USRP Hardware Driver and USRP Manual Version: 4.1.0.2
uhd::rfnoc::radio_control Member List
This is the complete list of members for uhd::rfnoc::radio_control, including all inherited members.
ALL_CHANSuhd::rfnoc::radio_controlstatic
ALL_GAINSuhd::rfnoc::radio_controlstatic
ALL_LOSuhd::rfnoc::radio_controlstatic
enable_rx_timestamps(const bool enable, const size_t chan)=0uhd::rfnoc::radio_controlpure virtual
enumerate_features()=0uhd::features::discoverable_feature_getter_ifacepure virtual
get_chan_from_dboard_fe(const std::string &fe, const uhd::direction_t direction) const =0uhd::rfnoc::radio_controlpure virtual
get_db_eeprom()=0uhd::rfnoc::radio_controlpure virtual
get_dboard_fe_from_chan(const size_t chan, const uhd::direction_t direction) const =0uhd::rfnoc::radio_controlpure virtual
get_fe_name(const size_t chan, const uhd::direction_t direction) const =0uhd::rfnoc::radio_controlpure virtual
get_feature()uhd::features::discoverable_feature_getter_ifaceinline
get_gpio_attr(const std::string &bank, const std::string &attr)=0uhd::rfnoc::radio_controlpure virtual
get_gpio_banks() const =0uhd::rfnoc::radio_controlpure virtual
get_mb_controller()uhd::rfnoc::noc_block_baseprotected
get_rate() const =0uhd::rfnoc::radio_controlpure virtual
get_rate_range() const =0uhd::rfnoc::radio_controlpure virtual
get_rx_antenna(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_antennas(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_bandwidth(const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_bandwidth_range(size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_dc_offset_range(size_t chan) const =0uhd::rfnoc::radio_controlpure virtual
get_rx_frequency(const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_frequency_range(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_gain(const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_gain(const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_gain_names(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_gain_profile(const size_t chan) const =0uhd::rfnoc::radio_controlpure virtual
get_rx_gain_profile_names(const size_t chan) const =0uhd::rfnoc::radio_controlpure virtual
get_rx_gain_range(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_gain_range(const std::string &name, const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_lo_export_enabled(const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_lo_freq(const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_lo_freq_range(const std::string &name, const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_lo_names(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_lo_source(const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_lo_sources(const std::string &name, const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_rx_power_range(const size_t chan)=0uhd::rfnoc::rf_control::power_reference_ifacepure virtual
get_rx_power_ref_keys(const size_t chan=0)=0uhd::rfnoc::rf_control::power_reference_ifacepure virtual
get_rx_power_reference(const size_t chan=0)=0uhd::rfnoc::rf_control::power_reference_ifacepure virtual
get_rx_sensor(const std::string &name, size_t chan)=0uhd::rfnoc::radio_controlpure virtual
get_rx_sensor_names(size_t chan) const =0uhd::rfnoc::radio_controlpure virtual
get_slot_name() const =0uhd::rfnoc::radio_controlpure virtual
get_spc() const =0uhd::rfnoc::radio_controlpure virtual
get_tx_antenna(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_antennas(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_bandwidth(const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_bandwidth_range(size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_dc_offset_range(size_t chan) const =0uhd::rfnoc::radio_controlpure virtual
get_tx_frequency(const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_frequency_range(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_gain(const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_gain(const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_gain_names(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_gain_profile(const size_t chan) const =0uhd::rfnoc::radio_controlpure virtual
get_tx_gain_profile_names(const size_t chan) const =0uhd::rfnoc::radio_controlpure virtual
