11#include <boost/current_function.hpp>
   12#include <boost/thread/thread.hpp>
   97namespace uhd {
namespace log {
  123        const std::string& file_,
  124        const unsigned int& line_,
  125        const std::string& component_,
  126        const boost::thread::id& thread_id_)
  128        , verbosity(verbosity_)
  131        , component(component_)
  132        , thread_id(thread_id_)
  177#define _UHD_LOG_INTERNAL(component, level) \
  178    uhd::_log::log(level, __FILE__, __LINE__, component, boost::this_thread::get_id())
  182#if UHD_LOG_MIN_LEVEL < 1
  183#    define UHD_LOG_TRACE(component, message) \
  184        _UHD_LOG_INTERNAL(component, uhd::log::trace) << message;
  186#    define UHD_LOG_TRACE(component, message)
  189#if UHD_LOG_MIN_LEVEL < 2
  190#    define UHD_LOG_DEBUG(component, message) \
  191        _UHD_LOG_INTERNAL(component, uhd::log::debug) << message;
  193#    define UHD_LOG_DEBUG(component, message)
  196#if UHD_LOG_MIN_LEVEL < 3
  197#    define UHD_LOG_INFO(component, message) \
  198        _UHD_LOG_INTERNAL(component, uhd::log::info) << message;
  200#    define UHD_LOG_INFO(component, message)
  203#if UHD_LOG_MIN_LEVEL < 4
  204#    define UHD_LOG_WARNING(component, message) \
  205        _UHD_LOG_INTERNAL(component, uhd::log::warning) << message;
  207#    define UHD_LOG_WARNING(component, message)
  210#if UHD_LOG_MIN_LEVEL < 5
  211#    define UHD_LOG_ERROR(component, message) \
  212        _UHD_LOG_INTERNAL(component, uhd::log::error) << message;
  214#    define UHD_LOG_ERROR(component, message)
  217#if UHD_LOG_MIN_LEVEL < 6
  218#    define UHD_LOG_FATAL(component, message) \
  219        _UHD_LOG_INTERNAL(component, uhd::log::fatal) << message;
  221#    define UHD_LOG_FATAL(component, message)
  224#define RFNOC_LOG_TRACE(message) UHD_LOG_TRACE(this->get_unique_id(), message)
  225#define RFNOC_LOG_DEBUG(message) UHD_LOG_DEBUG(this->get_unique_id(), message)
  226#define RFNOC_LOG_INFO(message) UHD_LOG_INFO(this->get_unique_id(), message)
  227#define RFNOC_LOG_WARNING(message) UHD_LOG_WARNING(this->get_unique_id(), message)
  228#define RFNOC_LOG_ERROR(message) UHD_LOG_ERROR(this->get_unique_id(), message)
  229#define RFNOC_LOG_FATAL(message) UHD_LOG_FATAL(this->get_unique_id(), message)
  231#ifndef UHD_LOG_FASTPATH_DISABLE
  236#    define UHD_LOG_FASTPATH(message) uhd::_log::log_fastpath(message);
  238#    define UHD_LOG_FASTPATH(message)
  242#define UHD_LOGGER_TRACE(component) _UHD_LOG_INTERNAL(component, uhd::log::trace)
  243#define UHD_LOGGER_DEBUG(component) _UHD_LOG_INTERNAL(component, uhd::log::debug)
  244#define UHD_LOGGER_INFO(component) _UHD_LOG_INTERNAL(component, uhd::log::info)
  245#define UHD_LOGGER_WARNING(component) _UHD_LOG_INTERNAL(component, uhd::log::warning)
  246#define UHD_LOGGER_ERROR(component) _UHD_LOG_INTERNAL(component, uhd::log::error)
  247#define UHD_LOGGER_FATAL(component) _UHD_LOG_INTERNAL(component, uhd::log::fatal)
  253        UHD_LOGGER_DEBUG("DEBUG") \
  254            << __FILE__ << ":" << __LINE__ << " (" << __PRETTY_FUNCTION__ << ")";
  257#    define UHD_HERE() UHD_LOGGER_DEBUG("DEBUG") << __FILE__ << ":" << __LINE__;
  261#define UHD_VAR(var) UHD_LOGGER_DEBUG("DEBUG") << #var << " = " << var;
  264#define UHD_HEX(var)                                                              \
  265    UHD_LOGGER_DEBUG("DEBUG") << #var << " = 0x" << std::hex << std::setfill('0') \
  266                              << std::setw(8) << var << std::dec;
  273void UHD_API log_fastpath(
const std::string&);
  280        const std::string& file,
  281        const unsigned int line,
  282        const std::string& component,
  283        const boost::thread::id thread_id);
  289#define INSERTION_OVERLOAD(x) \
  299    template <
typename T>
  300    INSERTION_OVERLOAD(T val)
  303    INSERTION_OVERLOAD(std::ostream& (*val)(std::ostream&))
  304        INSERTION_OVERLOAD(std::ios& (*val)(std::ios&))
  305            INSERTION_OVERLOAD(std::ios_base& (*val)(std::ios_base&))
  308    std::ostringstream _ss;
Definition: config.h:67
UHD_API void set_logger_level(const std::string &logger, uhd::log::severity_level level)
UHD_API void set_console_level(uhd::log::severity_level level)
UHD_API void set_log_level(uhd::log::severity_level level)
UHD_API void set_file_level(uhd::log::severity_level level)
severity_level
Definition: log.hpp:103
@ warning
Definition: log.hpp:107
@ fatal
Definition: log.hpp:109
@ error
Definition: log.hpp:108
@ trace
Definition: log.hpp:104
@ off
Definition: log.hpp:110
@ info
Definition: log.hpp:106
@ debug
Definition: log.hpp:105
Definition: build_info.hpp:12
std::string file
Definition: log.hpp:138
logging_info()
Definition: log.hpp:120
std::string component
Definition: log.hpp:140
boost::posix_time::ptime time
Definition: log.hpp:136
unsigned int line
Definition: log.hpp:139
uhd::log::severity_level verbosity
Definition: log.hpp:137
logging_info(const boost::posix_time::ptime &time_, const uhd::log::severity_level &verbosity_, const std::string &file_, const unsigned int &line_, const std::string &component_, const boost::thread::id &thread_id_)
Definition: log.hpp:121
Definition: log.hpp:141
std::string message
Definition: log.hpp:142
