Loading [MathJax]/jax/output/HTML-CSS/config.js
Version: 4.2.0.0
Table Of Contents
RFNoC Block Properties
Deprecated List
Modules
Namespaces
Classes
Files
File List
File Members
All
Classes
Namespaces
Files
Functions
Variables
Typedefs
Enumerations
Enumerator
Friends
Macros
Modules
Pages
config.hpp
1
2
// Copyright 2010-2011,2014-2016 Ettus Research LLC
3
// Copyright 2018 Ettus Research, a National Instruments Company
4
5
// SPDX-License-Identifier: GPL-3.0-or-later
6
7
8
#pragma once
9
10
#include <boost/config.hpp>
11
#include <boost/version.hpp>
12
13
#ifdef BOOST_MSVC
14
// suppress warnings
15
//# pragma warning(push)
16
//# pragma warning(disable: 4511) // copy constructor can't not be generated
//# pragma warning(disable: 4512) // assignment operator can't not be generated
18
//# pragma warning(disable: 4100) // unreferenced formal parameter
19
//# pragma warning(disable: 4996) // <symbol> was declared deprecated
# pragma warning(disable : 4355)
// 'this' : used in base member initializer list
21
//# pragma warning(disable: 4706) // assignment within conditional expression
22
# pragma warning(disable : 4251)
// class 'A<T>' needs to have dll-interface to be used
23
// by clients of class 'B'
//# pragma warning(disable: 4127) // conditional expression is constant
25
//# pragma warning(disable: 4290) // C++ exception specification ignored except to ...
26
//# pragma warning(disable: 4180) // qualifier applied to function type has no meaning;
27
// ignored
28
# pragma warning(disable : 4275)
// non dll-interface class ... used as base for
29
// dll-interface class ...
30
//# pragma warning(disable: 4267) // 'var' : conversion from 'size_t' to 'type', possible
31
// loss of data # pragma warning(disable: 4511) // 'class' : copy constructor could not be
32
// generated
33
# pragma warning(disable : 4250)
// 'class' : inherits 'method' via dominance
34
# pragma warning( \
35
disable : 4200)
// nonstandard extension used : zero-sized array in struct/union
36
37
// define logical operators
38
# include <ciso646>
39
40
// define ssize_t
41
#ifndef _SSIZE_T_DEFINED
42
#define _SSIZE_T_DEFINED
43
# include <BaseTsd.h>
44
typedef
SSIZE_T ssize_t;
45
#endif
/* _SSIZE_T_DEFINED */
46
47
#endif
// BOOST_MSVC
48
49
// define cross platform attribute macros
50
#if defined(BOOST_MSVC)
51
# define UHD_EXPORT __declspec(dllexport)
52
# define UHD_IMPORT __declspec(dllimport)
53
# define UHD_EXPORT_HEADER
54
# define UHD_IMPORT_HEADER
55
# define UHD_INLINE __forceinline
56
# define UHD_FORCE_INLINE __forceinline
57
# define UHD_DEPRECATED __declspec(deprecated)
58
# define UHD_ALIGNED(x) __declspec(align(x))
59
# define UHD_UNUSED(x) x
60
# define UHD_FALLTHROUGH
61
# define UHD_FUNCTION __FUNCTION__
62
# define UHD_PRETTY_FUNCTION __FUNCSIG__
63
#elif defined(__MINGW32__)
64
65
66
67
68
# define UHD_INLINE inline
69
# define UHD_FORCE_INLINE inline
70
71
72
# define UHD_UNUSED(x) x __attribute__((unused))
73
74
# define UHD_FUNCTION __func__
75
# define UHD_PRETTY_FUNCTION __PRETTY_FUNCTION__
76
#elif defined(__clang__)
77
# define UHD_EXPORT __attribute__((visibility("default"
78
# define UHD_IMPORT __attribute__((visibility("default"
79
# define UHD_EXPORT_HEADER __attribute__((visibility("default"
80
# define UHD_IMPORT_HEADER __attribute__((visibility("default"
81
# define UHD_INLINE inline __attribute__((always_inline))
82
# define UHD_FORCE_INLINE inline __attribute__((always_inline))
83
# define UHD_DEPRECATED __attribute__((deprecated))
84
# define UHD_ALIGNED(x) __attribute__((aligned(x)))
85
86
# if __clang_major__ > 3 || (__clang_major__ == 3 && __clang_minor__ >= 8)
87
# define UHD_FALLTHROUGH [[clang::fallthrough]];
88
# else
89
90
# endif
91
92
93
#elif defined(__GNUG__) && __GNUG__ >= 4
94
95
96
97
98
99
100
101
102
103
# if __GNUG__ >= 7
104
# define UHD_FALLTHROUGH __attribute__((fallthrough));
105
# else
106
107
# endif
108
109
110
#else
111
# define UHD_EXPORT
112
# define UHD_IMPORT
113
114
115
116
117
118
119
120
121
122
# define UHD_PRETTY_FUNCTION __func__
123
#endif
124
125
// Define API declaration macro
126
127
// UHD_API should be used for classes/structs that
128
// have a direct cpp implementations that get directly
129
// built into a so/dylib/dll.
130
131
// UHD_API_HEADER should be used for classes/structs
132
// that are implemented in header only like hpp/ipp.
133
#ifdef UHD_STATIC_LIB
134
# define UHD_API
135
# define UHD_API_HEADER
136
#else
137
# ifdef UHD_DLL_EXPORTS
138
# define UHD_API UHD_EXPORT
139
# define UHD_API_HEADER UHD_EXPORT_HEADER
140
# else
141
# define UHD_API UHD_IMPORT
142
# define UHD_API_HEADER UHD_IMPORT_HEADER
143
# endif
// UHD_DLL_EXPORTS
144
#endif
// UHD_STATIC_LIB
145
146
// Platform defines for conditional parts of headers:
147
// Taken from boost/config/select_platform_config.hpp,
148
// however, we define macros, not strings for platforms.
149
#if (defined(linux) || defined(__linux) || defined(__linux__) || defined(__GLIBC__)) \
150
&& !defined(_CRAYC) && !defined(__FreeBSD_kernel__) && !defined(__GNU__)
151
# define UHD_PLATFORM_LINUX
152
#elif defined(_WIN32) || defined(__WIN32__) || defined(WIN32)
153
# define UHD_PLATFORM_WIN32
154
#elif defined(macintosh) || defined(__APPLE__) || defined(__APPLE_CC__)
155
# define UHD_PLATFORM_MACOS
156
#elif defined(__FreeBSD__) || defined(__NetBSD__) || defined(__OpenBSD__) \
157
158
# define UHD_PLATFORM_BSD
159
#endif
160
161
// Define 'stringize' preprocessor macros. The stringize macro, XSTR, takes
162
// variable arguments so that it can deal with strings that contain commas.
163
// There are two different versions because MSVC handles this syntax a bit
164
// differently than other compilers.
165
166
# define XSTR(x, ...) # x
167
#else
168
# define XSTR(x...) # x
169
#endif
170
171
#define STR(x) XSTR(x)
include
uhd
config.hpp
Generated by
1.9.3
