12#include <boost/format.hpp>
   13#include <boost/optional.hpp>
   19namespace uhd {
namespace rfnoc {
namespace chdr {
   47        return get_field<uint8_t>(_flat_hdr, VC_OFFSET, VC_WIDTH);
   53        _flat_hdr = set_field(_flat_hdr, vc, VC_OFFSET, VC_WIDTH);
   59        return get_field<bool>(_flat_hdr, EOB_OFFSET, EOB_WIDTH);
   65        _flat_hdr = set_field(_flat_hdr, eob, EOB_OFFSET, EOB_WIDTH);
   71        return get_field<bool>(_flat_hdr, EOV_OFFSET, EOV_WIDTH);
   77        _flat_hdr = set_field(_flat_hdr, eov, EOV_OFFSET, EOV_WIDTH);
   83        return get_field<packet_type_t>(_flat_hdr, PKT_TYPE_OFFSET, PKT_TYPE_WIDTH);
   89        _flat_hdr = set_field(_flat_hdr, pkt_type, PKT_TYPE_OFFSET, PKT_TYPE_WIDTH);
   95        return get_field<uint8_t>(_flat_hdr, NUM_MDATA_OFFSET, NUM_MDATA_WIDTH);
  101        _flat_hdr = set_field(_flat_hdr, num_mdata, NUM_MDATA_OFFSET, NUM_MDATA_WIDTH);
  107        return get_field<uint16_t>(_flat_hdr, SEQ_NUM_OFFSET, SEQ_NUM_WIDTH);
  113        _flat_hdr = set_field(_flat_hdr, seq_num, SEQ_NUM_OFFSET, SEQ_NUM_WIDTH);
  119        return get_field<uint16_t>(_flat_hdr, LENGTH_OFFSET, LENGTH_WIDTH);
  125        _flat_hdr = set_field(_flat_hdr, length, LENGTH_OFFSET, LENGTH_WIDTH);
  131        return get_field<uint16_t>(_flat_hdr, DST_EPID_OFFSET, DST_EPID_WIDTH);
  137        _flat_hdr = set_field(_flat_hdr, dst_epid, DST_EPID_OFFSET, DST_EPID_WIDTH);
  147    inline operator uint64_t()
 const
  155        return _flat_hdr == rhs._flat_hdr;
  161        return _flat_hdr != rhs._flat_hdr;
  167        _flat_hdr = rhs._flat_hdr;
  184        return str(boost::format(
"chdr_header{vc:%u, eob:%c, eov:%c, pkt_type:%u, "
  185                                 "num_mdata:%u, seq_num:%u, length:%u, dst_epid:%u}\n")
  194    uint64_t _flat_hdr = 0;
  196    static constexpr size_t VC_WIDTH        = 6;
  197    static constexpr size_t EOB_WIDTH       = 1;
  198    static constexpr size_t EOV_WIDTH       = 1;
  199    static constexpr size_t PKT_TYPE_WIDTH  = 3;
  200    static constexpr size_t NUM_MDATA_WIDTH = 5;
  201    static constexpr size_t SEQ_NUM_WIDTH   = 16;
  202    static constexpr size_t LENGTH_WIDTH    = 16;
  203    static constexpr size_t DST_EPID_WIDTH  = 16;
  205    static constexpr size_t VC_OFFSET        = 58;
  206    static constexpr size_t EOB_OFFSET       = 57;
  207    static constexpr size_t EOV_OFFSET       = 56;
  208    static constexpr size_t PKT_TYPE_OFFSET  = 53;
  209    static constexpr size_t NUM_MDATA_OFFSET = 48;
  210    static constexpr size_t SEQ_NUM_OFFSET   = 32;
  211    static constexpr size_t LENGTH_OFFSET    = 16;
  212    static constexpr size_t DST_EPID_OFFSET  = 0;
  214    static inline uint64_t mask(
const size_t width)
  216        return ((uint64_t(1) <<
width) - 1);
  219    template <
typename field_t>
  220    static inline field_t get_field(
  221        const uint64_t flat_hdr,
const size_t offset,
const size_t width)
  223        return static_cast<field_t
>((flat_hdr >> offset) & mask(
width));
  226    template <
typename field_t>
  227    static inline uint64_t set_field(
const uint64_t old_val,
  232        return (old_val & ~(mask(
width) << offset))
  233               | ((
static_cast<uint64_t
>(field) & mask(
width)) << offset);
  269    uint16_t dst_port = 0;
  271    uint16_t src_port = 0;
  275    boost::optional<uint64_t> timestamp = boost::none;
  279    uint16_t src_epid = 0;
  281    uint32_t address = 0;
  283    std::vector<uint32_t> data_vtr = {0};
  285    uint8_t byte_enable = 0xF;
  303        size_t max_size_bytes,
