dboard_eeprom.h
1//
2// Copyright 2015 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#include <uhd/config.h>
11#include <uhd/error.h>
12
13#ifdef __cplusplus
15#include <string>
16
17struct uhd_dboard_eeprom_t {
18 uhd::usrp::dboard_eeprom_t dboard_eeprom_cpp;
19 std::string last_error;
20};
21
22extern "C" {
23#else
24struct uhd_dboard_eeprom_t;
25#endif
26
28
34typedef struct uhd_dboard_eeprom_t* uhd_dboard_eeprom_handle;
35
39);
40
42
48);
49
53 char* id_out,
54 size_t strbuffer_len
55);
56
60 const char* id
61);
62
66 char* serial_out,
67 size_t strbuffer_len
68);
69
73 const char* serial
74);
75
83 int* revision_out
84);
85
89 int revision
90);
91
95 char* error_out,
96 size_t strbuffer_len
97);
98
99#ifdef __cplusplus
100}
101#endif
Definition: config.h:70
UHD_API uhd_error uhd_dboard_eeprom_set_id(uhd_dboard_eeprom_handle h, const char *id)
Set the daughterboard ID using a string hex representation.
UHD_API uhd_error uhd_dboard_eeprom_get_revision(uhd_dboard_eeprom_handle h, int *revision_out)
UHD_API uhd_error uhd_dboard_eeprom_get_serial(uhd_dboard_eeprom_handle h, char *serial_out, size_t strbuffer_len)
Get the daughterboard's serial.
UHD_API uhd_error uhd_dboard_eeprom_free(uhd_dboard_eeprom_handle *h)
Safely destroy the given handle.
UHD_API uhd_error uhd_dboard_eeprom_set_revision(uhd_dboard_eeprom_handle h, int revision)
Set the daughterboard's revision.
UHD_API uhd_error uhd_dboard_eeprom_make(uhd_dboard_eeprom_handle *h)
Create handle for a USRP daughterboard EEPROM.
UHD_API uhd_error uhd_dboard_eeprom_get_id(uhd_dboard_eeprom_handle h, char *id_out, size_t strbuffer_len)
Get the ID associated with the given daughterboard as a string hex representation.
struct uhd_dboard_eeprom_t * uhd_dboard_eeprom_handle
A C-level interface for interacting with a daughterboard EEPROM.
Definition: dboard_eeprom.h:34
UHD_API uhd_error uhd_dboard_eeprom_last_error(uhd_dboard_eeprom_handle h, char *error_out, size_t strbuffer_len)
Get the last error reported by the handle.
UHD_API uhd_error uhd_dboard_eeprom_set_serial(uhd_dboard_eeprom_handle h, const char *serial)
Set the daughterboard's serial.
uhd_error
UHD error codes.
Definition: error.h:20
Definition: dboard_eeprom.hpp:18
