constants.hpp
4 //
6 //
7
8 #ifndef INCLUDED_LIBUHD_RFNOC_CONSTANTS_HPP
9 #define INCLUDED_LIBUHD_RFNOC_CONSTANTS_HPP
10
11 #include <uhd/types/dict.hpp>
12 #include <stdint.h>
13 #include <boost/assign/list_of.hpp>
14 #include <string>
15
16 namespace uhd { namespace rfnoc {
18 // All these configure the XML reader
20 static const std::string XML_DEFAULT_PATH = "share/uhd/rfnoc";
22 static const std::string XML_PATH_ENV = "UHD_RFNOC_DIR";
23
25 static const std::string DEFAULT_BLOCK_NAME = "Block";
26 static const uint64_t DEFAULT_NOC_ID = 0xFFFFFFFFFFFFFFFF;
27 static const size_t NOC_SHELL_COMPAT_MAJOR = 6;
28 static const size_t NOC_SHELL_COMPAT_MINOR = 0;
29
30 static const size_t MAX_PACKET_SIZE = 8000; // bytes
31 static const size_t DEFAULT_PACKET_SIZE = 1456; // bytes
32
33 // One line in FPGA is 64 Bits
34 static const size_t BYTES_PER_LINE = 8;
35
37 static const size_t DEFAULT_FC_XBAR_RESPONSE_FREQ = 8;
39 static const size_t DEFAULT_FC_RX_RESPONSE_FREQ = 64; // ACKs per flow control window
41 static const size_t DEFAULT_FC_TX_RESPONSE_FREQ = 8; // ACKs per flow control window
43 // Why not 100% full? Because we need to have some headroom to account for the inaccuracy
44 // when computing the window size. We compute the flow control window based on the frame
45 // size but the buffer can have overhead due to things like UDP headers, page alignment,
46 // housekeeping info, etc. This number has to be transport agnostic so 20% of headroom is
47 // safe.
48 static const double DEFAULT_FC_RX_SW_BUFF_FULL_FACTOR = 0.80;
49
50 // Common settings registers.
51 static const uint32_t SR_FLOW_CTRL_BYTES_PER_ACK = 1;
52 static const uint32_t SR_FLOW_CTRL_WINDOW_SIZE = 2;
53 static const uint32_t SR_FLOW_CTRL_EN = 3;
54 static const uint32_t SR_ERROR_POLICY = 4;
55 static const uint32_t SR_BLOCK_SID = 5; // TODO rename to SRC_SID
56 static const uint32_t SR_NEXT_DST_SID = 6;
57 static const uint32_t SR_RESP_IN_DST_SID = 7;
58 static const uint32_t SR_RESP_OUT_DST_SID = 8;
59 static const uint32_t SR_FLOW_CTRL_PKT_LIMIT = 9;
60
61 static const uint32_t SR_READBACK_ADDR = 124;
62 static const uint32_t SR_READBACK = 127;
63
64 static const uint32_t SR_CLEAR_RX_FC = 125;
65 static const uint32_t SR_CLEAR_TX_FC = 126;
66
71  SR_READBACK_REG_FIFOSIZE = 2, // fifo size
76 };
77
78 // AXI stream configuration bus (output master bus of axi wrapper) registers
79 static const uint32_t AXI_WRAPPER_BASE = 128;
80 static const uint32_t AXIS_CONFIG_BUS =
81  AXI_WRAPPER_BASE + 1; // tdata with tvalid asserted
82 static const uint32_t AXIS_CONFIG_BUS_TLAST =
83  AXI_WRAPPER_BASE + 2; // tdata with tvalid & tlast asserted
84
85 static const size_t CMD_FIFO_SIZE = 256; // Lines == multiples of 8 bytes
86 static const size_t MAX_CMD_PKT_SIZE = 3; // Lines == multiples of 8 bytes
87
88 // Named settings registers
89 static const uhd::dict<std::string, uint32_t> DEFAULT_NAMED_SR =
90  boost::assign::map_list_of("AXIS_CONFIG_BUS", AXIS_CONFIG_BUS)(
91  "AXIS_CONFIG_BUS_TLAST", AXIS_CONFIG_BUS_TLAST);
92
93 // Blocks
94 static const size_t MAX_NUM_BLOCKS = 16;
95
96 // Block ports
97 static const size_t ANY_PORT = size_t(~0);
98 static const size_t MAX_NUM_PORTS = 16;
99
100 // Regular expressions
101 static const std::string VALID_BLOCKNAME_REGEX = "[A-Za-z][A-Za-z0-9]*";
102 static const std::string VALID_BLOCKID_REGEX =
103  "(?:(\\d+)(?:/))?([A-Za-z][A-Za-z0-9]*)(?:(?:_)(\\d\\d?))?";
104
105 }} /* namespace uhd::rfnoc */
106
107 #endif /* INCLUDED_LIBUHD_RFNOC_CONSTANTS_HPP */
Definition: constants.hpp:70
Definition: constants.hpp:69
Definition: constants.hpp:71
Definition: dict.hpp:21
settingsbus_reg_t
Settings register readback.
Definition: constants.hpp:68
Definition: build_info.hpp:13
Definition: constants.hpp:74
Definition: constants.hpp:75
Definition: constants.hpp:73
Definition: constants.hpp:72
