: Builds the USRP B210 design.
Outputs
  • build/usrp_<product>_fpga.bit : Configuration bitstream with header
  • build/usrp_<product>_fpga.bin : Configuration bitstream without header
  • build/usrp_<product>_fpga.syr : Xilinx system report
  • build/usrp_<product>_fpga.twr : Xilinx timing report
X3x0 Targets and Outputs
Supported Targets
  • X310_1G: USRP X310. 1GigE on both SFP+ ports. DRAM TX FIFO (experimental!).
  • X300_1G: USRP X300. 1GigE on both SFP+ ports. DRAM TX FIFO (experimental!).
  • X310_HG: USRP X310. 1GigE on SFP+ Port0, 10Gig on SFP+ Port1. DRAM TX FIFO (experimental!).
  • X300_HG: USRP X300. 1GigE on SFP+ Port0, 10Gig on SFP+ Port1. DRAM TX FIFO (experimental!).
  • X310_XG: USRP X310. 10GigE on both SFP+ ports. DRAM TX FIFO (experimental!).
  • X300_XG: USRP X300. 10GigE on both SFP+ ports. DRAM TX FIFO (experimental!).
  • X310_HA: USRP X310. 1GigE on SFP+ Port0, Aurora on SFP+ Port1. DRAM TX FIFO.
  • X300_HA: USRP X300. 1GigE on SFP+ Port0, Aurora on SFP+ Port1. DRAM TX FIFO.
  • X310_XA: USRP X310. 10GigE on SFP+ Port0, Aurora on SFP+ Port1. DRAM TX FIFO.
  • X300_XA: USRP X300. 10GigE on SFP+ Port0, Aurora on SFP+ Port1. DRAM TX FIFO.
  • X310_RFNOC_HG: USRP X310. 1GigE on SFP+ Port0, 10Gig on SFP+ Port1. RFNoC CEs enabled
  • X300_RFNOC_HG: USRP X300. 1GigE on SFP+ Port0, 10Gig on SFP+ Port1. RFNoC CEs enabled
  • X310_RFNOC_XG: USRP X310. 10GigE on both SFP+ ports. RFNoC CEs enabled.
  • X300_RFNOC_XG: USRP X300. 10GigE on both SFP+ ports. RFNoC CEs enabled.
  • X310_RFNOC_HLS_HG: USRP X310. 1GigE on SFP+ Port0, 10Gig on SFP+ Port1. RFNoC CEs enabled + Vivado HLS
  • X300_RFNOC_HLS_HG: USRP X300. 1GigE on SFP+ Port0, 10Gig on SFP+ Port1. RFNoC CEs enabled + Vivado HLS
Outputs
  • build/usrp_<product>_fpga_<image_type>.bit : Configuration bitstream with header
  • build/usrp_<product>_fpga_<image_type>.bin : Configuration bitstream without header
  • build/usrp_<product>_fpga_<image_type>.lvbitx : Configuration bitstream for PCIe (NI-RIO)
  • build/usrp_<product>_fpga_<image_type>.rpt : System, utilization and timing summary report
E310 Targets and Outputs
Supported Targets
  • E310: Builds the USRP E310 design.
Outputs
  • build/usrp_<product>_fpga.rpt : System, utilization and timing summary report
E320 Targets and Outputs
Supported Targets
  • E320_1G: 1GigE on SFP+ Port.
  • E320_XG: 10GigE on SFP+ Port.
  • E320_AA: Aurora on SFP+ Port.
  • E320_RFNOC_1G: 1GigE on SFP+ Port. RFNOC CEs enabled.
  • E320_RFNOC_XG: 10GigE on SFP+ Port. RFNOC CEs enabled.
  • E320_RFNOC_AA: Aurora on SFP+ Port. RFNOC CEs enabled.
Outputs
N3XX Targets and Outputs
Supported Targets
The targets depend on the actual hardware the FPGA image is being deployed to. Unlike the X300 Series, the daughterboards are an integral part of the module and not meant to be removed. Therefore, the target is specific to the combination of motherboard and daughterboards.
  • N300_AA: Aurora on both SFP+ ports
  • N300_HA: 1GigE on SFP0, Aurora on SFP1
  • N300_HG: 1GigE on SFP0, 10GigE on SFP1
  • N300_WX: White Rabbing on SFP0, 10GigE on SFP1
  • N300_XA: 10GigE on SFP0, Aurora on SFP1
  • N300_XG: 10GigE on both SFP+ ports
  • N310_AA: Aurora on both SFP+ ports
  • N310_HA: 1GigE on SFP0, Aurora on SFP1
  • N310_HG: 1GigE on SFP0, 10GigE on SFP1
  • N310_WX: White Rabbing on SFP0, 10GigE on SFP1
  • N310_XA: 10GigE on SFP0, Aurora on SFP1
  • N310_XG: 10GigE on both SFP+ ports
  • N320_AQ: 10GigE on both SFP+ ports, Aurora on QSFP+ ports
  • N320_HG: 1GigE on SFP0, 10GigE on SFP1
  • N320_XG: 10GigE on both SFP+ ports
  • N320_XQ: White Rabbit on SFP0, 10 GigE on QSFP0 and QSFP1
For the N320 targets see also the N320 manual page on the UHD manual.
All targets also support an RFNOC version (e.g. N300_RFNOC_XG), which enables custom selection of RFNoC blocks.
Outputs
Additional Build Options
It is possible to make a target and specific additional options in the form VAR=VALUE in the command. For example: make B210 PROJECT_ONLY=1
Here are the supported options:
  • PROJECT_ONLY=1 : Only create a Xilinx project for the specified target(s). Useful for use with the ISE GUI. (NOTE: this option is only valid for Xilinx ISE)
  • EXPORT_ONLY=1 : Export build targets from a GUI build to the build directory. Requires the project in build-*_* to be built. (NOTE: this option is only valid for Xilinx ISE)
  • GUI=1 : Run the Vivado build in GUI mode instead of batch mode. After the build is complete, Vivado provides an option to save the fully configured project for customization (NOTE: this option is only valid for Xilinx Vivado)
