block_id.hpp
1 // Copyright 2014 Ettus Research LLC
2 // Copyright 2018 Ettus Research, a National Instruments Company
5 //
6
7 #ifndef INCLUDED_UHD_TYPES_BLOCK_ID_HPP
8 #define INCLUDED_UHD_TYPES_BLOCK_ID_HPP
9
10 #include <uhd/config.hpp>
11 #include <stdint.h>
12 #include <boost/shared_ptr.hpp>
13 #include <iostream>
14 #include <string>
15
16 namespace uhd {
17 struct fs_path;
18
19 namespace rfnoc {
40 {
41 public:
42  block_id_t();
43  block_id_t(const std::string& block_str);
47  block_id_t(const size_t device_no,
48  const std::string& block_name,
49  const size_t block_ctr = 0);
50
52  std::string to_string() const;
53
55  //
56  // Note: This only applies to the block *name*, not the entire block ID.
57  // Examples:
58  // * is_valid_blockname("FFT") will return true.
59  // * is_valid_blockname("FIR_Filter") will return false, because an underscore
60  // is not allowed in a block name.
61  //
62  // Internally, this matches the string with uhd::rfnoc::VALID_BLOCKNAME_REGEX.
63  static bool is_valid_blockname(const std::string& block_name);
64
66  //
67  // Note: This does necessary require a complete complete ID. If this returns
68  // true, then it is a valid input for block_id_t::match().
69  //
70  // Examples:
71  // * is_valid_block_id("FFT") will return true.
72  // * is_valid_block_id("0/Filter_1") will return true.
73  // * is_valid_block_id("0/Filter_Foo") will return false.
74  //
75  // Internally, this matches the string with uhd::rfnoc::VALID_BLOCKID_REGEX.
76  static bool is_valid_block_id(const std::string& block_id);
77
79  //
80  // A match is a less strict version of equality.
81  // Less specific block IDs will match more specific ones,
82  // e.g. "FFT" will match "0/FFT_1", "1/FFT_2", etc.
83  // "FFT_1" will only match the former, etc.
84  bool match(const std::string& block_str);
85
86  // Getters
87
89  std::string get() const
90  {
91  return to_string();
92  };
93
95  std::string get_local() const;
96
98  uhd::fs_path get_tree_root() const;
99
101  size_t get_device_no() const
102  {
103  return _device_no;
104  };
105
107  size_t get_block_count() const
108  {
109  return _block_ctr;
110  };
111
113  std::string get_block_name() const
114  {
115  return _block_name;
116  };
117
118  // Setters
119
121  // Returns true if successful (i.e. if string valid)
122  bool set(const std::string& new_name);
123
125  // and set_block_count() one after another, only if \p block_name is invalid, stops
126  // and returns false before chaning anything
127  bool set(const size_t device_no,
128  const std::string& block_name,
129  const size_t block_ctr = 0);
130
132  void set_device_no(size_t device_no)
133  {
134  _device_no = device_no;
135  };
136
138  bool set_block_name(const std::string& block_name);
139
141  void set_block_count(size_t count)
142  {
143  _block_ctr = count;
144  };
145
146  // Overloaded operators
147
149  block_id_t operator=(const std::string& new_name)
150  {
151  set(new_name);
152  return *this;
153  }
154
155  bool operator==(const block_id_t& block_id) const
156  {
157  return (_device_no == block_id.get_device_no())
158  and (_block_name == block_id.get_block_name())
159  and (_block_ctr == block_id.get_block_count());
160  }
161
162  bool operator!=(const block_id_t& block_id) const
163  {
164  return not(*this == block_id);
165  }
166
167  bool operator<(const block_id_t& block_id) const
168  {
169  return (_device_no < block_id.get_device_no()
170  or (_device_no == block_id.get_device_no()
171  and _block_name < block_id.get_block_name())
172  or (_device_no == block_id.get_device_no()
173  and _block_name == block_id.get_block_name()
174  and _block_ctr < block_id.get_block_count()));
175  }
176
177  bool operator>(const block_id_t& block_id) const
178  {
179  return (_device_no > block_id.get_device_no()
180  or (_device_no == block_id.get_device_no()
181  and _block_name > block_id.get_block_name())
182  or (_device_no == block_id.get_device_no()
183  and _block_name == block_id.get_block_name()
184  and _block_ctr > block_id.get_block_count()));
185  }
186
188  bool operator==(const std::string& block_id_str) const
189  {
190  return get() == block_id_str;
191  }
192
194  bool operator==(const char* block_id_str) const
195  {
196  std::string comp = std::string(block_id_str);
197  return *this == comp;
198  }
199
201  operator std::string() const
202  {
203  return to_string();
204  }
205
208  {
209  _block_ctr++;
210  return *this;
211  }
212
215  {
216  _block_ctr++;
217  return *this;
218  }
219
220 private:
221  size_t _device_no;
222  std::string _block_name;
223  size_t _block_ctr;
224 };
225
227 inline std::ostream& operator<<(std::ostream& out, block_id_t block_id)
228 {
229  out << block_id.to_string();
230  return out;
231 }
232
233 } // namespace rfnoc
234 } // namespace uhd
235
236 #endif /* INCLUDED_UHD_TYPES_BLOCK_ID_HPP */
Set the block count.
Definition: block_id.hpp:141
bool operator<(const block_id_t &block_id) const
Definition: block_id.hpp:167
Return device number.
Definition: block_id.hpp:101
Return a string like this: "0/FFT_1" (includes all components, if set)
bool operator==(const char *block_id_str) const
Check if a string matches the entire block ID (not like match())
Definition: block_id.hpp:194
Definition: property_tree.hpp:199
block_id_t operator++()
Increment the block count ("FFT_1" -> "FFT_2")
Definition: block_id.hpp:207
bool operator==(const std::string &block_id_str) const
Definition: block_id.hpp:188
bool operator>(const block_id_t &block_id) const
Definition: block_id.hpp:177
bool operator==(const block_id_t &block_id) const
Definition: block_id.hpp:155
Definition: block_id.hpp:39
Definition: build_info.hpp:13
std::ostream & operator<<(std::ostream &out, block_id_t block_id)
Shortcut for << block_id.to_string()
Definition: block_id.hpp:227
bool operator!=(const block_id_t &block_id) const
Definition: block_id.hpp:162
Return block count.
Definition: block_id.hpp:107
Set the device number.
Definition: block_id.hpp:132
#define UHD_RFNOC_API
Definition: config.hpp:117
block_id_t operator=(const std::string &new_name)
Assignment: Works like set(std::string)
Definition: block_id.hpp:149
block_id_t operator++(int)
Definition: block_id.hpp:214
Return block name.
Definition: block_id.hpp:113
