serial.hpp
4 //
6 //
7
8 #ifndef INCLUDED_UHD_TYPES_SERIAL_HPP
9 #define INCLUDED_UHD_TYPES_SERIAL_HPP
10
11 #include <uhd/config.hpp>
12 #include <stdint.h>
13 #include <boost/shared_ptr.hpp>
14 #include <string>
15 #include <vector>
16
17 namespace uhd {
18
22 typedef std::vector<uint8_t> byte_vector_t;
23
37 {
38 public:
39  typedef boost::shared_ptr<i2c_iface> sptr;
40
41  virtual ~i2c_iface(void);
42
44  i2c_iface::sptr eeprom16(void);
45
51  virtual void write_i2c(uint16_t addr, const byte_vector_t& buf) = 0;
52
59  virtual byte_vector_t read_i2c(uint16_t addr, size_t num_bytes) = 0;
60
67  virtual void write_eeprom(uint16_t addr, uint16_t offset, const byte_vector_t& buf);
68
76  virtual byte_vector_t read_eeprom(uint16_t addr, uint16_t offset, size_t num_bytes);
77 };
78
84 {
89  enum edge_t { EDGE_RISE = 'r', EDGE_FALL = 'f' };
90
93
96
99
101  size_t divider;
102
107  spi_config_t(edge_t edge = EDGE_RISE);
108 };
109
116 {
117 public:
118  typedef boost::shared_ptr<spi_iface> sptr;
119
120  virtual ~spi_iface(void);
121
131  virtual uint32_t transact_spi(int which_slave,
132  const spi_config_t& config,
133  uint32_t data,
134  size_t num_bits,
135  bool readback) = 0;
136
145  virtual uint32_t read_spi(
146  int which_slave, const spi_config_t& config, uint32_t data, size_t num_bits);
147
155  virtual void write_spi(
156  int which_slave, const spi_config_t& config, uint32_t data, size_t num_bits);
157 };
158
163 {
164 public:
165  typedef boost::shared_ptr<uart_iface> sptr;
166
167  virtual ~uart_iface(void);
168
173  virtual void write_uart(const std::string& buf) = 0;
174
180  virtual std::string read_uart(double timeout) = 0;
181 };
182
183 } // namespace uhd
184
185 #endif /* INCLUDED_UHD_TYPES_SERIAL_HPP */
size_t divider
Optionally set the SPI clock divider for this transaction.
Definition: serial.hpp:101
Definition: serial.hpp:115
Definition: serial.hpp:36
bool use_custom_divider
Set the clock speed for this transaction.
Definition: serial.hpp:98
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:92
Definition: build_info.hpp:13
Definition: serial.hpp:83
boost::shared_ptr< spi_iface > sptr
Definition: serial.hpp:118
Definition: config.h:68
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:95
Definition: serial.hpp:162
Definition: serial.hpp:165
edge_t
Definition: serial.hpp:89
boost::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:39
Definition: byte_vector.hpp:20
