traffic_counter.hpp
1//
2// Copyright 2018 Ettus Research, a National Instruments Company
3// Copyright 2019 Ettus Research, A National Instruments Brand
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#include <uhd/property_tree.hpp>
11#include <uhdlib/utils/narrow.hpp>
12#include <stdint.h>
13#include <type_traits>
14#include <functional>
15#include <memory>
16
17namespace uhd { namespace rfnoc {
18
20{
21public:
22 typedef std::shared_ptr<traffic_counter> sptr;
23 typedef std::function<void(const uint32_t addr, const uint32_t data)> write_reg_fn_t;
24 typedef std::function<uint64_t(const uint32_t addr)> read_reg_fn_t;
25
27 uhd::fs_path root_path,
28 write_reg_fn_t write_reg_fn,
29 read_reg_fn_t read_reg_fn)
30 : _write_reg_fn(write_reg_fn), _read_reg_fn(read_reg_fn)
31 {
32 const uint32_t id_reg_offset = 0;
33 const uint32_t first_counter_offset = 1;
34 const uint64_t traffic_counter_id = 0x712AFF1C00000000ULL;
35
36 // Check traffic counter id to determine if it's present
37 const uint64_t id = _read_reg_fn(id_reg_offset);
38
39 // If present, add properties
40 if (id == traffic_counter_id) {
41 tree->create<bool>(root_path / "traffic_counter/enable")
42 .add_coerced_subscriber([this](const bool enable) {
43 uint32_t val = enable ? 1 : 0;
44 return _write_reg_fn(0, val);
45 })
46 .set(false);
47
48 const char* counters[] = {"bus_clock_ticks",
49 "xbar_to_shell_xfer_count",
50 "xbar_to_shell_pkt_count",
51 "shell_to_xbar_xfer_count",
52 "shell_to_xbar_pkt_count",
53 "shell_to_ce_xfer_count",
54 "shell_to_ce_pkt_count",
55 "ce_to_shell_xfer_count",
56 "ce_to_shell_pkt_count"};
57
58 for (size_t i = 0; i < std::extent<decltype(counters)>::value; i++) {
59 tree->create<uint64_t>(root_path / "traffic_counter" / counters[i])
60 .set_publisher([this, i, first_counter_offset]() {
61 return _read_reg_fn(
62 uhd::narrow_cast<uint32_t>(i) + first_counter_offset);
63 });
64 }
65 }
66 }
67
68private:
69 write_reg_fn_t _write_reg_fn;
70 read_reg_fn_t _read_reg_fn;
71};
72
73}} /* namespace uhd::rfnoc */
Definition: property_tree.hpp:216
Definition: traffic_counter.hpp:20
std::function< void(const uint32_t addr, const uint32_t data)> write_reg_fn_t
Definition: traffic_counter.hpp:23
traffic_counter(uhd::property_tree::sptr tree, uhd::fs_path root_path, write_reg_fn_t write_reg_fn, read_reg_fn_t read_reg_fn)
Definition: traffic_counter.hpp:26
std::function< uint64_t(const uint32_t addr)> read_reg_fn_t
Definition: traffic_counter.hpp:24
std::shared_ptr< traffic_counter > sptr
Definition: traffic_counter.hpp:22
Definition: build_info.hpp:12
Definition: property_tree.hpp:199
