USRP Hardware Driver and USRP Manual Version: 4.1.0.3
usrp_info.h
1/*
2 * Copyright 2015 Ettus Research LLC
3 * Copyright 2018 Ettus Research, a National Instruments Company
4 *
5 * SPDX-License-Identifier: GPL-3.0-or-later
6 */
7
8#pragma once
9
10#include <uhd/config.h>
11#include <uhd/error.h>
12
14
17typedef struct {
19 char* mboard_id;
25 char* rx_id;
31 char* rx_serial;
35
37
40typedef struct {
42 char* mboard_id;
48 char* tx_id;
54 char* tx_serial;
58
59#ifdef __cplusplus
60extern "C" {
61#endif
62
64
70
72
78
79#ifdef __cplusplus
80}
81#endif
Definition: config.h:70
uhd_error
UHD error codes.
Definition: error.h:20
USRP RX info.
Definition: usrp_info.h:17
char * rx_id
RX daughterboard ID.
Definition: usrp_info.h:25
char * rx_serial
RX daughterboard serial.
Definition: usrp_info.h:31
char * rx_antenna
RX daughterboard antenna.
Definition: usrp_info.h:33
char * rx_subdev_name
RX subdev name.
Definition: usrp_info.h:27
char * rx_subdev_spec
RX subdev spec.
Definition: usrp_info.h:29
char * mboard_id
Motherboard ID.
Definition: usrp_info.h:19
char * mboard_serial
Motherboard serial.
Definition: usrp_info.h:23
char * mboard_name
Motherboard name.
Definition: usrp_info.h:21
USRP TX info.
Definition: usrp_info.h:40
char * tx_id
TX daughterboard ID.
Definition: usrp_info.h:48
char * tx_subdev_name
TX subdev name.
Definition: usrp_info.h:50
char * tx_serial
TX daughterboard serial.
Definition: usrp_info.h:54
char * mboard_id
Motherboard ID.
Definition: usrp_info.h:42
char * mboard_name
Motherboard name.
Definition: usrp_info.h:44
char * tx_antenna
TX daughterboard antenna.
Definition: usrp_info.h:56
char * tx_subdev_spec
TX subdev spec.
Definition: usrp_info.h:52
Motherboard serial.
Definition: usrp_info.h:46
UHD_API uhd_error uhd_usrp_rx_info_free(uhd_usrp_rx_info_t *rx_info)
Clean up a uhd_usrp_rx_info_t populated by uhd_usrp_get_rx_info().
UHD_API uhd_error uhd_usrp_tx_info_free(uhd_usrp_tx_info_t *tx_info)
Clean up a uhd_usrp_tx_info_t populated by uhd_usrp_get_tx_info().