  304        const std::function<uint64_t(uint64_t)>& conv_byte_order)
const;
  307    template <endianness_t endianness>
  308    size_t serialize(uint64_t* buff,
size_t max_size_bytes)
 const
  310        auto conv_byte_order = [](uint64_t x) -> uint64_t {
  312                                                       : uhd::htowx<uint64_t>(x);
  314        return serialize(buff, max_size_bytes, conv_byte_order);
  320        const std::function<uint64_t(uint64_t)>& conv_byte_order);
  323    template <endianness_t endianness>
  326        auto conv_byte_order = [](uint64_t x) -> uint64_t {
  328                                                       : uhd::wtohx<uint64_t>(x);
  330        deserialize(buff, num_elems, conv_byte_order);
  339        return bool(timestamp);
  348        return !(*
this == rhs);
  355    static constexpr size_t DST_PORT_WIDTH    = 10;
  356    static constexpr size_t SRC_PORT_WIDTH    = 10;
  357    static constexpr size_t NUM_DATA_WIDTH    = 4;
  358    static constexpr size_t SEQ_NUM_WIDTH     = 6;
  359    static constexpr size_t HAS_TIME_WIDTH    = 1;
  360    static constexpr size_t IS_ACK_WIDTH      = 1;
  361    static constexpr size_t SRC_EPID_WIDTH    = 16;
  362    static constexpr size_t ADDRESS_WIDTH     = 20;
  363    static constexpr size_t BYTE_ENABLE_WIDTH = 4;
  364    static constexpr size_t OPCODE_WIDTH      = 4;
  365    static constexpr size_t STATUS_WIDTH      = 2;
  368    static constexpr size_t DST_PORT_OFFSET    = 0;
  369    static constexpr size_t SRC_PORT_OFFSET    = 10;
  370    static constexpr size_t NUM_DATA_OFFSET    = 20;
  371    static constexpr size_t SEQ_NUM_OFFSET     = 24;
  372    static constexpr size_t HAS_TIME_OFFSET    = 30;
  373    static constexpr size_t IS_ACK_OFFSET      = 31;
  374    static constexpr size_t SRC_EPID_OFFSET    = 32;
  375    static constexpr size_t ADDRESS_OFFSET     = 0;
  376    static constexpr size_t BYTE_ENABLE_OFFSET = 20;
  377    static constexpr size_t OPCODE_OFFSET      = 24;
  378    static constexpr size_t STATUS_OFFSET      = 30;
  379    static constexpr size_t LO_DATA_OFFSET     = 0;
  380    static constexpr size_t HI_DATA_OFFSET     = 32;
  399    uint16_t src_epid = 0;
  403    uint64_t capacity_bytes = 0;
  405    uint32_t capacity_pkts = 0;
  407    uint64_t xfer_count_bytes = 0;
  409    uint64_t xfer_count_pkts = 0;
  411    uint16_t buff_info = 0;
  413    uint64_t status_info = 0;
  427        size_t max_size_bytes,
  428        const std::function<uint64_t(uint64_t)>& conv_byte_order)
const;
  431    template <endianness_t endianness>
  432    size_t serialize(uint64_t* buff,
 const
  434        auto conv_byte_order = [](uint64_t x) -> uint64_t {
  436                                                       : uhd::htowx<uint64_t>(x);
  438        return serialize(buff, max_size_bytes, conv_byte_order);
  444        const std::function<uint64_t(uint64_t)>& conv_byte_order);
  447    template <endianness_t endianness>
  450        auto conv_byte_order = [](uint64_t x) -> uint64_t {
  452                                                       : uhd::wtohx<uint64_t>(x);
  454        deserialize(buff, num_elems, conv_byte_order);
  466        return !(*
this == rhs);
  473    static constexpr size_t SRC_EPID_WIDTH        = 16;
  474    static constexpr size_t STATUS_WIDTH          = 4;
  475    static constexpr size_t CAPACITY_BYTES_WIDTH  = 40;
  476    static constexpr size_t CAPACITY_PKTS_WIDTH   = 24;
  477    static constexpr size_t XFER_COUNT_PKTS_WIDTH = 40;
  478    static constexpr size_t BUFF_INFO_WIDTH       = 16;
