fft_block_control.hpp
1//
2// Copyright 2019 Ettus Research, a National Instruments Brand
3//
4// SPDX-License-Identifier: GPL-3.0-or-later
5//
6
7#pragma once
8
9#include <uhd/config.hpp>
11
12namespace uhd { namespace rfnoc {
13
18// Custom property keys
19static const std::string PROP_KEY_MAGNITUDE = "magnitude";
20static const std::string PROP_KEY_DIRECTION = "direction";
21static const std::string PROP_KEY_LENGTH = "length";
22static const std::string PROP_KEY_FFT_SCALING = "fft_scaling";
23static const std::string PROP_KEY_SHIFT_CONFIG = "shift_config";
42{
43public:
45
46 static const uint32_t REG_RESET_ADDR;
47 static const uint32_t REG_LENGTH_LOG2_ADDR;
48 static const uint32_t REG_MAGNITUDE_OUT_ADDR;
49 static const uint32_t REG_DIRECTION_ADDR;
50 static const uint32_t REG_SCALING_ADDR;
51 static const uint32_t REG_SHIFT_CONFIG_ADDR;
52
60 virtual void set_direction(const fft_direction direction) = 0;
61
68 virtual fft_direction get_direction() const = 0;
69
81 virtual void set_magnitude(const fft_magnitude magnitude) = 0;
82
89 virtual fft_magnitude get_magnitude() const = 0;
90
104 virtual void set_shift_config(const fft_shift shift) = 0;
105
112 virtual fft_shift get_shift_config() const = 0;
113
124 virtual void set_scaling(const uint16_t scaling) = 0;
125
132 virtual uint16_t get_scaling() const = 0;
133
142 virtual void set_length(const size_t length) = 0;
143
150 virtual size_t get_length() const = 0;
151};
152
153}} // namespace uhd::rfnoc
Definition: fft_block_control.hpp:42
Definition: noc_block_base.hpp:43
Definition: config.h:87
fft_magnitude
Definition: fft_block_control.hpp:16
fft_shift
Definition: fft_block_control.hpp:14
fft_direction
Definition: fft_block_control.hpp:15
UHD_INLINE size_t shift(const soft_reg_field_t field)
Definition: soft_register.hpp:80
Definition: build_info.hpp:12
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
