18namespace uhd {
namespace rfnoc {
   33    using sptr = std::shared_ptr<multichan_register_iface>;
   36        const uint32_t block_base_addr,
   37        const size_t block_size)
   38        : _reg_iface_holder(reg_iface_holder)
   39        , _block_base_addr(block_base_addr)
   40        , _block_size(block_size)
   61        const size_t instance = 0,
   65        _reg_iface_holder.
regs().
poke32(_get_addr(addr, instance), data, time, ack);
   88        const size_t instance = 0,
   92        _reg_iface_holder.
regs().
poke64(_get_addr(addr, instance), data, time, ack);
  115        const std::vector<uint32_t> data,
  116        const size_t instance = 0,
  120        std::vector<uint32_t> abs_addrs(addrs.size());
  121        std::transform(addrs.begin(),
  125                uint32_t addr) -> uint32_t { return _get_addr(addr, instance); });
  151        const std::vector<uint32_t> data,
  152        const size_t instance = 0,
  157            _get_addr(first_addr, instance), data, time, ack);
  171        const size_t instance = 0,
  174        return _reg_iface_holder.
regs().
peek32(_get_addr(addr, instance), time);
  194        const size_t instance = 0,
  197        return _reg_iface_holder.
regs().
peek64(_get_addr(addr, instance), time);
  222        const size_t instance = 0,
  226            _get_addr(first_addr, instance), length, time);
  271        const size_t instance = 0,
  276            _get_addr(addr, instance), data,
mask, timeout, time, ack);
  281    uint32_t _block_base_addr;
  284    inline uint32_t _get_addr(
const uint32_t reg_offset,
const size_t instance)
 const
  286        return _block_base_addr + reg_offset + _block_size * instance;
Definition: multichan_register_iface.hpp:31
void poll32(uint32_t addr, uint32_t data, uint32_t mask, time_spec_t timeout, const size_t instance=0, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)
Definition: multichan_register_iface.hpp:267
std::vector< uint32_t > block_peek32(uint32_t first_addr, size_t length, const size_t instance=0, time_spec_t time=uhd::time_spec_t::ASAP)
Definition: multichan_register_iface.hpp:220
void poke64(uint32_t addr, uint64_t data, const size_t instance=0, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)
Definition: multichan_register_iface.hpp:86
std::shared_ptr< multichan_register_iface > sptr
Definition: multichan_register_iface.hpp:33
void multi_poke32(const std::vector< uint32_t > addrs, const std::vector< uint32_t > data, const size_t instance=0, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)
Definition: multichan_register_iface.hpp:114
uint64_t peek64(uint32_t addr, const size_t instance=0, time_spec_t time=uhd::time_spec_t::ASAP)
Definition: multichan_register_iface.hpp:193
void poke32(uint32_t addr, uint32_t data, const size_t instance=0, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)
Definition: multichan_register_iface.hpp:59
void block_poke32(uint32_t first_addr, const std::vector< uint32_t > data, const size_t instance=0, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)
Definition: multichan_register_iface.hpp:150
~multichan_register_iface()=default
uint32_t peek32(uint32_t addr, const size_t instance=0, time_spec_t time=uhd::time_spec_t::ASAP)
Definition: multichan_register_iface.hpp:170
multichan_register_iface(register_iface_holder ®_iface_holder, const uint32_t block_base_addr, const size_t block_size)
Definition: multichan_register_iface.hpp:35
Definition: register_iface_holder.hpp:19
register_iface & regs()
Definition: register_iface_holder.hpp:28
virtual void block_poke32(uint32_t first_addr, const std::vector< uint32_t > data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
uint64_t peek64(uint32_t addr, time_spec_t time=uhd::time_spec_t::ASAP)
Definition: register_iface.hpp:177
virtual void poll32(uint32_t addr, uint32_t data, uint32_t mask, time_spec_t timeout, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
virtual void multi_poke32(const std::vector< uint32_t > addrs, const std::vector< uint32_t > data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
virtual std::vector< uint32_t > block_peek32(uint32_t first_addr, size_t length, time_spec_t time=uhd::time_spec_t::ASAP)=0
virtual uint32_t peek32(uint32_t addr, time_spec_t time=uhd::time_spec_t::ASAP)=0
void poke64(uint32_t addr, uint64_t data, time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)
Definition: register_iface.hpp:92
virtual void poke32(uint32_t addr, uint32_t data, uhd::time_spec_t time=uhd::time_spec_t::ASAP, bool ack=false)=0
Definition: time_spec.hpp:31
static constexpr double ASAP
Definition: time_spec.hpp:34
Definition: soft_register.hpp:87
Definition: build_info.hpp:12