  479    static constexpr size_t STATUS_INFO_WIDTH     = 48;
  482    static constexpr size_t SRC_EPID_OFFSET        = 0;
  483    static constexpr size_t STATUS_OFFSET          = 16;
  484    static constexpr size_t CAPACITY_BYTES_OFFSET  = 24;
  485    static constexpr size_t CAPACITY_PKTS_OFFSET   = 0;
  486    static constexpr size_t XFER_COUNT_PKTS_OFFSET = 24;
  487    static constexpr size_t BUFF_INFO_OFFSET       = 0;
  488    static constexpr size_t STATUS_INFO_OFFSET     = 16;
  505    uint16_t src_epid = 0;
  511    uint64_t num_pkts = 0;
  513    uint64_t num_bytes = 0;
  515    static constexpr size_t MAX_PACKET_SIZE = 128;
  529        size_t max_size_bytes,
  530        const std::function<uint64_t(uint64_t)>& conv_byte_order)
const;
  533    template <endianness_t endianness>
  534    size_t serialize(uint64_t* buff,
 const
  536        auto conv_byte_order = [](uint64_t x) -> uint64_t {
  538                                                       : uhd::htowx<uint64_t>(x);
  540        return serialize(buff, max_size_bytes, conv_byte_order);
  546        const std::function<uint64_t(uint64_t)>& conv_byte_order);
  549    template <endianness_t endianness>
  552        auto conv_byte_order = [](uint64_t x) -> uint64_t {
  554                                                       : uhd::wtohx<uint64_t>(x);
  556        deserialize(buff, num_elems, conv_byte_order);
  568        return !(*
this == rhs);
  575    static constexpr size_t SRC_EPID_WIDTH = 16;
  576    static constexpr size_t OP_CODE_WIDTH  = 4;
  577    static constexpr size_t OP_DATA_WIDTH  = 4;
  578    static constexpr size_t NUM_PKTS_WIDTH = 40;
  581    static constexpr size_t SRC_EPID_OFFSET = 0;
  582    static constexpr size_t OP_CODE_OFFSET  = 16;
  583    static constexpr size_t OP_DATA_OFFSET  = 20;
  584    static constexpr size_t NUM_PKTS_OFFSET = 24;
  602        MGMT_OP_ADVERTISE = 1,
  604        MGMT_OP_SEL_DEST = 2,
  608        MGMT_OP_INFO_REQ = 4,
  610        MGMT_OP_INFO_RESP = 5,
  612        MGMT_OP_CFG_WR_REQ = 6,
  614        MGMT_OP_CFG_RD_REQ = 7,
  616        MGMT_OP_CFG_RD_RESP = 8
  642        cfg_payload(uint16_t addr_, uint32_t data_ = 0) : addr(addr_), data(data_) {}
  644            : addr(static_cast<uint16_t>(payload_ >> 0))
  645            , data(static_cast<uint32_t>(payload_ >> 16))
  666            : device_id(device_id_)
  667            , node_type(node_type_)
  668            , node_inst(node_inst_)
  669            , ext_info(ext_info_)
  673            : device_id(static_cast<uint16_t>(payload_ >> 0))
  674            , node_type(static_cast<uint8_t>((payload_ >> 16) & 0xF))
  675            , node_inst(static_cast<uint16_t>((payload_ >> 20) & 0x3FF))
  676            , ext_info(static_cast<uint32_t>((payload_ >> 30) & 0x3FFFF))
  681            return ((
static_cast<payload_t>(device_id) << 0)
  682                    | (
static_cast<payload_t>(node_type & 0xF) << 16)
  683                    | (
static_cast<payload_t>(node_inst & 0x3FF) << 20)
  684                    | (
static_cast<payload_t>(ext_info & 0x3FFFF) << 30));
  689        : _op_code(op_code), _op_payload(op_payload)
  709        return (_op_code == rhs._op_code) && (_op_payload == rhs._op_payload);
  752        const std::function<uint64_t(uint64_t)>& conv_byte_order,
  753        const size_t padding_size)
const;
  759        const std::function<uint64_t(uint64_t)>& conv_byte_order,
  760        const size_t padding_size);
  765        return _ops == rhs._ops;
  772    std::vector<mgmt_op_t> _ops;
