config.h
1//
2// Copyright 2015-2016 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#ifdef _MSC_VER
11// Bring in "and", "or", and "not"
12#include <iso646.h>
13
14// Define ssize_t
15#ifndef _SSIZE_T_DEFINED
16#define _SSIZE_T_DEFINED
17# include <BaseTsd.h>
18typedef SSIZE_T ssize_t;
19#endif /* _SSIZE_T_DEFINED */
21#endif /* _MSC_VER */
22
23// Define cross-platform macros
24#if defined(_MSC_VER)
25 #define UHD_EXPORT __declspec(dllexport)
26 #define UHD_IMPORT __declspec(dllimport)
27 #define UHD_EXPORT_HEADER
28 #define UHD_IMPORT_HEADER
29 #define UHD_INLINE __forceinline
30 #define UHD_DEPRECATED __declspec(deprecated)
31 #define UHD_ALIGNED(x) __declspec(align(x))
32 #define UHD_UNUSED(x) x
33#elif defined(__MINGW32__)
34 #define UHD_EXPORT __declspec(dllexport)
35 #define UHD_IMPORT __declspec(dllimport)
36 #define UHD_EXPORT_HEADER
37 #define UHD_IMPORT_HEADER
38 #define UHD_INLINE inline
39 #define UHD_DEPRECATED __declspec(deprecated)
40 #define UHD_ALIGNED(x) __declspec(align(x))
41 #define UHD_UNUSED(x) x __attribute__((unused))
42#elif defined(__clang__)
43 #define UHD_EXPORT __attribute__((visibility("default")))
44 #define UHD_IMPORT __attribute__((visibility("default")))
45 #define UHD_EXPORT_HEADER __attribute__((visibility("default")))
46 #define UHD_IMPORT_HEADER __attribute__((visibility("default")))
47 #define UHD_INLINE inline __attribute__((always_inline))
48 #define UHD_DEPRECATED __attribute__((deprecated))
49 #define UHD_ALIGNED(x) __attribute__((aligned(x)))
50 #define UHD_UNUSED(x) x __attribute__((unused))
51#elif defined(__GNUC__) && (__GNUC__ >= 4)
52 #define UHD_EXPORT __attribute__((visibility("default")))
53 #define UHD_IMPORT __attribute__((visibility("default")))
54 #define UHD_EXPORT_HEADER __attribute__((visibility("default")))
55 #define UHD_IMPORT_HEADER __attribute__((visibility("default")))
56 #define UHD_INLINE inline __attribute__((always_inline))
57 #define UHD_DEPRECATED __attribute__((deprecated))
58 #define UHD_ALIGNED(x) __attribute__((aligned(x)))
59 #define UHD_UNUSED(x) x __attribute__((unused))
60#else
61 #define UHD_EXPORT
62 #define UHD_IMPORT
63 #define UHD_EXPORT_HEADER
64 #define UHD_IMPORT_HEADER
65 #define UHD_INLINE inline
66 #define UHD_DEPRECATED
67 #define UHD_ALIGNED(x)
68 #define UHD_UNUSED(x) x
69#endif
70
71// Define API declaration macro
72//
73// UHD_API should be used for classes/structs that
74// have a direct cpp implementations that get directly
75// built into a so/dylib/dll.
76//
77// UHD_API_HEADER should be used for classes/structs
78// that are implemented in header only like hpp/ipp.
79#ifdef UHD_STATIC_LIB
80 #define UHD_API
81 #define UHD_API_HEADER
82#else
83 #ifdef UHD_DLL_EXPORTS
84 #define UHD_API UHD_EXPORT
85 #define UHD_API_HEADER UHD_EXPORT_HEADER
86 #else
87 #define UHD_API UHD_IMPORT
88 #define UHD_API_HEADER UHD_IMPORT_HEADER
89 #endif // UHD_DLL_EXPORTS
90#endif // UHD_STATIC_LIB
91
92// Platform defines for conditional code:
93// Taken from boost/config/select_platform_config.hpp,
94// However, we define macros, not strings, for platforms.
95#if (defined(linux) || defined(__linux) || defined(__linux__) || defined(__GLIBC__)) && !defined(_CRAYC) && !defined(__FreeBSD_kernel__) && !defined(__GNU__)
96 #define UHD_PLATFORM_LINUX
97#elif defined(_WIN32) || defined(__WIN32__) || defined(WIN32)
98 #define UHD_PLATFORM_WIN32
99#elif defined(macintosh) || defined(__APPLE__) || defined(__APPLE_CC__)
100 #define UHD_PLATFORM_MACOS
101#elif defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__) || defined(__FreeBSD_kernel__)
102 #define UHD_PLATFORM_BSD
103#endif
