13#include <boost/assign/list_of.hpp>
   16namespace uhd {
namespace rfnoc {
   20static const size_t NOC_SHELL_COMPAT_MAJOR = 5;
   21static const size_t NOC_SHELL_COMPAT_MINOR = 1;
   23static const size_t MAX_PACKET_SIZE     = 8000;
   24static const size_t DEFAULT_PACKET_SIZE = 1456;
   27static const size_t BYTES_PER_LINE = 8;
   30static const size_t DEFAULT_FC_XBAR_RESPONSE_FREQ = 8;
   32static const size_t DEFAULT_FC_RX_RESPONSE_FREQ = 64;
   34static const size_t DEFAULT_FC_TX_RESPONSE_FREQ = 8;
   41static const double DEFAULT_FC_RX_SW_BUFF_FULL_FACTOR = 0.80;
   44static const uint32_t SR_FLOW_CTRL_BYTES_PER_ACK = 1;
   45static const uint32_t SR_FLOW_CTRL_WINDOW_SIZE   = 2;
   46static const uint32_t SR_FLOW_CTRL_EN            = 3;
   47static const uint32_t SR_ERROR_POLICY            = 4;
   48static const uint32_t SR_BLOCK_SID               = 5;
   49static const uint32_t SR_NEXT_DST_SID            = 6;
   50static const uint32_t SR_RESP_IN_DST_SID         = 7;
   51static const uint32_t SR_RESP_OUT_DST_SID        = 8;
   52static const uint32_t SR_FLOW_CTRL_PKT_LIMIT     = 9;
   54static const uint32_t SR_READBACK_ADDR = 124;
   55static const uint32_t SR_READBACK      = 127;
   57static const uint32_t SR_CLEAR_RX_FC = 125;
   58static const uint32_t SR_CLEAR_TX_FC = 126;
   72static const uint32_t AXI_WRAPPER_BASE = 128;
   73static const uint32_t AXIS_CONFIG_BUS =
   75static const uint32_t AXIS_CONFIG_BUS_TLAST =
   78static const size_t CMD_FIFO_SIZE    = 256;
   79static const size_t MAX_CMD_PKT_SIZE = 3;
   83    boost::assign::map_list_of(
"AXIS_CONFIG_BUS", AXIS_CONFIG_BUS)(
   84        "AXIS_CONFIG_BUS_TLAST", AXIS_CONFIG_BUS_TLAST);
   87static const size_t MAX_NUM_BLOCKS = 16;
   90static const size_t ANY_PORT      = size_t(~0);
   91static const size_t MAX_NUM_PORTS = 16;
   94static const std::string VALID_BLOCKNAME_REGEX =
"[A-Za-z][A-Za-z0-9_]*";
   95static const std::string VALID_BLOCKID_REGEX =
   96    "(?:(\\d+)(?:/))?([A-Za-z][A-Za-z0-9]*)(?:(?:#)(\\d\\d?))?";
constexpr uint16_t RFNOC_PROTO_VER
Definition: constants.hpp:18
settingsbus_reg_t
Settings register readback.
Definition: constants.hpp:61
@ SR_READBACK_REG_MTU
Definition: constants.hpp:65
@ SR_READBACK_REG_BLOCKPORT_SIDS
Definition: constants.hpp:66
@ SR_READBACK_REG_ID
Definition: constants.hpp:62
@ SR_READBACK_COMPAT
Definition: constants.hpp:68
@ SR_READBACK_REG_FIFOSIZE
Definition: constants.hpp:64
@ SR_READBACK_REG_USER
Definition: constants.hpp:67
@ SR_READBACK_REG_GLOBAL_PARAMS
Definition: constants.hpp:63
Definition: build_info.hpp:12
