USRP Hardware Driver and USRP Manual Version: 4.1.0.1
node.hpp
1//
2// Copyright 2019 Ettus Research, a National Instruments Brand
3//
4// SPDX-License-Identifier: GPL-3.0-or-later
5//
6
7#pragma once
8
14#include <uhd/utils/log.hpp>
16#include <unordered_map>
17#include <unordered_set>
18#include <boost/graph/adjacency_list.hpp>
19#include <functional>
20#include <memory>
21#include <mutex>
22#include <string>
23#include <tuple>
24#include <vector>
25
26namespace uhd { namespace rfnoc {
27
35{
36public:
37 using resolver_fn_t = std::function<void(void)>;
38 using resolve_callback_t = std::function<void(void)>;
40 std::function<void(const res_source_info&, action_info::sptr)>;
42 std::unordered_map<res_source_info, std::vector<res_source_info>>;
43
47 //(e.g., if it comes from input port 0, forward it to output port 0).
48 ONE_TO_ONE,
50 ONE_TO_FAN,
52 ONE_TO_ALL_IN,
54 ONE_TO_ALL_OUT,
56 ONE_TO_ALL,
58 DROP,
60 USE_MAP
61 };
62
63 static const size_t ANY_PORT = size_t(~0);
64
65 /**************************************************************************
66 * Structors
67 *************************************************************************/
69
70 virtual ~node_t() {}
71
72 /******************************************
73 * Basic Operations
74 ******************************************/
76 // no two nodes cannot have the same ID.
77 //
78 // \returns The unique ID as a string
79 virtual std::string get_unique_id() const;
80
87 virtual size_t get_num_input_ports() const = 0;
88
95 virtual size_t get_num_output_ports() const = 0;
96
97 /******************************************
98 * Property Specific
99 ******************************************/
100
109 std::vector<std::string> get_property_ids() const;
110
126 template <typename prop_data_t>
127 void set_property(
128 const std::string& id, const prop_data_t& val, const size_t instance = 0);
129
162 void set_properties(const uhd::device_addr_t& props, const size_t instance = 0);
163
181 template <typename prop_data_t>
182 const prop_data_t& get_property(
183 const std::string& id, const size_t instance = 0) /* mutable */;
184
200 virtual void set_command_time(uhd::time_spec_t time, const size_t instance);
201
206 virtual uhd::time_spec_t get_command_time(const size_t instance) const;
207
213 virtual void clear_command_time(const size_t instance);
214
215protected:
216 /******************************************
217 * Internal Registration Functions
218 ******************************************/
219 using prop_ptrs_t = std::unordered_set<property_base_t*>;
220
240 property_base_t* prop, resolve_callback_t&& clean_callback = nullptr);
241
275 prop_ptrs_t&& inputs, prop_ptrs_t&& outputs, resolver_fn_t&& resolver_fn);
276
277 /**************************************************************************
278 * Property forwarding
279 *************************************************************************/
299 forwarding_policy_t policy, const std::string& prop_id = "");
300
321
333 template <typename prop_data_t>
334 void set_property(
335 const std::string& id, const prop_data_t& val, const res_source_info& src_info);
336
348 template <typename prop_data_t>
349 const prop_data_t& get_property(
350 const std::string& id, const res_source_info& src_info) /* mutable */;
351
352 /******************************************
353 * Internal action forwarding
354 ******************************************/
368 void register_action_handler(const std::string& id, action_handler_t&& handler);
369
389 forwarding_policy_t policy, const std::string& action_key = "");
390
414
426 void post_action(const res_source_info& edge_info, action_info::sptr action);
427
428 /**************************************************************************
429 * Graph Interaction
430 *************************************************************************/
451 virtual bool check_topology(const std::vector<size_t>& connected_inputs,
452 const std::vector<size_t>& connected_outputs);
453
459 virtual void shutdown();
460
461 /**************************************************************************
462 * Attributes
463 *************************************************************************/
466
467private:
468 friend class node_accessor_t;
469
474 property_base_t* _find_property(
475 res_source_info src_info, const std::string& id) const;
476
482 uhd::utils::scope_exit::uptr _request_property_access(
483 property_base_t* prop, property_base_t::access_t access) const;
484
489 template <typename PredicateType>
490 prop_ptrs_t filter_props(PredicateType&& predicate)
491 {
492 prop_ptrs_t filtered_props{};
493 for (const auto& type_prop_pair : _props) {
494 for (const auto& prop : type_prop_pair.second) {
495 if (predicate(prop)) {
496 filtered_props.insert(prop);
497 }
498 }
499 }
500
501 return filtered_props;
502 }
503
511 property_base_t* inject_edge_property(
512 property_base_t* blueprint, res_source_info new_src_info);
513
527 void init_props();
528
552 void resolve_props();
553
556 void resolve_all();
557
563 void clean_props();
564
568 void set_resolve_all_callback(resolve_callback_t&& resolver)
569 {
570 _resolve_all_cb = resolver;
571 }
572
575 void clear_resolve_all_callback()
576 {
577 _resolve_all_cb = _default_resolve_all_cb;
578 }
579
614 void forward_edge_property(
615 property_base_t* incoming_prop, const size_t incoming_port);
616
617 /**************************************************************************
618 * Action-Related Methods
619 *************************************************************************/
623 void set_post_action_callback(action_handler_t&& post_handler)
624 {
625 _post_action_cb = std::move(post_handler);
626 }
627
636 void receive_action(const res_source_info& src_info, action_info::sptr action);
637
638 /**************************************************************************
639 * Private helpers
640 *************************************************************************/
642 bool _has_port(const res_source_info& port_info) const;
643
644 /****** Attributes *******************************************************/
646 // global property mutex, this only write-protects access to the property-
647 // related containers in this class.
