node_ctrl_base.hpp
4 // Copyright 2019 Ettus Research, a National Instruments Brand
5 //
6 // SPDX-License-Identifier: GPL-3.0-or-later
7 //
8
9 #ifndef INCLUDED_LIBUHD_NODE_CTRL_BASE_HPP
10 #define INCLUDED_LIBUHD_NODE_CTRL_BASE_HPP
11
12 #include <uhd/rfnoc/constants.hpp>
14 #include <uhd/utils/log.hpp>
16 #include <stdint.h>
17 #include <boost/enable_shared_from_this.hpp>
18 #include <boost/function.hpp>
19 #include <boost/shared_ptr.hpp>
20 #include <boost/utility.hpp>
21 #include <map>
22 #include <set>
23
24 namespace uhd { namespace usrp {
25 // Forward declaration for friend clause
26 class device3_impl;
27 }} // namespace uhd::usrp
28
29 namespace uhd { namespace rfnoc {
30
31 #define UHD_RFNOC_BLOCK_TRACE() UHD_LOGGER_TRACE("RFNOC")
32
38  public boost::enable_shared_from_this<node_ctrl_base>
39 {
40 public:
41  /***********************************************************************
42  * Types
43  **********************************************************************/
44  typedef boost::shared_ptr<node_ctrl_base> sptr;
45  typedef boost::weak_ptr<node_ctrl_base> wptr;
46  typedef std::map<size_t, wptr> node_map_t;
47  typedef std::pair<size_t, wptr> node_map_pair_t;
48  typedef boost::function<void(void)> graph_update_cb_t;
49
50  /***********************************************************************
51  * Node control
52  **********************************************************************/
54  virtual std::string unique_id() const;
55
56  /***********************************************************************
57  * Connections
58  **********************************************************************/
61  virtual void clear();
62
63  node_map_t list_downstream_nodes()
64  {
65  return _downstream_nodes;
66  };
67  node_map_t list_upstream_nodes()
68  {
69  return _upstream_nodes;
70  };
71
74  void disconnect();
75
78  void disconnect_output_port(const size_t output_port);
79
82  void disconnect_input_port(const size_t input_port);
83
84  // TODO we need a more atomic connect procedure, this is too error-prone.
85
90  void set_downstream_port(const size_t this_port, const size_t remote_port);
91
96  size_t get_downstream_port(const size_t this_port);
97
102  void set_upstream_port(const size_t this_port, const size_t remote_port);
103
108  size_t get_upstream_port(const size_t this_port);
109
125  template <typename T>
126  UHD_INLINE std::vector<boost::shared_ptr<T> > find_downstream_node(
127  bool active_only = false)
128  {
129  return _find_child_node<T, true>(active_only);
130  }
131
134  template <typename T>
135  UHD_INLINE std::vector<boost::shared_ptr<T> > find_upstream_node(
136  bool active_only = false)
137  {
138  return _find_child_node<T, false>(active_only);
139  }
140
153  template <typename T, typename value_type>
155  boost::function<value_type(boost::shared_ptr<T> node, size_t port)> get_property,
156  value_type null_value,
157  const std::set<boost::shared_ptr<T> >& exclude_nodes =
158  std::set<boost::shared_ptr<T> >())
159  {
160  return _find_unique_property<T, value_type, true>(
161  get_property, null_value, exclude_nodes);
162  }
163
166  template <typename T, typename value_type>
168  boost::function<value_type(boost::shared_ptr<T> node, size_t port)> get_property,
169  value_type null_value,
170  const std::set<boost::shared_ptr<T> >& exclude_nodes =
171  std::set<boost::shared_ptr<T> >())
172  {
173  return _find_unique_property<T, value_type, false>(
174  get_property, null_value, exclude_nodes);
175  }
176
177 protected:
178  /***********************************************************************
179  * Structors
180  **********************************************************************/
