12namespace uhd {
namespace rfnoc {
  105    static const uint32_t REG_ENABLE_ADDR;
  106    static const uint32_t REG_CLEAR_ADDR;
  107    static const uint32_t REG_RANDOM_ADDR;
  108    static const uint32_t REG_DECIM_ADDR;
  109    static const uint32_t REG_OFFSET_ADDR;
  110    static const uint32_t REG_SCALE_ADDR;
  111    static const uint32_t REG_TRISE_ADDR;
  112    static const uint32_t REG_TDECAY_ADDR;
  113    static const uint32_t REG_ALPHA_ADDR;
  114    static const uint32_t REG_EPSILON_ADDR;
  115    static const uint32_t REG_WF_CTRL_ADDR;
  116    static const uint32_t REG_WF_DECIM_ADDR;
  124    virtual
void set_enable_histogram(const
bool enable_histogram) = 0;
  132    virtual
bool get_enable_histogram() const = 0;
  140    virtual
void set_enable_waterfall(const
bool enable_waterfall) = 0;
  148    virtual
bool get_enable_waterfall() const = 0;
  155    virtual
void clear_history() = 0;
  164    virtual
void set_enable_dither(const
bool enable_dither) = 0;
  172    virtual
bool get_enable_dither() const = 0;
  181    virtual
void set_enable_noise(const
bool enable_noise) = 0;
  189    virtual
bool get_enable_noise() const = 0;
  201    virtual
void set_histogram_decimation(const uint16_t decimation) = 0;
  209    virtual uint16_t get_histogram_decimation() const = 0;
  218    virtual
void set_histogram_offset(const uint16_t offset) = 0;
  226    virtual uint16_t get_histogram_offset() const = 0;
  235    virtual
void set_histogram_scale(const uint16_t scale) = 0;
  243    virtual uint16_t get_histogram_scale() const = 0;
  256    virtual
void set_histogram_rise_rate(const uint16_t rise_rate) = 0;
  264    virtual uint16_t get_histogram_rise_rate() const = 0;
  277    virtual
void set_histogram_decay_rate(const uint16_t decay_rate) = 0;
  285    virtual uint16_t get_histogram_decay_rate() const = 0;
  296    virtual
void set_spectrum_alpha(const uint16_t alpha) = 0;
  305    virtual uint16_t get_spectrum_alpha() const = 0;
  315    virtual
void set_spectrum_max_hold_decay(const uint16_t epsilon) = 0;
  324    virtual uint16_t get_spectrum_max_hold_decay() const = 0;
  332    virtual
void set_waterfall_predivision(
  373    virtual
void set_waterfall_decimation(const uint16_t waterfall_decimation) = 0;
  381    virtual uint16_t get_waterfall_decimation() const = 0;
Definition: fosphor_block_control.hpp:100
Definition: noc_block_base.hpp:43
Definition: config.h:87
fosphor_waterfall_predivision_ratio
Definition: fosphor_block_control.hpp:15
fosphor_waterfall_mode
Definition: fosphor_block_control.hpp:14
Definition: build_info.hpp:12
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
