USRP Hardware Driver and USRP Manual Version: 4.1.0.1
convert.hpp
1//
2// Copyright 2011-2012,2014 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#include <uhd/config.hpp>
12#include <boost/operators.hpp>
13#include <functional>
14#include <memory>
15#include <string>
16
17namespace uhd { namespace convert {
18
21{
22public:
23 typedef std::shared_ptr<converter> sptr;
26
27 virtual ~converter(void) = 0;
28
30 virtual void set_scalar(const double) = 0;
31
33 UHD_INLINE void conv(const input_type& in, const output_type& out, const size_t num)
34 {
35 if (num != 0)
36 (*this)(in, out, num);
37 }
38
39private:
41 //
42 // This is the guts of the converter. When deriving new converter types,
43 // this is where the actual conversion routines go.
44 //
45 // \param in Pointers to the input buffers
46 // \param out Pointers to the output buffers
47 // \param num Number of items in the input buffers to convert
48 virtual void operator()(
49 const input_type& in, const output_type& out, const size_t num) = 0;
50};
51
53typedef std::function<converter::sptr(void)> function_type;
54
56typedef int priority_type;
57
59struct UHD_API id_type : boost::equality_comparable<id_type>
60{
61 std::string input_format;
62 size_t num_inputs;
63 std::string output_format;
65 std::string to_pp_string(void) const;
66 std::string to_string(void) const;
67};
68
70UHD_API bool operator==(const id_type&, const id_type&);
71
82 const id_type& id, const function_type& fcn, const priority_type prio);
83
91
97UHD_API void register_bytes_per_item(const std::string& format, const size_t size);
98
100UHD_API size_t get_bytes_per_item(const std::string& format);
101
102}} // namespace uhd::convert
A conversion class that implements a conversion from inputs -> outputs.
Definition: convert.hpp:21
uhd::ref_vector< void * > output_type
Definition: convert.hpp:24
uhd::ref_vector< const void * > input_type
Definition: convert.hpp:25
virtual void set_scalar(const double)=0
Set the scale factor (used in floating point conversions)
UHD_INLINE void conv(const input_type &in, const output_type &out, const size_t num)
The public conversion method to convert inputs -> outputs.
Definition: convert.hpp:33
std::shared_ptr< converter > sptr
Definition: convert.hpp:23
virtual ~converter(void)=0
Definition: ref_vector.hpp:22
#define UHD_INLINE
Definition: config.h:55
Definition: config.h:70
std::function< converter::sptr(void)> function_type
Conversion factory function typedef.
Definition: convert.hpp:53
UHD_API void register_converter(const id_type &id, const function_type &fcn, const priority_type prio)
int priority_type
Priority of conversion routines.
Definition: convert.hpp:56
UHD_API void register_bytes_per_item(const std::string &format, const size_t size)
UHD_API function_type get_converter(const id_type &id, const priority_type prio=-1)
UHD_API bool operator==(const id_type &, const id_type &)
UHD_API size_t get_bytes_per_item(const std::string &format)
Convert an item format to a size in bytes.
Definition: build_info.hpp:12
Identify a conversion routine in the registry.
Definition: convert.hpp:60
Definition: convert.hpp:61
Definition: convert.hpp:63
size_t num_inputs
Definition: convert.hpp:62
size_t num_outputs
Definition: convert.hpp:64