get_tx_gain_range(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_gain_range(const std::string &name, const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_lo_export_enabled(const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_lo_freq(const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_lo_freq_range(const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_lo_names(const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_lo_source(const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_lo_sources(const std::string &name, const size_t chan) const =0uhd::rfnoc::rf_control::core_ifacepure virtual
get_tx_power_range(const size_t chan)=0uhd::rfnoc::rf_control::power_reference_ifacepure virtual
get_tx_power_ref_keys(const size_t chan=0)=0uhd::rfnoc::rf_control::power_reference_ifacepure virtual
get_tx_power_reference(const size_t chan=0)=0uhd::rfnoc::rf_control::power_reference_ifacepure virtual
get_tx_sensor(const std::string &name, size_t chan)=0uhd::rfnoc::radio_controlpure virtual
get_tx_sensor_names(size_t chan) const =0uhd::rfnoc::radio_controlpure virtual
has_feature()uhd::features::discoverable_feature_getter_ifaceinline
has_rx_power_reference(const size_t chan=0)=0uhd::rfnoc::rf_control::power_reference_ifacepure virtual
has_tx_power_reference(const size_t chan=0)=0uhd::rfnoc::rf_control::power_reference_ifacepure virtual
issue_stream_cmd(const uhd::stream_cmd_t &stream_cmd, const size_t port)=0uhd::rfnoc::radio_controlpure virtual
node_t()uhd::rfnoc::node_t
set_db_eeprom(const uhd::eeprom_map_t &db_eeprom)=0uhd::rfnoc::radio_controlpure virtual
set_gpio_attr(const std::string &bank, const std::string &attr, const uint32_t value)=0uhd::rfnoc::radio_controlpure virtual
set_rate(const double rate)=0uhd::rfnoc::radio_controlpure virtual
set_rx_agc(const bool enable, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_rx_antenna(const std::string &ant, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_rx_bandwidth(const double bandwidth, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_rx_dc_offset(const bool enb, size_t chan=ALL_CHANS)=0uhd::rfnoc::radio_controlpure virtual
set_rx_dc_offset(const std::complex< double > &offset, size_t chan)=0uhd::rfnoc::radio_controlpure virtual
set_rx_frequency(const double freq, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_rx_gain(const double gain, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_rx_gain(const double gain, const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_rx_gain_profile(const std::string &profile, const size_t chan)=0uhd::rfnoc::radio_controlpure virtual
set_rx_iq_balance(const bool enb, size_t chan)=0uhd::rfnoc::radio_controlpure virtual
set_rx_iq_balance(const std::complex< double > &correction, size_t chan)=0uhd::rfnoc::radio_controlpure virtual
set_rx_lo_export_enabled(bool enabled, const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_rx_lo_freq(double freq, const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_rx_lo_source(const std::string &src, const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_rx_power_reference(const double power_dbm, const size_t chan=0)=0uhd::rfnoc::rf_control::power_reference_ifacepure virtual
set_rx_tune_args(const uhd::device_addr_t &args, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_tx_antenna(const std::string &ant, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_tx_bandwidth(const double bandwidth, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_tx_dc_offset(const std::complex< double > &offset, size_t chan)=0uhd::rfnoc::radio_controlpure virtual
set_tx_frequency(const double freq, size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_tx_gain(const double gain, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_tx_gain(const double gain, const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_tx_gain_profile(const std::string &profile, const size_t chan)=0uhd::rfnoc::radio_controlpure virtual
set_tx_iq_balance(const std::complex< double > &correction, size_t chan)=0uhd::rfnoc::radio_controlpure virtual
set_tx_lo_export_enabled(const bool enabled, const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_tx_lo_freq(const double freq, const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_tx_lo_source(const std::string &src, const std::string &name, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
set_tx_power_reference(const double power_dbm, const size_t chan=0)=0uhd::rfnoc::rf_control::power_reference_ifacepure virtual
set_tx_tune_args(const uhd::device_addr_t &args, const size_t chan)=0uhd::rfnoc::rf_control::core_ifacepure virtual
~core_iface()=defaultuhd::rfnoc::rf_control::core_ifacevirtual
~discoverable_feature_getter_iface()=defaultuhd::features::discoverable_feature_getter_ifacevirtual
~power_reference_iface()=defaultuhd::rfnoc::rf_control::power_reference_ifacevirtual
