21namespace uhd {
namespace rfnoc {
   43    virtual
double set_rate(const
double rate) = 0;
   71        const
size_t chan) const = 0;
   76        const
  120        const
std::complex<
double>& correction,
size_t chan) = 0;
  163        const
std::complex<
size_t chan) = 0;
  189        const
std::
string& bank, const
std::
string& attr, const uint32_t value) = 0;
Definition: discoverable_feature_getter_iface.hpp:18
Definition: noc_block_base.hpp:42
Definition: radio_control.hpp:29
virtual std::vector< std::string > get_rx_sensor_names(size_t chan) const =0
virtual std::string get_dboard_fe_from_chan(const size_t chan, const uhd::direction_t direction) const =0
Return the frontend name for a channel index.
virtual uint32_t get_gpio_attr(const std::string &bank, const std::string &attr)=0
virtual meta_range_t get_rx_dc_offset_range(size_t chan) const =0
virtual void set_tx_dc_offset(const std::complex< double > &offset, size_t chan)=0
virtual std::string get_slot_name() const =0
Returns this radio's slot name (typically "A" or "B")
virtual void issue_stream_cmd(const uhd::stream_cmd_t &stream_cmd, const size_t port)=0
virtual void set_rx_iq_balance(const bool enb, size_t chan)=0
static const std::string ALL_LOS
Definition: radio_control.hpp:31
virtual void enable_rx_timestamps(const bool enable, const size_t chan)=0
virtual void set_db_eeprom(const uhd::eeprom_map_t &db_eeprom)=0
Update the daughterboard EEPROM.
virtual std::vector< std::string > get_gpio_banks() const =0
virtual uhd::eeprom_map_t get_db_eeprom()=0
Return the content of the daughterboard EEPROM.
virtual std::vector< std::string > get_tx_sensor_names(size_t chan) const =0
virtual std::vector< std::string > get_rx_gain_profile_names(const size_t chan) const =0
virtual uhd::meta_range_t get_rate_range() const =0
Return a list of valid rates.
virtual double get_rate() const =0
Get the sample rate.
virtual void set_tx_iq_balance(const std::complex< double > &correction, size_t chan)=0
virtual double set_rate(const double rate)=0
Set the sample rate.
virtual void set_rx_dc_offset(const bool enb, size_t chan=ALL_CHANS)=0
virtual uhd::sensor_value_t get_rx_sensor(const std::string &name, size_t chan)=0
virtual meta_range_t get_tx_dc_offset_range(size_t chan) const =0
virtual void set_rx_gain_profile(const std::string &profile, const size_t chan)=0
virtual std::vector< std::string > get_tx_gain_profile_names(const size_t chan) const =0
virtual std::string get_tx_gain_profile(const size_t chan) const =0
static const std::string ALL_GAINS
Definition: radio_control.hpp:32
static constexpr size_t ALL_CHANS
Definition: radio_control.hpp:33
virtual void set_gpio_attr(const std::string &bank, const std::string &attr, const uint32_t value)=0
virtual void set_tx_gain_profile(const std::string &profile, const size_t chan)=0
virtual size_t get_spc() const =0
Return the samples per clock (SPC) value of this radio.
virtual std::string get_fe_name(const size_t chan, const uhd::direction_t direction) const =0
Return the name of the frontend, as given by the dboard driver.
virtual size_t get_chan_from_dboard_fe(const std::string &fe, const uhd::direction_t direction) const =0
Return the channel that corresponds to a frontend's name.
virtual uhd::sensor_value_t get_tx_sensor(const std::string &name, size_t chan)=0
virtual std::string get_rx_gain_profile(const size_t chan) const =0
Definition: core_iface.hpp:25
Definition: power_reference_iface.hpp:23
Definition: build_info.hpp:12
direction_t
Definition: direction.hpp:12
std::map< std::string, std::vector< uint8_t > > eeprom_map_t
Definition: eeprom.hpp:15
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:21
Definition: sensors.hpp:29
Definition: stream_cmd.hpp:40
