Version: 4.1.0.5
config.hpp
1
2
// Copyright 2010-2011,2014-2016 Ettus Research LLC
3
// Copyright 2018 Ettus Research, a National Instruments Company
4
5
// SPDX-License-Identifier: GPL-3.0-or-later
6
7
8
#pragma once
9
10
#include <boost/config.hpp>
11
#include <boost/version.hpp>
12
13
#ifdef BOOST_MSVC
14
// suppress warnings
15
//# pragma warning(push)
16
//# pragma warning(disable: 4511) // copy constructor can't not be generated
//# pragma warning(disable: 4512) // assignment operator can't not be generated
18
//# pragma warning(disable: 4100) // unreferenced formal parameter
19
//# pragma warning(disable: 4996) // <symbol> was declared deprecated
# pragma warning(disable : 4355)
// 'this' : used in base member initializer list
21
//# pragma warning(disable: 4706) // assignment within conditional expression
22
# pragma warning(disable : 4251)
// class 'A<T>' needs to have dll-interface to be used
23
// by clients of class 'B'
//# pragma warning(disable: 4127) // conditional expression is constant
25
//# pragma warning(disable: 4290) // C++ exception specification ignored except to ...
26
//# pragma warning(disable: 4180) // qualifier applied to function type has no meaning;
27
// ignored
28
# pragma warning(disable : 4275)
// non dll-interface class ... used as base for
29
// dll-interface class ...
30
//# pragma warning(disable: 4267) // 'var' : conversion from 'size_t' to 'type', possible
31
// loss of data # pragma warning(disable: 4511) // 'class' : copy constructor could not be
32
// generated
33
# pragma warning(disable : 4250)
// 'class' : inherits 'method' via dominance
34
# pragma warning( \
35
disable : 4200)
// nonstandard extension used : zero-sized array in struct/union
36
37
// define logical operators
38
# include <ciso646>
39
40
// define ssize_t
41
#ifndef _SSIZE_T_DEFINED
42
#define _SSIZE_T_DEFINED
43
# include <BaseTsd.h>
44
typedef
SSIZE_T ssize_t;
45
#endif
/* _SSIZE_T_DEFINED */
46
47
#endif
// BOOST_MSVC
48
49
// define cross platform attribute macros
50
#if defined(BOOST_MSVC)
51
# define UHD_EXPORT __declspec(dllexport)
52
# define UHD_IMPORT __declspec(dllimport)
53
# define UHD_INLINE __forceinline
54
# define UHD_FORCE_INLINE __forceinline
55
# define UHD_DEPRECATED __declspec(deprecated)
56
# define UHD_ALIGNED(x) __declspec(align(x))
57
# define UHD_UNUSED(x) x
58
# define UHD_FALLTHROUGH
59
#elif defined(__MINGW32__)
60
61
62
# define UHD_INLINE inline
63
# define UHD_FORCE_INLINE inline
64
65
66
# define UHD_UNUSED(x) x __attribute__((unused))
67
68
#elif defined(__GNUG__) && __GNUG__ >= 4
69
# define UHD_EXPORT __attribute__((visibility("default"
70
# define UHD_IMPORT __attribute__((visibility("default"
71
# define UHD_INLINE inline __attribute__((always_inline))
72
# define UHD_FORCE_INLINE inline __attribute__((always_inline))
73
# define UHD_DEPRECATED __attribute__((deprecated))
74
# define UHD_ALIGNED(x) __attribute__((aligned(x)))
75
76
# if __GNUG__ >= 7
77
# define UHD_FALLTHROUGH __attribute__((fallthrough));
78
# else
79
80
# endif
81
#elif defined(__clang__)
82
83
84
85
86
87
88
89
# if __clang_major__ > 3 || (__clang_major__ == 3 && __clang_minor__ >= 8)
90
# define UHD_FALLTHROUGH [[clang:fallthrough]];
91
# else
92
93
# endif
94
#else
95
# define UHD_EXPORT
96
# define UHD_IMPORT
97
98
99
100
101
102
103
#endif
104
105
// Define API declaration macro
106
#ifdef UHD_STATIC_LIB
107
# define UHD_API
108
#else
109
# ifdef UHD_DLL_EXPORTS
110
# define UHD_API UHD_EXPORT
111
# else
112
# define UHD_API UHD_IMPORT
113
# endif
// UHD_DLL_EXPORTS
114
#endif
// UHD_STATIC_LIB
115
116
// Platform defines for conditional parts of headers:
117
// Taken from boost/config/select_platform_config.hpp,
118
// however, we define macros, not strings for platforms.
119
#if (defined(linux) || defined(__linux) || defined(__linux__) || defined(__GLIBC__)) \
120
&& !defined(_CRAYC) && !defined(__FreeBSD_kernel__) && !defined(__GNU__)
121
# define UHD_PLATFORM_LINUX
122
#elif defined(_WIN32) || defined(__WIN32__) || defined(WIN32)
123
# define UHD_PLATFORM_WIN32
124
#elif defined(macintosh) || defined(__APPLE__) || defined(__APPLE_CC__)
125
# define UHD_PLATFORM_MACOS
126
#elif defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__) \
127
128
# define UHD_PLATFORM_BSD
129
#endif
130
131
// Define 'stringize' preprocessor macros. The stringize macro, XSTR, takes
132
// variable arguments so that it can deal with strings that contain commas.
133
// There are two different versions because MSVC handles this syntax a bit
134
// differently than other compilers.
135
136
# define XSTR(x, ...) # x
137
#else
138
# define XSTR(x...) # x
139
#endif
140
141
#define STR(x) XSTR(x)
include
uhd
config.hpp
Generated by
1.9.3