  789        set_src_epid(src_epid);
  791        set_proto_ver(protover);
  798        _hops.push_back(hop);
  816        auto hop = _hops.front();
  823        size_t num_lines = 1;
  824        for (
const auto& hop : _hops) {
  825            num_lines += hop.get_num_ops();
  835        size_t max_size_bytes,
  836        const std::function<uint64_t(uint64_t)>& conv_byte_order)
const;
  839    template <endianness_t endianness>
  840    size_t serialize(uint64_t* buff,
 const
  842        auto conv_byte_order = [](uint64_t x) -> uint64_t {
  844                                                       : uhd::htowx<uint64_t>(x);
  846        return serialize(buff, max_size_bytes, conv_byte_order);
  852        const std::function<uint64_t(uint64_t)>& conv_byte_order);
  855    template <endianness_t endianness>
  858        auto conv_byte_order = [](uint64_t x) -> uint64_t {
  860                                                       : uhd::wtohx<uint64_t>(x);
  862        deserialize(buff, num_elems, conv_byte_order);
  883        _src_epid = src_epid;
  911        _protover = proto_ver;
  916    uint16_t _protover   = 0;
  918    size_t _padding_size = 0;
  919    std::deque<mgmt_hop_t> _hops;
  923template <
typename payload_t>
Definition: chdr_types.hpp:266
ctrl_payload & operator=(const ctrl_payload &rhs)=default
bool has_timestamp() const
Definition: chdr_types.hpp:337
size_t get_length() const
Get the serialized size of this payload in 64 bit words.
size_t serialize(uint64_t *buff, size_t max_size_bytes, const std::function< uint64_t(uint64_t)> &conv_byte_order) const
Serialize the payload to a uint64_t buffer.
const std::string to_string() const
Return a string representation of this object.
size_t serialize(uint64_t *buff, size_t max_size_bytes) const
Serialize the payload to a uint64_t buffer (no conversion function)
Definition: chdr_types.hpp:308
ctrl_payload(const ctrl_payload &rhs)=default
bool operator==(const ctrl_payload &rhs) const
Comparison operator (==)
bool operator!=(const ctrl_payload &rhs) const
Comparison operator (!=)
Definition: chdr_types.hpp:346
void populate_header(chdr_header &header) const
Populate the header for this type of packet.
ctrl_payload(ctrl_payload &&rhs)=default
void deserialize(const uint64_t *buff, size_t num_elems)
Deserialize the payload from a uint64_t buffer (no conversion function)
Definition: chdr_types.hpp:324
void deserialize(const uint64_t *buff, size_t num_elems, const std::function< uint64_t(uint64_t)> &conv_byte_order)
Deserialize the payload from a uint64_t buffer.
A class that represents a single management hop.
Definition: chdr_types.hpp:724
void deserialize(std::list< uint64_t > &src, const std::function< uint64_t(uint64_t)> &conv_byte_order, const size_t padding_size)
bool operator==(const mgmt_hop_t &rhs) const
Definition: chdr_types.hpp:763
const mgmt_op_t & get_op(size_t i) const
Get the n'th operation in the hop.
Definition: chdr_types.hpp:743
size_t serialize(std::vector< uint64_t > &target, const std::function< uint64_t(uint64_t)> &conv_byte_order, const size_t padding_size) const
void add_op(const mgmt_op_t &op)
Add a management operation to this hop.
Definition: chdr_types.hpp:731
mgmt_hop_t(const mgmt_hop_t &rhs)=default
size_t get_num_ops() const
Get the number of management operations in this hop.
Definition: chdr_types.hpp:737
A class that represents a single management operation.
Definition: chdr_types.hpp:595
mgmt_op_t(const mgmt_op_t &rhs)=default
op_code_t
Definition: chdr_types.hpp:598
op_code_t get_op_code() const
Get the op-code for this transaction.
