13namespace uhd {
namespace rfnoc {
   15static const std::string CLOCK_KEY_GRAPH(
"__graph__");
   17static const std::string PROP_KEY_DECIM(
"decim");
   18static const std::string PROP_KEY_INTERP(
"interp");
   19static const std::string PROP_KEY_SAMP_RATE(
"samp_rate");
   20static const std::string PROP_KEY_SCALING(
"scaling");
   21static const std::string PROP_KEY_TYPE(
"type");
   22static const std::string PROP_KEY_FREQ(
"freq");
   23static const std::string PROP_KEY_TICK_RATE(
"tick_rate");
   24static const std::string PROP_KEY_SPP(
"spp");
   25static const std::string PROP_KEY_MTU(
"mtu");
   26static const std::string PROP_KEY_ATOMIC_ITEM_SIZE(
"atomic_item_size");
   28static const std::string NODE_ID_SEP(
"SEP");
   31static const io_type_t IO_TYPE_S16  =
"s16";
   32static const io_type_t IO_TYPE_SC16 =
"sc16";
   35static const std::string ACTION_KEY_STREAM_CMD(
"stream_cmd");
   36static const std::string ACTION_KEY_RX_EVENT(
"rx_event");
   37static const std::string ACTION_KEY_RX_RESTART_REQ(
"restart_request");
   38static const std::string ACTION_KEY_TX_EVENT(
"tx_event");
   41static const std::string DEFAULT_BLOCK_NAME =
"Block";
   43static const uint32_t DEFAULT_NOC_ID  = 0xFFFFFFFF;
   44static const double DEFAULT_TICK_RATE = 1.0;
   74static const noc_id_t ADDSUB_BLOCK         = 0xADD00000;
   75static const noc_id_t DUC_BLOCK            = 0xD0C00000;
   76static const noc_id_t DDC_BLOCK            = 0xDDC00000;
   77static const noc_id_t FFT_BLOCK            = 0xFF700000;
   78static const noc_id_t FIR_FILTER_BLOCK     = 0xF1120000;
   79static const noc_id_t FOSPHOR_BLOCK        = 0x666F0000;
   80static const noc_id_t LOGPWR_BLOCK         = 0x4C500000;
   81static const noc_id_t KEEP_ONE_IN_N_BLOCK  = 0x02460000;
   82static const noc_id_t MOVING_AVERAGE_BLOCK = 0xAAD20000;
   83static const noc_id_t RADIO_BLOCK          = 0x12AD1000;
   84static const noc_id_t REPLAY_BLOCK         = 0x4E91A000;
   85static const noc_id_t SIGGEN_BLOCK         = 0x51663110;
   86static const noc_id_t SPLIT_STREAM_BLOCK   = 0x57570000;
   87static const noc_id_t SWITCHBOARD_BLOCK    = 0xBE110000;
   88static const noc_id_t VECTOR_IIR_BLOCK     = 0x11120000;
   89static const noc_id_t WINDOW_BLOCK         = 0xD0530000;
uint16_t device_type_t
Device Type.
Definition: defaults.hpp:53
uint32_t noc_id_t
Definition: defaults.hpp:49
std::string io_type_t
Definition: defaults.hpp:30
Definition: build_info.hpp:12
