device.hpp
1//
2// Copyright 2010-2011,2014 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#include <uhd/config.hpp>
11#include <uhd/property_tree.hpp>
12#include <uhd/stream.hpp>
15#include <functional>
16#include <memory>
18namespace uhd {
19
20class property_tree; // forward declaration
21
27{
28public:
29 typedef std::shared_ptr<device> sptr;
30 typedef std::function<device_addrs_t(const device_addr_t&)> find_t;
31 typedef std::function<sptr(const device_addr_t&)> make_t;
32
34 enum device_filter_t { ANY, USRP, CLOCK };
35 virtual ~device(void) = 0;
36
44 static void register_device(
45 const find_t& find, const make_t& make, const device_filter_t filter);
46
57 static device_addrs_t find(const device_addr_t& hint, device_filter_t filter = ANY);
58
73 static sptr make(
74 const device_addr_t& hint, device_filter_t filter = ANY, size_t which = 0);
75
82
89
100 virtual bool recv_async_msg(
101 async_metadata_t& async_metadata, double timeout = 0.1) = 0;
102
105
108
109protected:
112};
113
114} // namespace uhd
Definition: device.hpp:27
device_filter_t _type
Definition: device.hpp:111
virtual rx_streamer::sptr get_rx_stream(const stream_args_t &args)=0
Make a new receive streamer from the streamer arguments.
virtual bool recv_async_msg(async_metadata_t &async_metadata, double timeout=0.1)=0
static device_addrs_t find(const device_addr_t &hint, device_filter_t filter=ANY)
Find devices attached to the host.
std::function< device_addrs_t(const device_addr_t &)> find_t
Definition: device.hpp:30
uhd::property_tree::sptr get_tree(void) const
Get access to the underlying property structure.
uhd::property_tree::sptr _tree
Definition: device.hpp:110
virtual tx_streamer::sptr get_tx_stream(const stream_args_t &args)=0
Make a new transmit streamer from the streamer arguments.
std::shared_ptr< device > sptr
Definition: device.hpp:29
static sptr make(const device_addr_t &hint, device_filter_t filter=ANY, size_t which=0)
Create a new device from the device address hint.
virtual ~device(void)=0
static void register_device(const find_t &find, const make_t &make, const device_filter_t filter)
std::function< sptr(const device_addr_t &)> make_t
Definition: device.hpp:31
device_filter_t
Device type, used as a filter in make.
Definition: device.hpp:34
@ ANY
device_filter_t get_device_type() const
Get device type.
Definition: property_tree.hpp:216
Definition: stream.hpp:172
std::shared_ptr< tx_streamer > sptr
Definition: stream.hpp:250
Definition: config.h:70
Definition: build_info.hpp:12
std::vector< device_addr_t > device_addrs_t
A typedef for a vector of device addresses.
Definition: device_addr.hpp:87
Definition: metadata.hpp:203
Definition: stream.hpp:59
