log.hpp
1//
2// Copyright 2011 Ettus Research LLC
3// Copyright 2018 Ettus Research, a National Instruments Company
4//
5// SPDX-License-Identifier: GPL-3.0-or-later
6//
7
8#pragma once
9
10#include <uhd/config.hpp>
11#include <boost/date_time/posix_time/posix_time_types.hpp>
12#include <boost/optional.hpp>
13#include <iomanip>
14#include <iostream>
15#include <ostream>
16#include <sstream>
17#include <string>
18#include <thread>
19
99/*
100 * Advanced logging macros
101 * UHD_LOG_MIN_LEVEL definitions
102 * trace: 0
103 * debug: 1
104 * info: 2
105 * warning: 3
106 * error: 4
107 * fatal: 5
108 */
109
110namespace uhd { namespace log {
117 trace = 0,
118 debug = 1,
119 info = 2,
121 error = 4,
122 fatal = 5,
123 off = 6,
124};
125
129boost::optional<uhd::log::severity_level> UHD_API parse_log_level_from_string(
130 const std::string& log_level_str);
131
138{
139 logging_info() : verbosity(uhd::log::off) {}
140 logging_info(const boost::posix_time::ptime& time_,
141 const uhd::log::severity_level& verbosity_,
142 const std::string& file_,
143 const unsigned int& line_,
144 const std::string& component_,
145 const std::thread::id& thread_id_)
146 : time(time_)
147 , verbosity(verbosity_)
148 , file(file_)
149 , line(line_)
150 , component(component_)
151 , thread_id(thread_id_)
152 { /* nop */
153 }
154
155 boost::posix_time::ptime time;
157 std::string file;
158 unsigned int line;
159 std::string component;
160 std::thread::id thread_id;
161 std::string message;
162};
163
171
177
183
191UHD_API void set_logger_level(const std::string& logger, uhd::log::severity_level level);
192}} // namespace uhd::log
193
196#define _UHD_LOG_INTERNAL(component, level) \
197 uhd::_log::log(level, __FILE__, __LINE__, component, std::this_thread::get_id())
199
200// macro-style logging (compile-time determined)
201#if UHD_LOG_MIN_LEVEL < 1
202# define UHD_LOG_TRACE(component, message) \
203 _UHD_LOG_INTERNAL(component, uhd::log::trace) << message;
204#else
205# define UHD_LOG_TRACE(component, message)
206#endif
207
208#if UHD_LOG_MIN_LEVEL < 2
209# define UHD_LOG_DEBUG(component, message) \
210 _UHD_LOG_INTERNAL(component, uhd::log::debug) << message;
211#else
212# define UHD_LOG_DEBUG(component, message)
213#endif
214
215#if UHD_LOG_MIN_LEVEL < 3
216# define UHD_LOG_INFO(component, message) \
217 _UHD_LOG_INTERNAL(component, uhd::log::info) << message;
218#else
219# define UHD_LOG_INFO(component, message)
220#endif
221
222#if UHD_LOG_MIN_LEVEL < 4
223# define UHD_LOG_WARNING(component, message) \
224 _UHD_LOG_INTERNAL(component, uhd::log::warning) << message;
225#else
226# define UHD_LOG_WARNING(component, message)
227#endif
228
229#if UHD_LOG_MIN_LEVEL < 5
230# define UHD_LOG_ERROR(component, message) \
231 _UHD_LOG_INTERNAL(component, uhd::log::error) << message;
232#else
233# define UHD_LOG_ERROR(component, message)
234#endif
235
236#if UHD_LOG_MIN_LEVEL < 6
237# define UHD_LOG_FATAL(component, message) \
238 _UHD_LOG_INTERNAL(component, uhd::log::fatal) << message;
239#else
240# define UHD_LOG_FATAL(component, message)
241#endif
242
243#define RFNOC_LOG_TRACE(message) UHD_LOG_TRACE(this->get_unique_id(), message)
244#define RFNOC_LOG_DEBUG(message) UHD_LOG_DEBUG(this->get_unique_id(), message)
245#define RFNOC_LOG_INFO(message) UHD_LOG_INFO(this->get_unique_id(), message)
246#define RFNOC_LOG_WARNING(message) UHD_LOG_WARNING(this->get_unique_id(), message)
247#define RFNOC_LOG_ERROR(message) UHD_LOG_ERROR(this->get_unique_id(), message)
248#define RFNOC_LOG_FATAL(message) UHD_LOG_FATAL(this->get_unique_id(), message)
249
250#ifndef UHD_LOG_FASTPATH_DISABLE
252// No metadata is tracked. Only the message is displayed. This does not go
253// through the regular backends. Mostly used for printing the UOSDL characters
254// during streaming.
