USRP Hardware Driver and USRP Manual Version: 4.1.0.1
udp_zero_copy.hpp
1//
2// Copyright 2010 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#include <uhd/config.hpp>
13#include <memory>
14
15namespace uhd { namespace transport {
16
27class UHD_API udp_zero_copy : public virtual zero_copy_if
28{
29public:
31 {
34 };
35
36 typedef std::shared_ptr<udp_zero_copy> sptr;
37
54 static sptr make(const std::string& addr,
55 const std::string& port,
56 const zero_copy_xport_params& default_buff_args,
57 udp_zero_copy::buff_params& buff_params_out,
58 const device_addr_t& hints = device_addr_t());
59
66 virtual uint16_t get_local_port(void) const = 0;
67
73 virtual std::string get_local_addr(void) const = 0;
74};
75
76}} // namespace uhd::transport
Definition: udp_zero_copy.hpp:28
static sptr make(const std::string &addr, const std::string &port, const zero_copy_xport_params &default_buff_args, udp_zero_copy::buff_params &buff_params_out, const device_addr_t &hints=device_addr_t())
virtual uint16_t get_local_port(void) const =0
std::shared_ptr< udp_zero_copy > sptr
Definition: udp_zero_copy.hpp:36
virtual std::string get_local_addr(void) const =0
Definition: zero_copy.hpp:147
Definition: config.h:70
Definition: build_info.hpp:12
Definition: udp_zero_copy.hpp:31
size_t send_buff_size
Definition: udp_zero_copy.hpp:33
size_t recv_buff_size
Definition: udp_zero_copy.hpp:32
Definition: zero_copy.hpp:123
