Internal GPSDO Application Notes (USRP-B2x0 Models)
This application note describes the use of integrated GPS-disciplined oscillators with Ettus Research USRP devices.
Specifications
  • 10MHz ADEV: 5e-11 over >24h
  • 1PPS RMS jitter: <50ns 1-sigma
  • Holdover: <20us over 3h
Phase noise:
Offset Phase Noise Power
1Hz -65dBc/Hz
10Hz > -102dBc/Hz
100Hz -132dBc/Hz
1kHz -148dBc/Hz
10kHz -152dBc/Hz
100kHz < -155dBc/Hz
Antenna Types:
Installation Instructions
To install the GPSDO, you must insert it into the slot on the board near the 10 MHz Reference SMA. Keep in mind that the two sides of the GPSDO have a different number of pins. When inserting the GPSDO, make sure to press down firmly and evenly. When turning on the USRP B2X0 device, a green LED should illuminate on the GPSDO. This signifies that the unit has successfully been placed.
By default, if a GPSDO is detected at startup, the USRP will be configured to use it as a frequency and time reference. The internal VITA timestamp will be initialized to the GPS time, and the internal oscillator will be phase-locked to the 10MHz GPSDO reference. If the GPSDO is not locked to satellites, the VITA time will not be initialized.
Using a power supply with the B2x0 and GPSDO
The GPSDOs for the B2x0 draw extra power, and when running off of bus power only, brownouts are possible (although not guaranteed to happen). It is recommended to use a wall power connector when using a B2x0 in conjunction with a GPSDO.
