13#include <boost/scoped_array.hpp>
   26    typedef std::shared_ptr<filter_info_base>
sptr;
   30        : _type(type), _bypass(bypass), _position_index(position_index)
   62    std::string _analog_type;
   65    typedef std::shared_ptr<analog_filter_base>
sptr;
   68        size_t position_index,
   69        const std::string& analog_type)
   89    typedef std::shared_ptr<analog_filter_lp>
sptr;
   92        size_t position_index,
   93        const std::string& analog_type,
  121template <
typename tap_t>
  133    typedef std::shared_ptr<digital_filter_base>
sptr;
  136        size_t position_index,
  138        size_t interpolation,
  140        double tap_full_scale,
  142        const std::vector<tap_t>& taps)
  145        , _interpolation(interpolation)
  146        , _decimation(decimation)
  147        , _tap_full_scale(tap_full_scale)
  148        , _max_num_taps(max_num_taps)
  156        return (_bypass ? _rate : (_rate / _decimation * _interpolation));
  166        return _interpolation;
  176        return _tap_full_scale;
  186        std::ostringstream os;
  188           <<
"\tinput rate: " << _rate << std::endl
  189           <<
"\tinterpolation: " << _interpolation << std::endl
  190           <<
"\tdecimation: " << _decimation << std::endl
  191           <<
"\tfull-scale: " << _tap_full_scale << std::endl
  192           <<
"\tmax num taps: " << _max_num_taps << std::endl
  193           <<
"\ttaps: " << std::endl;
  196        for (
size_t i = 0; i < _taps.size(); i++) {
  197            os <<
"(tap " << i <<
": " << _taps[i] <<
  198            if (((i % 10) == 0) && (i != 0)) {
  199                os << std::endl <<
"\t\t";
  203        return std::string(os.str());
  207template <
typename tap_t>
  211    typedef std::shared_ptr<digital_filter_fir<tap_t>>
sptr;
  215        size_t position_index,
  217        size_t interpolation,
  219        size_t tap_bit_width,
  221        const std::vector<tap_t>& taps)
  237        std::size_t num_taps = taps.size();
  238        if (num_taps < this->_max_num_taps) {
  240                                             "coefficients. Appending zeros";
  241            std::vector<tap_t> coeffs;
  242            for (
size_t i = 0; i < this->_max_num_taps; i++) {
  244                    coeffs.push_back(taps[i]);
  249            this->_taps = coeffs;
Definition: filters.hpp:61
UHD_INLINE const std::string & get_analog_type()
Definition: filters.hpp:75
virtual std::string to_pp_string()
analog_filter_base(filter_type type, bool bypass, size_t position_index, const std::string &analog_type)
Definition: filters.hpp:66
std::shared_ptr< analog_filter_base > sptr
Definition: filters.hpp:65
Definition: filters.hpp:84
std::shared_ptr< analog_filter_lp > sptr
Definition: filters.hpp:89
analog_filter_lp(filter_type type, bool bypass, size_t position_index, const std::string &analog_type, double cutoff, double rolloff)
Definition: filters.hpp:90
UHD_INLINE double get_cutoff()
Definition: filters.hpp:103
UHD_INLINE void set_cutoff(const double cutoff)
Definition: filters.hpp:113
UHD_INLINE double get_rolloff()
Definition: filters.hpp:108
Definition: filters.hpp:123
uint32_t _decimation
Definition: filters.hpp:127
std::shared_ptr< digital_filter_base > sptr
Definition: filters.hpp:133
tap_t _tap_full_scale
Definition: filters.hpp:128
UHD_INLINE std::vector< tap_t > & get_taps()
Definition: filters.hpp:179
UHD_INLINE double get_interpolation()
Definition: filters.hpp:164
uint32_t _interpolation
Definition: filters.hpp:126
UHD_INLINE double get_output_rate()
Definition: filters.hpp:154
UHD_INLINE double get_tap_full_scale()
Definition: filters.hpp:174
digital_filter_base(filter_type type, bool bypass, size_t position_index, double rate, size_t interpolation, size_t decimation, double tap_full_scale, size_t max_num_taps, const std::vector< tap_t > &taps)
Definition: filters.hpp:134
double _rate
Definition: filters.hpp:125
Definition: filters.hpp:184
UHD_INLINE double get_input_rate()
Definition: filters.hpp:159
UHD_INLINE double get_decimation()
Definition: filters.hpp:169
uint32_t _max_num_taps
Definition: filters.hpp:129
std::vector< tap_t > _taps
Definition: filters.hpp:130
Definition: filters.hpp:209
std::shared_ptr< digital_filter_fir< tap_t > > sptr
Definition: filters.hpp:211
void set_taps(const std::vector< tap_t > &taps)
Definition: filters.hpp:235
digital_filter_fir(filter_info_base::filter_type type, bool bypass, size_t position_index, double rate, size_t interpolation, size_t decimation, size_t tap_bit_width, size_t max_num_taps, const std::vector< tap_t > &taps)
Definition: filters.hpp:213
Definition: filters.hpp:24
UHD_INLINE filter_type get_type()
Definition: filters.hpp:40
virtual ~filter_info_base()
Definition: filters.hpp:45
size_t _position_index
Definition: filters.hpp:55
filter_type _type
Definition: filters.hpp:53
filter_type
Definition: filters.hpp:27
@ ANALOG_BAND_PASS
virtual UHD_INLINE bool is_bypassed()
Definition: filters.hpp:35
std::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:26
filter_info_base(filter_type type, bool bypass, size_t position_index)
Definition: filters.hpp:29
bool _bypass
Definition: filters.hpp:54
#define UHD_INLINE
Definition: config.h:52
Definition: config.h:67
#define UHD_LOGGER_WARNING(component)
Definition: log.hpp:245
Definition: build_info.hpp:12
