dboard_iface.hpp
1//
2// Copyright 2010-2013,2015-2016 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#include <uhd/config.hpp>
11#include <uhd/types/serial.hpp>
15#include <uhd/utils/pimpl.hpp>
16#include <stdint.h>
17#include <boost/thread/thread.hpp>
18#include <memory>
19#include <string>
20#include <vector>
21
22namespace uhd { namespace usrp {
23
26{
34
44};
45
53{
54public:
55 typedef std::shared_ptr<dboard_iface> sptr;
57
59 enum unit_t {
60 UNIT_RX = int('r'),
61 UNIT_TX = int('t'),
62 UNIT_BOTH = int('b'),
63 };
64
66 enum aux_dac_t {
67 AUX_DAC_A = int('a'),
68 AUX_DAC_B = int('b'),
69 AUX_DAC_C = int('c'),
70 AUX_DAC_D = int('d')
71 };
72
74 enum aux_adc_t { AUX_ADC_A = int('a'), AUX_ADC_B = int('b') };
75
77
78 ~dboard_iface(void) override{};
79
87
95 virtual void write_aux_dac(unit_t unit, aux_dac_t which_dac, double value) = 0;
96
104 virtual double read_aux_adc(unit_t unit, aux_adc_t which_adc) = 0;
105
113 virtual void set_pin_ctrl(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
114
121 virtual uint32_t get_pin_ctrl(unit_t unit) = 0;
122
131 virtual void set_atr_reg(
132 unit_t unit, atr_reg_t reg, uint32_t value, uint32_t mask = 0xffff) = 0;
133
141 virtual uint32_t get_atr_reg(unit_t unit, atr_reg_t reg) = 0;
142
150 virtual void set_gpio_ddr(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
151
158 virtual uint32_t get_gpio_ddr(unit_t unit) = 0;
159
167 virtual void set_gpio_out(unit_t unit, uint32_t value, uint32_t mask = 0xffff) = 0;
168
175 virtual uint32_t get_gpio_out(unit_t unit) = 0;
176
183 virtual uint32_t read_gpio(unit_t unit) = 0;
184
193 virtual void write_spi(
194 unit_t unit, const spi_config_t& config, uint32_t data, size_t num_bits) = 0;
195
205 virtual uint32_t read_write_spi(
206 unit_t unit, const spi_config_t& config, uint32_t data, size_t num_bits) = 0;
207
214 virtual void set_clock_rate(unit_t unit, double rate) = 0;
215
222 virtual double get_clock_rate(unit_t unit) = 0;
223
230 virtual std::vector<double> get_clock_rates(unit_t unit) = 0;
231
238 virtual void set_clock_enabled(unit_t unit, bool enb) = 0;
239
247 virtual double get_codec_rate(unit_t unit) = 0;
248
256 virtual void set_fe_connection(unit_t unit,
257 const std::string& fe_name,
258 const uhd::usrp::fe_connection_t& fe_conn) = 0;
259
262 virtual bool has_set_fe_connection(const unit_t)
263 {
264 return false;
265 }
266
272
277 virtual void set_command_time(const uhd::time_spec_t& t) = 0;
278
283 virtual void sleep(const boost::chrono::nanoseconds& time);
284};
285
286}} // namespace uhd::usrp
Definition: serial.hpp:36
Definition: time_spec.hpp:31
Definition: dboard_iface.hpp:53
virtual uint32_t get_atr_reg(unit_t unit, atr_reg_t reg)=0
virtual uint32_t get_gpio_ddr(unit_t unit)=0
virtual void set_gpio_ddr(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0
aux_adc_t
Definition: dboard_iface.hpp:74
virtual void set_clock_rate(unit_t unit, double rate)=0
Definition: dboard_iface.hpp:56
std::shared_ptr< dboard_iface > sptr
Definition: dboard_iface.hpp:55
virtual special_props_t get_special_props(void)=0
Definition: dboard_iface.hpp:78
virtual void set_atr_reg(unit_t unit, atr_reg_t reg, uint32_t value, uint32_t mask=0xffff)=0
virtual void set_command_time(const uhd::time_spec_t &t)=0
virtual uhd::time_spec_t get_command_time(void)=0
virtual void write_aux_dac(unit_t unit, aux_dac_t which_dac, double value)=0
virtual uint32_t get_gpio_out(unit_t unit)=0
uhd::usrp::gpio_atr::gpio_atr_reg_t atr_reg_t
Definition: dboard_iface.hpp:76
virtual void set_pin_ctrl(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0
virtual void set_gpio_out(unit_t unit, uint32_t value, uint32_t mask=0xffff)=0
unit_t
Definition: dboard_iface.hpp:59
virtual void set_fe_connection(unit_t unit, const std::string &fe_name, const uhd::usrp::fe_connection_t &fe_conn)=0
virtual double get_codec_rate(unit_t unit)=0
Definition: dboard_iface.hpp:262
virtual uint32_t get_pin_ctrl(unit_t unit)=0
virtual uint32_t read_write_spi(unit_t unit, const spi_config_t &config, uint32_t data, size_t num_bits)=0
virtual void sleep(const boost::chrono::nanoseconds &time)
virtual void write_spi(unit_t unit, const spi_config_t &config, uint32_t data, size_t num_bits)=0
virtual uint32_t read_gpio(unit_t unit)=0
virtual double get_clock_rate(unit_t unit)=0
aux_dac_t
Definition: dboard_iface.hpp:66
virtual double read_aux_adc(unit_t unit, aux_adc_t which_adc)=0
virtual void set_clock_enabled(unit_t unit, bool enb)=0
virtual std::vector< double > get_clock_rates(unit_t unit)=0
Definition: fe_connection.hpp:17
Definition: config.h:87
Definition: soft_register.hpp:86
gpio_atr_reg_t
Definition: gpio_defs.hpp:12
Definition: build_info.hpp:12
Definition: serial.hpp:83
bool mangle_i2c_addrs
Definition: dboard_iface.hpp:43
bool soft_clock_divider
Definition: dboard_iface.hpp:33
