In most cases, USB 3.0 bus power will be sufficient to power the device. If using USB 2.0 or a GPSDO, an external power supply or a cable designed to pull power from 2 USB ports (USB 3.0 dual A to micro-B or B) must be used.
UHD software will automatically select the USRP B2X0 images from the installed images package. The image selection can be overridden with the fpga and fw device address parameters.
Example device address string representations to specify non-standard images:
fpga=usrp_b200_fpga.bin -- OR -- fw=usrp_b200_fw.hex
The FPGA image is provided in source code and can thus be modified and rebuilt to serve custom purposes. For example, additional filtering or other DSP operations can be inserted into the FPGA before or after the DAC or ADC stages, respectively. Refer to the FPGA Manual for further information on how to rebuild the FPGA.
To control user-defined IP, the USER_SETTINGS parameter for the radio_legacy block in b200_core.v (for B210 and B200) or b205_core.v (for the mini series) need to be set to 1, and radio_legacy.v can then be modified to include user-defined read and write registers (the file includes examples on how to do that). Any customizations will most likely also be applied in radio_legacy.v.
For FPGA images that include user settings registers, UHD provides APIs to interface with those. To enable access to user settings, apply the enable_user_regs device argument on initialization. Then, use the uhd::multi_usrp::get_user_settings_iface API call to access an object that allows modifying the registers. Example:
The master clock rate feeds the RF frontends and the DSP chains. Users may select non-default clock rates to achieve integer decimation rates or interpolations in the DSP chains. The clock rate can be set to any value between 5 MHz and 61.44 MHz (or 30.72 MHz for dual-channel mode). Note that rates above 56 MHz are possible, but not recommended.
The user can set the master clock rate through the usrp API call uhd::usrp::multi_usrp::set_master_clock_rate(), or the clock rate can be set through the device arguments, which many applications take:
uhd_usrp_probe --args="master_clock_rate=52e6"
 The property to control the master clock rate is a double value, called tick_rate.
The default clock rate setting is to automatically set a clock rate depending on the requested sampling rate. The automatic clock rate selection is disabled when either master_clock_rate is given in the device initialization arguments, or when uhd::usrp::multi_usrp::set_master_clock_rate() is called.
Note that the master clock rate must be an integer multiple of the sampling rate. If a master clock rate is chosen for which this condition does not hold, a warning will be displayed and a different sampling rate is used internally.
Nevertheless, there are multiple valid values for the master clock rate for most sampling rates. The auto clock rate selection attempts to use the largest possible clock rate as to enable as many half-band filters as possible. Expert users might have cases where a more fine-grained control over the resampling stages is required, in which case manually selecting a master clock rate might be more suitable than the automatic rate.
The property to dis- or enable the auto tick rate is a boolean value, auto_tick_rate.
The B200 features an integrated RF frontend.
The RF frontend has individually tunable receive and transmit chains. On the B200 and B200 mini, there is one transmit and one receive RF frontend. On the B210, both transmit and receive can be used in a MIMO configuration. For the MIMO case, both receive frontends share the RX LO, and both transmit frontends share the TX LO. Each LO is tunable between 50 MHz and 6 GHz.
The B200 series support the UHD power calibration API (see: Power Level Controls). The TX path and the two RX paths have their own calibration data, resulting in 6 sets of calibration data total for the B210, and 3 for all the others.
Devices have to be manually calibrated using a calibrated power meter or signal generator.
Below is a table of the B200/B210 LED indicators and their meanings:
| Component ID | Description | Details |
| LED600 | Power Indicator | off = no power applied (before rev6, some rev6) / external power applied and not yet initialized (most rev6) blue = USB power applied (before rev6) / power supplied (USB) OR power supplied (external) (rev6) red = external power applied (before rev6) / external power applied and device initialized (rev6)  |
| LED800 | Channel 2 RX2 Activity | off = no power applied green = receiving  |
| LED801 | Channel 2 TX/RX Activity | off = no activity green = receiving red = transmitting orange = switching between transmitting and receiving  |
| LED802 | Channel 1 TX/RX Activity | off = no activity green = receiving red = transmitting orange = switching between transmitting and receiving  |
| LED803 | Channel 1 RX2 Activity | off = no power applied green = receiving  |
| LED100 | GPS lock indicator | off = no lock green = lock  |
Below is a table of the B200mini LED indicators and their meanings:
| PWR LED | Power Indicator | off = no power applied on = power applied (external or USB)  |
| TRX LED | TX/RX Activity | off = no activity green = receiving red = transmitting orange = switching between transmitting and receiving  |
| RX2 LED | RX2 Activity | off = no activity green = receiving  |
| S0 LED | Reference Lock | off = no activity green = locked  |
| S1 LED | Reference Present | off = reference level low or not present green = reference level high  |
TX LED indicators are on when transmitting data and off when no samples are available to transmit. RX LED indicators are on when sending samples to the host and off when unable to do so. This means that TX/RX activity LED indicators will blink off in a temporary transmit underflow or receive overflow condition, indicating that the host is not sending or receiving samples fast enough. The host will be notified of the condition and output a "U" or "O" as well.
Below is a table showing the B200/B210 external connections and respective power information:
| J601 | External Power | 6 V 3 A  |
| J701 | USB Connector | USB 3.0 |
| J104 | External PPS Input | 1.8 V - 5 V |
| J101 | GPS Antenna | GPSDO will supply nominal voltage to antenna. |
| J100 | External 10 MHz Input | +15 dBm max |
| J800 | RF B: TX/RX | TX power +20 dBm max RX power -15 dBm max  |
| J802 | RF B: RX2 | RX power -15 dBm max |
| J803 | RF A: RX2 | RX power -15 dBm max |
| J801 | RF A: TX/RX | TX power +20 dBm max RX power -15 dBm max  |
Below is a table showing the B200mini external connections and respective power information:
| USB3 | USB Connector | USB 3.0 |
| J1 | TRX | TX power +20 dBm max RX power -15 dBm max  |
| J2 | RX2 | RX power -15 dBm max |
| J3 | External 10 MHz/PPS Reference | +15 dBm max |
Below is a table showing the B200/B210 on-board connectors and switches:
| J5021 | Mictor Connector | Interface to FPGA for I/O and inspection. |
| J5031 | JTAG Header | Interface to FPGA for programming and debugging. |
| J5042 | GPIO Header | Header connected to the FPGA for GPIO purposes. |
| S700 | FX3 Hard Reset Switch | Resets the USB controller / System reset |
| U100 | GPSDO socket | Interface to GPS disciplined reference oscillator |
1 Only on the B210
2 Only since rev. 6 (green board). GPIO pinout is 1=GPIO_0, 2=GPIO_1, 3=GPIO_2, 4=GPIO_3, 5=GPIO_4, 6=GPIO_5, 7=GPIO_6, 8=GPIO_7, 9=GND, 10=GND
Below is a table showing the B200mini on-board connectors and switches:
| J5 | JTAG Header | Interface to FPGA for programming and debugging. |
| J61 | GPIO Header | Header connected to the FPGA for GPIO purposes. |
| SW1 | FX3 Hard Reset Switch | Resets the USB controller / System reset |
1 GPIO pinout is 1=3.3V, 2=GPIO_0, 3=GPIO_1, 4=GPIO_2, 5=GPIO_3, 6=GND, 7=3.3V, 8=GPIO_4, 9=GPIO_5, 10=GPIO_6, 11=GPIO_7, 12=GND
recv_frame_size values, e.g., by setting recv_frame_size=1024 as part of the device args.
