dsa_cal.hpp
1//
2// Copyright 2020 Ettus Research, a National Instruments Brand
3//
4// SPDX-License-Identifier: GPL-3.0-or-later
5//
6
7#ifndef INCLUDED_LIBUHD_CAL_GAIN_HPP
8#define INCLUDED_LIBUHD_CAL_GAIN_HPP
9
10#include <uhd/cal/container.hpp>
11#include <uhd/config.hpp>
12#include <boost/optional.hpp>
13#include <array>
14#include <map>
15
16namespace uhd { namespace usrp { namespace cal {
21{
22public:
23 static constexpr uint32_t NUM_AMP = 1;
24 static constexpr uint32_t NUM_DSA = 2 + NUM_AMP;
25 static constexpr uint32_t NUM_GAIN_STAGES = 61;
26
27 using sptr = std::shared_ptr<zbx_tx_dsa_cal>;
28 using step_settings = std::array<uint32_t, NUM_DSA>;
29
37 virtual void add_frequency_band(const double max_freq,
38 const std::string& name,
39 std::array<step_settings, NUM_GAIN_STAGES> dsa_steps) = 0;
40
50 const double freq, const size_t gain_index) const = 0;
51
52 /* Check whether two frequencies map to the same band.
53 */
54 virtual bool is_same_band(double freq1, double freq2) const = 0;
55
60 virtual std::vector<uint32_t> get_band_settings(double freq, uint8_t dsa) const = 0;
61
65 virtual void clear() = 0;
66
68 static sptr make(
69 const std::string& name, const std::string& serial, const uint64_t timestamp);
70
72 static sptr make();
73};
74
78{
79public:
80 static constexpr uint32_t NUM_DSA = 4;
81 static constexpr uint32_t NUM_GAIN_STAGES = 61;
82
83 using sptr = std::shared_ptr<zbx_rx_dsa_cal>;
84 using step_settings = std::array<uint32_t, NUM_DSA>;
85
93 virtual void add_frequency_band(const double max_freq,
94 const std::string& name,
95 std::array<step_settings, NUM_GAIN_STAGES> dsa_steps) = 0;
96
97 virtual bool is_same_band(double freq1, double freq2) const = 0;
107 const double freq, const size_t gain_index) const = 0;
108
113 virtual std::vector<uint32_t> get_band_settings(double freq, uint8_t dsa) const = 0;
114
118 virtual void clear() = 0;
119
121 static sptr make(
122 const std::string& name, const std::string& serial, const uint64_t timestamp);
123
125 static sptr make();
126};
127
128}}} // namespace uhd::usrp::cal
129
130#endif /* INCLUDED_LIBUHD_CAL_GAIN_HPP */
Definition: container.hpp:23
Definition: dsa_cal.hpp:78
static sptr make(const std::string &name, const std::string &serial, const uint64_t timestamp)
Factory for new cal data sets.
virtual const step_settings get_dsa_setting(const double freq, const size_t gain_index) const =0
static sptr make()
Default factory.
virtual void add_frequency_band(const double max_freq, const std::string &name, std::array< step_settings, NUM_GAIN_STAGES > dsa_steps)=0
virtual std::vector< uint32_t > get_band_settings(double freq, uint8_t dsa) const =0
virtual bool is_same_band(double freq1, double freq2) const =0
std::array< uint32_t, NUM_DSA > step_settings
Definition: dsa_cal.hpp:84
std::shared_ptr< zbx_rx_dsa_cal > sptr
Definition: dsa_cal.hpp:83
Definition: dsa_cal.hpp:21
Definition: dsa_cal.hpp:28
std::shared_ptr< zbx_tx_dsa_cal > sptr
Definition: dsa_cal.hpp:27
static sptr make()
Default factory.
Definition: config.h:70
Definition: build_info.hpp:12