255# define UHD_LOG_FASTPATH(message) uhd::_log::log_fastpath(message);
256#else
257# define UHD_LOG_FASTPATH(message)
258#endif
259
260// iostream-style logging
261#define UHD_LOGGER_TRACE(component) _UHD_LOG_INTERNAL(component, uhd::log::trace)
262#define UHD_LOGGER_DEBUG(component) _UHD_LOG_INTERNAL(component, uhd::log::debug)
263#define UHD_LOGGER_INFO(component) _UHD_LOG_INTERNAL(component, uhd::log::info)
264#define UHD_LOGGER_WARNING(component) _UHD_LOG_INTERNAL(component, uhd::log::warning)
265#define UHD_LOGGER_ERROR(component) _UHD_LOG_INTERNAL(component, uhd::log::error)
266#define UHD_LOGGER_FATAL(component) _UHD_LOG_INTERNAL(component, uhd::log::fatal)
267
268
269#if defined(__GNUG__)
271# define UHD_HERE() \
272 UHD_LOGGER_DEBUG("DEBUG") \
273 << __FILE__ << ":" << __LINE__ << " (" << UHD_PRETTY_FUNCTION << ")";
274#else
276# define UHD_HERE() UHD_LOGGER_DEBUG("DEBUG") << __FILE__ << ":" << __LINE__;
277#endif
278
280#define UHD_VAR(var) UHD_LOGGER_DEBUG("DEBUG") << #var << " = " << var;
281
283#define UHD_HEX(var) \
284 UHD_LOGGER_DEBUG("DEBUG") << #var << " = 0x" << std::hex << std::setfill('0') \
285 << std::setw(8) << var << std::dec;
286
288namespace uhd {
289namespace _log {
290
292void UHD_API log_fastpath(const std::string&);
293
295class UHD_API log
296{
297public:
298 log(const uhd::log::severity_level verbosity,
299 const std::string& file,
300 const unsigned int line,
301 const std::string& component,
302 const std::thread::id thread_id);
303
304 ~log(void);
305
306// Macro for overloading insertion operators to avoid costly
307// conversion of types if not logging.
308#define INSERTION_OVERLOAD(x) \
309 log& operator<<(x) \
310 { \
311 if (_log_it) { \
312 _ss << val; \
313 } \
314 return *this; \
315 }
316
317 // General insertion overload
318 template <typename T>
319 INSERTION_OVERLOAD(T val)
320
321 // Insertion overloads for std::ostream manipulators
322 INSERTION_OVERLOAD(std::ostream& (*val)(std::ostream&))
323 INSERTION_OVERLOAD(std::ios& (*val)(std::ios&))
324 INSERTION_OVERLOAD(std::ios_base& (*val)(std::ios_base&))
325
326 private : uhd::log::logging_info _log_info;
327 std::ostringstream _ss;
328 const bool _log_it;
329};
330
331} // namespace _log
333} /* namespace uhd */
Definition: config.h:87
UHD_API void set_logger_level(const std::string &logger, uhd::log::severity_level level)
UHD_API void set_console_level(uhd::log::severity_level level)
UHD_API void set_log_level(uhd::log::severity_level level)
boost::optional< uhd::log::severity_level > UHD_API parse_log_level_from_string(const std::string &log_level_str)
UHD_API void set_file_level(uhd::log::severity_level level)
severity_level
Definition: log.hpp:116
@ warning
Definition: log.hpp:120
@ fatal
Definition: log.hpp:122
@ error
Definition: log.hpp:121
@ trace
Definition: log.hpp:117
@ off
Definition: log.hpp:123
@ info
Definition: log.hpp:119
@ debug
Definition: log.hpp:118
Definition: build_info.hpp:12
Definition: log.hpp:138
std::string file
Definition: log.hpp:157
Definition: log.hpp:160
logging_info(const boost::posix_time::ptime &time_, const uhd::log::severity_level &verbosity_, const std::string &file_, const unsigned int &line_, const std::string &component_, const std::thread::id &thread_id_)
Definition: log.hpp:140
logging_info()
Definition: log.hpp:139
Definition: log.hpp:159
Definition: log.hpp:155
unsigned int line
Definition: log.hpp:158
Definition: log.hpp:156
std::string message
Definition: log.hpp:161
