11#include <uhdlib/utils/narrow.hpp>
   17namespace uhd {
namespace rfnoc {
   22    typedef std::shared_ptr<traffic_counter>
sptr;
   23    typedef std::function<void(
const uint32_t addr,
const uint32_t data)>
write_reg_fn_t;
   30        : _write_reg_fn(write_reg_fn), _read_reg_fn(read_reg_fn)
   32        const uint32_t id_reg_offset        = 0;
   33        const uint32_t first_counter_offset = 1;
   34        const uint64_t traffic_counter_id   = 0x712AFF1C00000000ULL;
   37        const uint64_t
id = _read_reg_fn(id_reg_offset);
   40        if (
id == traffic_counter_id) {
   41            tree->create<
bool>(root_path /
"traffic_counter/enable")
   42                .add_coerced_subscriber([
this](
const bool enable) {
   43                    uint32_t val = enable ? 1 : 0;
   44                    return _write_reg_fn(0, val);
   48            const char* counters[] = {
"bus_clock_ticks",
   49                "xbar_to_shell_xfer_count",
   50                "xbar_to_shell_pkt_count",
   51                "shell_to_xbar_xfer_count",
   52                "shell_to_xbar_pkt_count",
   53                "shell_to_ce_xfer_count",
   54                "shell_to_ce_pkt_count",
   55                "ce_to_shell_xfer_count",
   56                "ce_to_shell_pkt_count"};
   58            for (
size_t i = 0; i < std::extent<
decltype(counters)>::value; i++) {
   59                tree->create<uint64_t>(root_path /
"traffic_counter" / counters[i])
   60                    .set_publisher([
this, i, first_counter_offset]() {
   62                            uhd::narrow_cast<uint32_t>(i) + first_counter_offset);
Definition: property_tree.hpp:217
Definition: traffic_counter.hpp:20
std::function< void(const uint32_t addr, const uint32_t data)> write_reg_fn_t
Definition: traffic_counter.hpp:23
traffic_counter(uhd::property_tree::sptr tree, uhd::fs_path root_path, write_reg_fn_t write_reg_fn, read_reg_fn_t read_reg_fn)
Definition: traffic_counter.hpp:26
std::function< uint64_t(const uint32_t addr)> read_reg_fn_t
Definition: traffic_counter.hpp:24
std::shared_ptr< traffic_counter > sptr
Definition: traffic_counter.hpp:22
Definition: build_info.hpp:12
Definition: property_tree.hpp:200
