15namespace uhd {
namespace rfnoc {
namespace rf_control {
  137        const std::string& name,
const size_t chan)
const = 0;
  149    virtual double get_tx_gain(
const size_t chan) = 0;
  161    virtual double set_tx_gain(
const double gain,
  171        const double gain,
  184        const std::string& name,
const size_t chan)
const = 0;
  196    virtual double get_rx_gain(
  205    virtual double set_rx_gain(
const double gain,
  215        const double gain,
  221    virtual void set_rx_agc(
const bool enable,
  278        const std::string& name,
const size_t chan)
const = 0;
  289        const std::string& name,
const size_t chan)
const = 0;
  301        const std::string& src,
  312        const std::string& name,
  323        bool enabled,
  340        double freq,
  368        const std::string& name,
const size_t chan)
const = 0;
  379        const std::string& name,
  391        const std::string& src,
  402        const std::string& name,
  413        const bool enabled,
  432        const double freq,
Definition: core_iface.hpp:25
virtual double set_rx_lo_freq(double freq, const std::string &name, const size_t chan)=0
virtual meta_range_t get_rx_bandwidth_range(size_t chan) const =0
virtual double get_rx_bandwidth(const size_t chan)=0
virtual std::string get_rx_antenna(const size_t chan) const =0
virtual void set_rx_lo_source(const std::string &src, const std::string &name, const size_t chan)=0
virtual double set_tx_lo_freq(const double freq, const std::string &name, const size_t chan)=0
virtual uhd::freq_range_t get_rx_frequency_range(const size_t chan) const =0
virtual double get_rx_gain(const size_t chan)=0
virtual bool get_tx_lo_export_enabled(const std::string &name, const size_t chan)=0
virtual double get_tx_gain(const size_t chan)=0
virtual bool get_rx_lo_export_enabled(const std::string &name, const size_t chan)=0
virtual double get_tx_bandwidth(const size_t chan)=0
virtual double set_tx_gain(const double gain, const size_t chan)=0
virtual double set_rx_bandwidth(const double bandwidth, const size_t chan)=0
virtual double get_tx_gain(const std::string &name, const size_t chan)=0
virtual double set_rx_gain(const double gain, const size_t chan)=0
virtual void set_rx_tune_args(const uhd::device_addr_t &args, const size_t chan)=0
virtual double set_rx_gain(const double gain, const std::string &name, const size_t chan)=0
virtual void set_rx_lo_export_enabled(bool enabled, const std::string &name, const size_t chan)=0
virtual void set_rx_agc(const bool enable, const size_t chan)=0
virtual void set_tx_lo_source(const std::string &src, const std::string &name, const size_t chan)=0
virtual void set_rx_antenna(const std::string &ant, const size_t chan)=0
virtual meta_range_t get_tx_bandwidth_range(size_t chan) const =0
virtual double get_tx_frequency(const size_t chan)=0
virtual std::string get_tx_antenna(const size_t chan) const =0
virtual std::vector< std::string > get_rx_lo_names(const size_t chan) const =0
virtual std::vector< std::string > get_rx_gain_names(const size_t chan) const =0
virtual double get_rx_gain(const std::string &name, const size_t chan)=0
virtual uhd::gain_range_t get_rx_gain_range(const std::string &name, const size_t chan) const =0
virtual double set_tx_bandwidth(const double bandwidth, const size_t chan)=0
virtual uhd::gain_range_t get_tx_gain_range(const std::string &name, const size_t chan) const =0
virtual double set_tx_gain(const double gain, const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_tx_gain_names(const size_t chan) const =0
virtual const std::string get_tx_lo_source(const std::string &name, const size_t chan)=0
virtual uhd::gain_range_t get_rx_gain_range(const size_t chan) const =0
virtual double set_tx_frequency(const double freq, size_t chan)=0
virtual std::vector< std::string > get_tx_antennas(const size_t chan) const =0
virtual double get_rx_frequency(const size_t chan)=0
virtual std::vector< std::string > get_rx_lo_sources(const std::string &name, const size_t chan) const =0
virtual double get_tx_lo_freq(const std::string &name, const size_t chan)=0
virtual uhd::freq_range_t get_tx_frequency_range(const size_t chan) const =0
virtual freq_range_t get_rx_lo_freq_range(const std::string &name, const size_t chan) const =0
virtual std::vector< std::string > get_tx_lo_sources(const std::string &name, const size_t chan) const =0
virtual const std::string get_rx_lo_source(const std::string &name, const size_t chan)=0
virtual ~core_iface()=default
virtual void set_tx_tune_args(const uhd::device_addr_t &args, const size_t chan)=0
virtual uhd::gain_range_t get_tx_gain_range(const size_t chan) const =0
virtual void set_tx_lo_export_enabled(const bool enabled, const std::string &name, const size_t chan)=0
virtual std::vector< std::string > get_tx_lo_names(const size_t chan) const =0
virtual double set_rx_frequency(const double freq, const size_t chan)=0
virtual std::vector< std::string > get_rx_antennas(const size_t chan) const =0
virtual void set_tx_antenna(const std::string &ant, const size_t chan)=0
virtual freq_range_t get_tx_lo_freq_range(const std::string &name, const size_t chan)=0
virtual double get_rx_lo_freq(const std::string &name, const size_t chan)=0
Definition: build_info.hpp:12