181  node_ctrl_base(void) : _num_input_ports(0), _num_output_ports(0) {}
182  virtual ~node_ctrl_base()
183  {
184  disconnect();
185  }
186
187  /***********************************************************************
188  * Protected members
189  **********************************************************************/
190
193
194  // TODO make these private
195
197  node_map_t _upstream_nodes;
198
200  node_map_t _downstream_nodes;
201
205
209
217  std::map<size_t, bool> _rx_streamer_active;
218
226  std::map<size_t, bool> _tx_streamer_active;
227
228  /***********************************************************************
229  * Connections
230  **********************************************************************/
237  virtual void _register_downstream_node(
238  node_ctrl_base::sptr downstream_node, size_t port);
239
246  virtual void _register_upstream_node(node_ctrl_base::sptr upstream_node, size_t port);
247
256  {
257  _graph_update_cb();
258  }
259
260 private:
261  friend class uhd::usrp::device3_impl;
262
271  template <typename T, bool downstream>
272  std::vector<boost::shared_ptr<T> > _find_child_node(bool active_only = false);
273
282  template <typename T, typename value_type, bool downstream>
283  value_type _find_unique_property(
284  boost::function<value_type(boost::shared_ptr<T>, size_t)> get_property,
285  value_type NULL_VALUE,
286  const std::set<boost::shared_ptr<T> >& exclude_nodes);
287
288  void set_graph_update_cb(graph_update_cb_t graph_update_cb)
289  {
290  _graph_update_cb = graph_update_cb;
291  }
292
295  std::map<size_t, size_t> _upstream_ports;
296
299  std::map<size_t, size_t> _downstream_ports;
300
301  graph_update_cb_t _graph_update_cb;
302
303 }; /* class node_ctrl_base */
304
305 }} /* namespace uhd::rfnoc */
306
308
309 #endif /* INCLUDED_LIBUHD_NODE_CTRL_BASE_HPP */
UHD_INLINE value_type find_upstream_unique_property(boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >())
Definition: node_ctrl_base.hpp:167
Definition: node_ctrl_base.hpp:67
Definition: noncopyable.hpp:46
std::pair< size_t, wptr > node_map_pair_t
Definition: node_ctrl_base.hpp:47
Definition: node_ctrl_base.hpp:182
Definition: node_ctrl_base.hpp:63
std::map< size_t, wptr > node_map_t
Definition: node_ctrl_base.hpp:46
Definition: node_ctrl_base.hpp:181
Definition: build_info.hpp:13
uhd::device_addr_t _args
Stores default arguments.
Definition: node_ctrl_base.hpp:192
UHD_INLINE std::vector< boost::shared_ptr< T > > find_upstream_node(bool active_only=false)
Definition: node_ctrl_base.hpp:135
boost::shared_ptr< node_ctrl_base > sptr
Definition: node_ctrl_base.hpp:44
#define UHD_RFNOC_API
Definition: config.hpp:117
#define UHD_INLINE
Definition: config.h:53
List of downstream nodes.
Definition: node_ctrl_base.hpp:200
size_t _num_input_ports
Definition: node_ctrl_base.hpp:204
boost::function< void(void)> graph_update_cb_t
Definition: node_ctrl_base.hpp:48
void update_graph()
Definition: node_ctrl_base.hpp:255
std::map< size_t, bool > _rx_streamer_active
Definition: node_ctrl_base.hpp:217
UHD_INLINE value_type find_downstream_unique_property(boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >())
Definition: node_ctrl_base.hpp:154
std::map< size_t, bool > _tx_streamer_active
Definition: node_ctrl_base.hpp:226
boost::weak_ptr< node_ctrl_base > wptr
Definition: node_ctrl_base.hpp:45
List of upstream nodes.
Definition: node_ctrl_base.hpp:197
size_t _num_output_ports
Definition: node_ctrl_base.hpp:208
UHD_INLINE std::vector< boost::shared_ptr< T > > find_downstream_node(bool active_only=false)
Definition: node_ctrl_base.hpp:126
Definition: node_ctrl_base.hpp:37