Definition: chdr_types.hpp:695
mgmt_op_t(const op_code_t op_code, const payload_t op_payload=0)
Definition: chdr_types.hpp:688
uint64_t get_op_payload() const
Get the payload for this transaction.
Definition: chdr_types.hpp:701
uint64_t payload_t
The payload for an operation is 48 bits wide.
Definition: chdr_types.hpp:620
bool operator==(const mgmt_op_t &rhs) const
Definition: chdr_types.hpp:707
A class that represents a complete multi-hop management transaction.
Definition: chdr_types.hpp:779
size_t get_num_hops() const
Get the number of management hops in this hop.
Definition: chdr_types.hpp:802
void set_proto_ver(uint16_t proto_ver)
Set the protocol version for this transaction.
Definition: chdr_types.hpp:909
chdr_w_t get_chdr_w() const
Return the CHDR_W for this transaction.
Definition: chdr_types.hpp:890
void set_src_epid(sep_id_t src_epid)
Set the source EPID for this transaction.
Definition: chdr_types.hpp:881
void set_chdr_w(chdr_w_t chdr_w)
Set the CHDR_W for this transaction.
Definition: chdr_types.hpp:896
mgmt_payload(const mgmt_payload &rhs)=default
void set_header(sep_id_t src_epid, uint16_t protover, chdr_w_t chdr_w)
Definition: chdr_types.hpp:787
mgmt_hop_t pop_hop()
Pop the first hop of the transaction and return it.
Definition: chdr_types.hpp:814
mgmt_payload & operator=(const mgmt_payload &rhs)=default
void add_hop(const mgmt_hop_t &hop)
Add a management hop to this transaction.
Definition: chdr_types.hpp:796
Definition: chdr_types.hpp:856
size_t get_size_bytes() const
Definition: chdr_types.hpp:821
Definition: chdr_types.hpp:840
sep_id_t get_src_epid() const
Return the source EPID for this transaction.
Definition: chdr_types.hpp:875
uint16_t get_proto_ver() const
Return the protocol version for this transaction.
Definition: chdr_types.hpp:903
const std::string hops_to_string() const
Return a string representaiton of the hops contained by this object.
mgmt_payload(mgmt_payload &&rhs)=default
const mgmt_hop_t & get_hop(size_t i) const
Get the n'th hop in the transaction.
Definition: chdr_types.hpp:808
bool operator==(const mgmt_payload &rhs) const
Definition: chdr_types.hpp:502
bool operator==(const strc_payload &rhs) const
strc_payload(const strc_payload &rhs)=default
strc_payload(strc_payload &&rhs)=default
Definition: chdr_types.hpp:534
Definition: chdr_types.hpp:550
bool operator!=(const strc_payload &rhs) const
Definition: chdr_types.hpp:566
strc_payload & operator=(const strc_payload &rhs)=default
Definition: chdr_types.hpp:396
bool operator!=(const strs_payload &rhs) const
Definition: chdr_types.hpp:464
bool operator==(const strs_payload &rhs) const
strs_payload & operator=(const strs_payload &rhs)=default
Definition: chdr_types.hpp:432
strs_payload(strs_payload &&rhs)=default
Definition: chdr_types.hpp:448
strs_payload(const strs_payload &rhs)=default
Definition: config.h:70
strs_status_t
Definition: chdr_types.hpp:387
@ STRS_CMDERR
No error.
Definition: chdr_types.hpp:389
@ STRS_OKAY
Definition: chdr_types.hpp:388
@ STRS_DATAERR
Packet out of sequence (sequence error)
Definition: chdr_types.hpp:391
@ STRS_RTERR
Data integrity check failed.
Definition: chdr_types.hpp:392
@ STRS_SEQERR
A stream command signalled an error.
Definition: chdr_types.hpp:390
constexpr packet_type_t payload_to_packet_type< mgmt_payload >()
Definition: chdr_types.hpp:933
constexpr packet_type_t payload_to_packet_type< strs_payload >()
Definition: chdr_types.hpp:945
strc_op_code_t
Definition: chdr_types.hpp:495
@ STRC_RESYNC
Trigger a stream status response.
Definition: chdr_types.hpp:498
@ STRC_INIT
Definition: chdr_types.hpp:496
@ STRC_PING
Initialize stream.