648 mutable std::mutex _prop_mutex;
649
651 std::unordered_map<res_source_info::source_t,
652 std::vector<property_base_t*>,
653 std::hash<size_t>>
654 _props;
655
657 std::unordered_map<property_base_t*, resolve_callback_t> _clean_cb_registry;
658
659 using property_resolver_t = std::tuple<prop_ptrs_t, prop_ptrs_t, resolver_fn_t>;
661 std::vector<property_resolver_t> _prop_resolvers;
662
664 // has changed, and that a property resolution needs to be performed.
665 resolve_callback_t _resolve_all_cb;
666
668 // method.
669 const resolve_callback_t _default_resolve_all_cb = [this]() {
670 resolve_props();
671 clean_props();
672 };
673
675 // explicitly.
676 //
677 // Dynamic properties include properties defined in the block descriptor
678 // file, as well as new properties that get passed in during property
679 // propagation.
680 std::unordered_set<std::unique_ptr<property_base_t>> _dynamic_props;
681
683 //
684 // The entry with the empty-string-key is the default policy.
685 std::unordered_map<std::string, forwarding_policy_t> _prop_fwd_policies{
686 {"", forwarding_policy_t::ONE_TO_ONE}};
687
689 forwarding_map_t _prop_fwd_map;
690
691 /**************************************************************************
692 * Action-related attributes
693 *************************************************************************/
694 mutable std::mutex _action_mutex;
695
697 std::unordered_map<std::string, action_handler_t> _action_handlers;
698
700 std::unordered_map<std::string, forwarding_policy_t> _action_fwd_policies{
701 {"", forwarding_policy_t::ONE_TO_ONE}};
702
704 //
705 // The default callback will simply drop actions
706 action_handler_t _post_action_cb = [](const res_source_info&,
707 action_info::sptr) { /* nop */ };
708
710 forwarding_map_t _action_fwd_map;
711
712 /**************************************************************************
713 * Other attributes
714 *************************************************************************/
715 std::vector<uhd::time_spec_t> _cmd_timespecs;
716}; // class node_t
717
718}} /* namespace uhd::rfnoc */
719
720#include <uhd/rfnoc/node.ipp>
Definition: dirtifier.hpp:19
Definition: node.hpp:35
Return a unique identifier string for this node. In every RFNoC graph,.
std::vector< std::string > get_property_ids() const
void register_property(property_base_t *prop, resolve_callback_t &&clean_callback=nullptr)
std::unordered_map< res_source_info, std::vector< res_source_info > > forwarding_map_t
Definition: node.hpp:42
void set_action_forwarding_policy(forwarding_policy_t policy, const std::string &action_key="")
void set_prop_forwarding_map(const forwarding_map_t &map)
std::function< void(void)> resolver_fn_t
Definition: node.hpp:37
std::function< void(void)> resolve_callback_t
Definition: node.hpp:38
void register_action_handler(const std::string &id, action_handler_t &&handler)
void post_action(const res_source_info &edge_info, action_info::sptr action)
virtual bool check_topology(const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs)
virtual ~node_t()
Definition: node.hpp:70
void set_action_forwarding_map(const forwarding_map_t &map)
virtual size_t get_num_output_ports() const =0
std::unordered_set< property_base_t * > prop_ptrs_t
Definition: node.hpp:219
void set_properties(const uhd::device_addr_t &props, const size_t instance=0)
forwarding_policy_t
Types of property/action forwarding for those not defined by the block itself.
Definition: node.hpp:45
virtual size_t get_num_input_ports() const =0
void add_property_resolver(prop_ptrs_t &&inputs, prop_ptrs_t &&outputs, resolver_fn_t &&resolver_fn)
std::function< void(const res_source_info &, action_info::sptr)> action_handler_t
Definition: node.hpp:40
static dirtifier_t ALWAYS_DIRTY
A dirtifyer object, useful for properties that always need updating.
Definition: node.hpp:465
void set_prop_forwarding_policy(forwarding_policy_t policy, const std::string &prop_id="")
Definition: property.hpp:26
access_t
Definition: property.hpp:28
Definition: time_spec.hpp:31
std::unique_ptr< scope_exit > uptr
Definition: scope_exit.hpp:25
Definition: config.h:70
Definition: build_info.hpp:12
std::shared_ptr< action_info > sptr
Definition: actions.hpp:32
Definition: res_source_info.hpp:18
source_t
Definition: res_source_info.hpp:21
