Version: 3.15.0.HEAD-0-g6563c537
All
Classes
Namespaces
Files
Functions
Variables
Typedefs
Enumerations
Enumerator
Macros
Pages
config.hpp
1
2
// Copyright 2010-2011,2014-2016 Ettus Research LLC
3
// Copyright 2018 Ettus Research, a National Instruments Company
4
5
// SPDX-License-Identifier: GPL-3.0-or-later
6
7
8
#ifndef INCLUDED_UHD_CONFIG_HPP
9
#define INCLUDED_UHD_CONFIG_HPP
10
11
#include <boost/config.hpp>
12
#include <boost/version.hpp>
13
14
#ifdef BOOST_MSVC
15
// suppress warnings
16
//# pragma warning(push)
//# pragma warning(disable: 4511) // copy constructor can't not be generated
18
//# pragma warning(disable: 4512) // assignment operator can't not be generated
19
//# pragma warning(disable: 4100) // unreferenced formal parameter
//# pragma warning(disable: 4996) // <symbol> was declared deprecated
21
# pragma warning(disable : 4355) // 'this' : used in base member initializer list
22
//# pragma warning(disable: 4706) // assignment within conditional expression
23
# pragma warning(disable : 4251) // class 'A<T>' needs to have dll-interface to be used
// by clients of class 'B'
25
//# pragma warning(disable: 4127) // conditional expression is constant
26
//# pragma warning(disable: 4290) // C++ exception specification ignored except to ...
27
//# pragma warning(disable: 4180) // qualifier applied to function type has no meaning;
28
// ignored
29
# pragma warning(disable : 4275) // non dll-interface class ... used as base for
30
// dll-interface class ...
31
//# pragma warning(disable: 4267) // 'var' : conversion from 'size_t' to 'type', possible
32
// loss of data # pragma warning(disable: 4511) // 'class' : copy constructor could not be
33
// generated
34
# pragma warning(disable : 4250) // 'class' : inherits 'method' via dominance
35
# pragma warning( \
36
disable : 4200) // nonstandard extension used : zero-sized array in struct/union
37
38
// define logical operators
39
# include <ciso646>
40
41
// define ssize_t
42
# include <cstddef>
43
typedef
ptrdiff_t ssize_t;
44
45
#endif // BOOST_MSVC
46
47
// define cross platform attribute macros
48
#if defined(BOOST_MSVC)
49
# define UHD_EXPORT __declspec(dllexport)
50
# define UHD_IMPORT __declspec(dllimport)
51
# define UHD_INLINE __forceinline
52
# define UHD_FORCE_INLINE __forceinline
53
# define UHD_DEPRECATED __declspec(deprecated)
54
# define UHD_ALIGNED(x) __declspec(align(x))
55
# define UHD_UNUSED(x) x
56
#elif defined(__MINGW32__)
57
58
59
# define UHD_INLINE inline
60
# define UHD_FORCE_INLINE inline
61
62
63
# define UHD_UNUSED(x) x __attribute__((unused))
64
#elif defined(__GNUG__) && __GNUG__ >= 4
65
# define UHD_EXPORT __attribute__((visibility("default")))
66
# define UHD_IMPORT __attribute__((visibility("default")))
67
# define UHD_INLINE inline __attribute__((always_inline))
68
# define UHD_FORCE_INLINE inline __attribute__((always_inline))
69
# define UHD_DEPRECATED __attribute__((deprecated))
70
# define UHD_ALIGNED(x) __attribute__((aligned(x)))
71
72
#elif defined(__clang__)
73
74
75
76
77
78
79
80
#else
81
# define UHD_EXPORT
82
# define UHD_IMPORT
83
84
85
86
87
88
#endif
89
90
// Define API declaration macro
91
#ifdef UHD_STATIC_LIB
92
# define UHD_API
93
#else
94
# ifdef UHD_DLL_EXPORTS
95
# define UHD_API UHD_EXPORT
96
# else
97
# define UHD_API UHD_IMPORT
98
# endif // UHD_DLL_EXPORTS
99
#endif // UHD_STATIC_LIB
100
101
#ifdef UHD_RFNOC_ENABLED
102
# define UHD_RFNOC_API UHD_API
103
#else
104
105
#endif // UHD_RFNOC_ENABLED
106
107
108
// Platform defines for conditional parts of headers:
109
// Taken from boost/config/select_platform_config.hpp,
110
// however, we define macros, not strings for platforms.
111
#if (defined(linux) || defined(__linux) || defined(__linux__) || defined(__GLIBC__)) \
112
&& !defined(_CRAYC) && !defined(__FreeBSD_kernel__) && !defined(__GNU__)
113
# define UHD_PLATFORM_LINUX
114
#elif defined(_WIN32) || defined(__WIN32__) || defined(WIN32)
115
# define UHD_PLATFORM_WIN32
116
#elif defined(macintosh) || defined(__APPLE__) || defined(__APPLE_CC__)
117
# define UHD_PLATFORM_MACOS
118
#elif defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__) \
119
120
# define UHD_PLATFORM_BSD
121
#endif
122
123
// Define 'stringize' preprocessor macros. The stringize macro, XSTR, takes
124
// variable arguments so that it can deal with strings that contain commas.
125
// There are two different versions because MSVC handles this syntax a bit
126
// differently than other compilers.
127
128
# define XSTR(x, ...) # x
129
#else
130
# define XSTR(x...) # x
131
#endif
132
133
#define STR(x) XSTR(x)
134
135
#endif
/* INCLUDED_UHD_CONFIG_HPP */
include
uhd
config.hpp
Generated by
1.8.13
