constants.hpp
1//
2// Copyright 2014 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
11#include <uhd/types/dict.hpp>
12#include <stdint.h>
13#include <boost/assign/list_of.hpp>
14#include <string>
15
16namespace uhd { namespace rfnoc {
18constexpr uint16_t RFNOC_PROTO_VER = 0x0100;
19
20static const size_t NOC_SHELL_COMPAT_MAJOR = 5;
21static const size_t NOC_SHELL_COMPAT_MINOR = 1;
22
23static const size_t MAX_PACKET_SIZE = 8000; // bytes
24static const size_t DEFAULT_PACKET_SIZE = 1456; // bytes
25
26// One line in FPGA is 64 Bits
27static const size_t BYTES_PER_LINE = 8;
28
30static const size_t DEFAULT_FC_XBAR_RESPONSE_FREQ = 8;
32static const size_t DEFAULT_FC_RX_RESPONSE_FREQ = 64; // ACKs per flow control window
34static const size_t DEFAULT_FC_TX_RESPONSE_FREQ = 8; // ACKs per flow control window
36// Why not 100% full? Because we need to have some headroom to account for the inaccuracy
37// when computing the window size. We compute the flow control window based on the frame
38// size but the buffer can have overhead due to things like UDP headers, page alignment,
39// housekeeping info, etc. This number has to be transport agnostic so 20% of headroom is
40// safe.
41static const double DEFAULT_FC_RX_SW_BUFF_FULL_FACTOR = 0.80;
42
43// Common settings registers.
44static const uint32_t SR_FLOW_CTRL_BYTES_PER_ACK = 1;
45static const uint32_t SR_FLOW_CTRL_WINDOW_SIZE = 2;
46static const uint32_t SR_FLOW_CTRL_EN = 3;
47static const uint32_t SR_ERROR_POLICY = 4;
48static const uint32_t SR_BLOCK_SID = 5; // TODO rename to SRC_SID
49static const uint32_t SR_NEXT_DST_SID = 6;
50static const uint32_t SR_RESP_IN_DST_SID = 7;
51static const uint32_t SR_RESP_OUT_DST_SID = 8;
52static const uint32_t SR_FLOW_CTRL_PKT_LIMIT = 9;
53
54static const uint32_t SR_READBACK_ADDR = 124;
55static const uint32_t SR_READBACK = 127;
56
57static const uint32_t SR_CLEAR_RX_FC = 125;
58static const uint32_t SR_CLEAR_TX_FC = 126;
59
64 SR_READBACK_REG_FIFOSIZE = 2, // fifo size
69};
70
71// AXI stream configuration bus (output master bus of axi wrapper) registers
72static const uint32_t AXI_WRAPPER_BASE = 128;
73static const uint32_t AXIS_CONFIG_BUS =
74 AXI_WRAPPER_BASE + 1; // tdata with tvalid asserted
75static const uint32_t AXIS_CONFIG_BUS_TLAST =
76 AXI_WRAPPER_BASE + 2; // tdata with tvalid & tlast asserted
77
78static const size_t CMD_FIFO_SIZE = 256; // Lines == multiples of 8 bytes
79static const size_t MAX_CMD_PKT_SIZE = 3; // Lines == multiples of 8 bytes
80
81// Named settings registers
82static const uhd::dict<std::string, uint32_t> DEFAULT_NAMED_SR =
83 boost::assign::map_list_of("AXIS_CONFIG_BUS", AXIS_CONFIG_BUS)(
84 "AXIS_CONFIG_BUS_TLAST", AXIS_CONFIG_BUS_TLAST);
85
86// Blocks
87static const size_t MAX_NUM_BLOCKS = 16;
88
89// Block ports
90static const size_t ANY_PORT = size_t(~0);
91static const size_t MAX_NUM_PORTS = 16;
92
93// Regular expressions
94static const std::string VALID_BLOCKNAME_REGEX = "[A-Za-z][A-Za-z0-9_]*";
95static const std::string VALID_BLOCKID_REGEX =
96 "(?:(\\d+)(?:/))?([A-Za-z][A-Za-z0-9]*)(?:(?:#)(\\d\\d?))?";
97
98}} /* namespace uhd::rfnoc */
Definition: dict.hpp:22
Definition: constants.hpp:18
settingsbus_reg_t
Settings register readback.
Definition: constants.hpp:61
@ SR_READBACK_REG_MTU
Definition: constants.hpp:65
@ SR_READBACK_REG_BLOCKPORT_SIDS
Definition: constants.hpp:66
@ SR_READBACK_REG_ID
Definition: constants.hpp:62
@ SR_READBACK_COMPAT
Definition: constants.hpp:68
@ SR_READBACK_REG_FIFOSIZE
Definition: constants.hpp:64
@ SR_READBACK_REG_USER
Definition: constants.hpp:67
@ SR_READBACK_REG_GLOBAL_PARAMS
Definition: constants.hpp:63
Definition: build_info.hpp:12