Definition: chdr_types.hpp:497
constexpr packet_type_t payload_to_packet_type< strc_payload >()
Definition: chdr_types.hpp:939
ctrl_opcode_t
Definition: chdr_types.hpp:249
@ OP_WRITE
Definition: chdr_types.hpp:251
@ OP_SLEEP
Definition: chdr_types.hpp:250
@ OP_USER1
Definition: chdr_types.hpp:257
@ OP_POLL
Definition: chdr_types.hpp:256
@ OP_USER2
Definition: chdr_types.hpp:258
@ OP_BLOCK_WRITE
Definition: chdr_types.hpp:254
@ OP_USER6
Definition: chdr_types.hpp:262
@ OP_READ
Definition: chdr_types.hpp:252
@ OP_READ_WRITE
Definition: chdr_types.hpp:253
@ OP_BLOCK_READ
Definition: chdr_types.hpp:255
@ OP_USER3
Definition: chdr_types.hpp:259
@ OP_USER4
Definition: chdr_types.hpp:260
@ OP_USER5
Definition: chdr_types.hpp:261
ctrl_status_t
Definition: chdr_types.hpp:242
@ CMD_TSERR
Slave asserted a command error.
Definition: chdr_types.hpp:245
@ CMD_OKAY
Definition: chdr_types.hpp:243
@ CMD_CMDERR
Transaction successful.
Definition: chdr_types.hpp:244
@ CMD_WARNING
Slave asserted a time stamp error.
Definition: chdr_types.hpp:246
constexpr packet_type_t payload_to_packet_type< ctrl_payload >()
Definition: chdr_types.hpp:927
constexpr packet_type_t payload_to_packet_type()
Conversion from payload_t to pkt_type.
packet_type_t
Definition: chdr_types.hpp:21
@ PKT_TYPE_DATA_WITH_TS
Data Packet without TimeStamp.
Definition: chdr_types.hpp:27
@ PKT_TYPE_DATA_NO_TS
Control Transaction.
@ PKT_TYPE_MGMT
Definition: chdr_types.hpp:22
@ PKT_TYPE_STRS
Management packet.
Definition: chdr_types.hpp:23
@ PKT_TYPE_CTRL
Stream Command.
@ PKT_TYPE_STRC
Stream status.
uint16_t sep_id_t
Stream Endpoint ID Type.
Definition: rfnoc_types.hpp:38
chdr_w_t
Type that indicates the CHDR Width in bits.
Definition: rfnoc_types.hpp:19
@ CHDR_W_64
constexpr size_t chdr_w_to_bits(chdr_w_t chdr_w)
Conversion from chdr_w_t to a number of bits.
Definition: rfnoc_types.hpp:21
UHD_INLINE size_t width(const soft_reg_field_t field)
Definition: soft_register.hpp:76
Definition: build_info.hpp:12
@ ENDIANNESS_BIG
Definition: endianness.hpp:30
Definition: chdr_types.hpp:638
cfg_payload(payload_t payload_)
Definition: chdr_types.hpp:643
const uint32_t data
Definition: chdr_types.hpp:640
cfg_payload(uint16_t addr_, uint32_t data_=0)
Definition: chdr_types.hpp:642
const uint16_t addr
Definition: chdr_types.hpp:639
An interpretation class for the payload for MGMT_OP_INFO_RESP.
Definition: chdr_types.hpp:656
const uint16_t node_inst
Definition: chdr_types.hpp:659
node_info_payload(payload_t payload_)
Definition: chdr_types.hpp:672
const uint8_t node_type
Definition: chdr_types.hpp:658
const uint32_t ext_info
Definition: chdr_types.hpp:660
const uint16_t device_id
Definition: chdr_types.hpp:657
node_info_payload(uint16_t device_id_, uint8_t node_type_, uint16_t node_inst_, uint32_t ext_info_)
Definition: chdr_types.hpp:662
An interpretation class for the payload for MGMT_OP_SEL_DEST.
Definition: chdr_types.hpp:624
sel_dest_payload(uint16_t dest_)
Definition: chdr_types.hpp:627
const uint16_t dest
Definition: chdr_types.hpp:625
sel_dest_payload(payload_t payload_)
Definition: chdr_types.hpp:628
