USRP Hardware Driver and USRP Manual Version: 4.1.0.3
ranges.h
1//
2// Copyright 2015 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#include <uhd/config.h>
11#include <uhd/error.h>
12
13#include <stdbool.h>
14#include <stdlib.h>
15
17typedef struct {
19 double start;
21 double stop;
23 double step;
25
26#ifdef __cplusplus
27#include <uhd/types/ranges.hpp>
28#include <string>
29
30struct uhd_meta_range_t {
31 uhd::meta_range_t meta_range_cpp;
32 std::string last_error;
33};
34
35extern "C" {
36#else
37struct uhd_meta_range_t;
38#endif
39
41
44typedef struct uhd_meta_range_t* uhd_meta_range_handle;
45
48 const uhd_range_t *range,
49 char* pp_string_out,
50 size_t strbuffer_len
51);
52
54
60);
61
63
69);
70
74 double *start_out
75);
76
80 double *stop_out
81);
82
86 double *step_out
87);
88
92 double value,
93 bool clip_step,
94 double *result_out
95);
96
100 size_t *size_out
101);
102
106 const uhd_range_t *range
107);
108
112 size_t num,
113 uhd_range_t *range_out
114);
115
119 char* pp_string_out,
120 size_t strbuffer_len
121);
122
126 char* error_out,
127 size_t strbuffer_len
128);
129
130#ifdef __cplusplus
131}
132
133UHD_API uhd::range_t uhd_range_c_to_cpp(
134 const uhd_range_t *range_c
135);
136
137UHD_API void uhd_range_cpp_to_c(
138 const uhd::range_t &range_cpp,
139 uhd_range_t *range_c
140);
141#endif
Definition: ranges.hpp:22
Definition: config.h:70
uhd_error
UHD error codes.
Definition: error.h:20
UHD_API uhd_error uhd_meta_range_make(uhd_meta_range_handle *h)
Create a meta range handle.
UHD_API uhd_error uhd_meta_range_to_pp_string(uhd_meta_range_handle h, char *pp_string_out, size_t strbuffer_len)
Get a string representation of the given meta range.
UHD_API uhd_error uhd_meta_range_free(uhd_meta_range_handle *h)
Destroy a meta range handle.
UHD_API uhd_error uhd_meta_range_start(uhd_meta_range_handle h, double *start_out)
Get the overall start value for the given meta range.
UHD_API uhd_error uhd_meta_range_at(uhd_meta_range_handle h, size_t num, uhd_range_t *range_out)
Get the range at the given index.
UHD_API uhd_error uhd_meta_range_clip(uhd_meta_range_handle h, double value, bool clip_step, double *result_out)
Clip the given value to a possible value in the given range.
UHD_API uhd_error uhd_meta_range_stop(uhd_meta_range_handle h, double *stop_out)
Get the overall stop value for the given meta range.
UHD_API uhd_error uhd_meta_range_last_error(uhd_meta_range_handle h, char *error_out, size_t strbuffer_len)
Get the last error recorded by the underlying meta range.
UHD_API uhd_error uhd_meta_range_push_back(uhd_meta_range_handle h, const uhd_range_t *range)
Add a range to the given meta range.
UHD_API uhd_error uhd_range_to_pp_string(const uhd_range_t *range, char *pp_string_out, size_t strbuffer_len)
Get a string representation of the given range.
Definition: ranges.h:44
UHD_API uhd_error uhd_meta_range_size(uhd_meta_range_handle h, size_t *size_out)
Get the number of ranges in the given meta range.
UHD_API uhd_error uhd_meta_range_step(uhd_meta_range_handle h, double *step_out)
Get the overall step value for the given meta range.
Definition: ranges.hpp:66
Range of floating-point values.
Definition: ranges.h:17
double stop
Last value.
Definition: ranges.h:21
double start
First value.
Definition: ranges.h:19
double step
Granularity.
Definition: ranges.h:23
