USRP Hardware Driver and USRP Manual Version: 4.1.0.1
pwr_cal.hpp
1//
2// Copyright 2020 Ettus Research, a National Instruments Brand
3//
4// SPDX-License-Identifier: GPL-3.0-or-later
5//
6
7#pragma once
8
10#include <uhd/config.hpp>
11#include <uhd/types/ranges.hpp>
12#include <boost/optional.hpp>
13#include <map>
14
15namespace uhd { namespace usrp { namespace cal {
16
45{
46public:
47 using sptr = std::shared_ptr<pwr_cal>;
48
64 virtual void add_power_table(const std::map<double, double>& gain_power_map,
65 const double min_power,
66 const double max_power,
67 const double freq,
68 const boost::optional<int> temperature = boost::none) = 0;
69
75 virtual void clear() = 0;
76
85 virtual void set_temperature(const int temperature) = 0;
86
88 virtual int get_temperature() const = 0;
89
95 virtual void set_ref_gain(const double gain) = 0;
96
101 virtual double get_ref_gain() const = 0;
102
105 virtual uhd::meta_range_t get_power_limits(const double freq,
106 const boost::optional<int> temperature = boost::none) const = 0;
107
119 virtual double get_power(const double gain,
120 const double freq,
121 const boost::optional<int> temperature = boost::none) const = 0;
122
138 virtual double get_gain(const double power_dbm,
139 const double freq,
140 const boost::optional<int> temperature = boost::none) const = 0;
141
143 static sptr make(
144 const std::string& name, const std::string& serial, const uint64_t timestamp);
145
147 static sptr make();
148};
149
150}}} // namespace uhd::usrp::cal
151
Definition: container.hpp:23
Definition: pwr_cal.hpp:45
static sptr make(const std::string &name, const std::string &serial, const uint64_t timestamp)
Factory for new cal data sets.
static sptr make()
Default factory.
virtual void set_ref_gain(const double gain)=0
virtual void set_temperature(const int temperature)=0
virtual double get_gain(const double power_dbm, const double freq, const boost::optional< int > temperature=boost::none) const =0
virtual int get_temperature() const =0
Return the current default temperature.
virtual double get_ref_gain() const =0
virtual uhd::meta_range_t get_power_limits(const double freq, const boost::optional< int > temperature=boost::none) const =0
virtual void clear()=0
virtual double get_power(const double gain, const double freq, const boost::optional< int > temperature=boost::none) const =0
std::shared_ptr< pwr_cal > sptr
Definition: pwr_cal.hpp:47
virtual void add_power_table(const std::map< double, double > &gain_power_map, const double min_power, const double max_power, const double freq, const boost::optional< int > temperature=boost::none)=0
Definition: config.h:70
Definition: build_info.hpp:12
Definition: ranges.hpp:65
