noc_block_base.hpp
1//
2// Copyright 2019 Ettus Research, a National Instruments Brand
3//
4// SPDX-License-Identifier: GPL-3.0-or-later
5//
6
7#pragma once
8
9#include <uhd/config.hpp>
10#include <uhd/property_tree.hpp>
13#include <uhd/rfnoc/node.hpp>
19#define RFNOC_BLOCK_CONSTRUCTOR(CLASS_NAME) \
20 CLASS_NAME##_impl(make_args_ptr make_args) : CLASS_NAME(std::move(make_args))
21
22#define RFNOC_DECLARE_BLOCK(CLASS_NAME) \
23 using sptr = std::shared_ptr<CLASS_NAME>; \
24 CLASS_NAME(make_args_ptr make_args) : noc_block_base(std::move(make_args)) {}
25
26namespace uhd { namespace rfnoc {
27
28class clock_iface;
29class mb_controller;
30
43{
44public:
48 using sptr = std::shared_ptr<noc_block_base>;
49
51 struct make_args_t;
52
54 using make_args_ptr = std::unique_ptr<make_args_t>;
55
56 ~noc_block_base() override;
57
58 /**************************************************************************
59 * node_t API calls
60 *************************************************************************/
62 std::string get_unique_id() const override
63 {
64 return get_block_id().to_string();
65 }
66
68 // information stored in the global register space.
69 //
70 // Note: This may be overridden by the block (e.g., the X300 radio may not
71 // have all ports available if no TwinRX board is plugged in), but the
72 // subclassed version may never report more ports than this.
73 size_t get_num_input_ports() const override
74 {
75 return _num_input_ports;
76 }
77
79 // information stored in the global register space.
80 //
81 // Note: This may be overridden by the block (e.g., the X300 radio may not
82 // have all ports available if no TwinRX board is plugged in), but the
83 // subclassed version may never report more ports than this.
84 size_t get_num_output_ports() const override
85 {
86 return _num_output_ports;
87 }
88
89 /**************************************************************************
90 * RFNoC-block specific API calls
91 *************************************************************************/
97 {
98 return _noc_id;
99 }
100
106 {
107 return _block_id;
108 }
109
114 double get_tick_rate() const;
115
132 size_t get_mtu(const res_source_info& edge);
133
147 size_t get_chdr_hdr_len(const bool account_for_ts = true) const;
148
177 const res_source_info& edge, const bool account_for_ts = true);
178
182 {
183 return _block_args;
184 }
185
188 {
189 return _tree;
190 }
191
194 {
195 return _tree;
196 }
197
209 std::shared_ptr<mb_controller> get_mb_controller();
210
211protected:
213
215 //
216 // - The new number of ports may not exceed the old number. This can only
217 // be used to 'decrease' the number of ports.
218 // - This is considered an 'advanced' API and should rarely be called by
219 // blocks. See also get_num_output_ports().
220 //
221 // \throws uhd::value_error if \p num_ports is larger than the current
222 // number of ports.
223 void set_num_input_ports(const size_t num_ports);
224
226 //
227 // - The new number of ports may not exceed the old number. This can only
228 // be used to 'decrease' the number of ports.
229 // - This is considered an 'advanced' API and should rarely be called by
230 // blocks. An example of where this is useful is the X310 radio block,
231 // which has 2 output ports, but only 1 is useful for UBX/SBX/WBX boards
232 // (i.e., boards with 1 frontend). In that case, software can make a
233 // determination to 'invalidate' one of the ports.
234 //
235 // \throws uhd::value_error if \p num_ports is larger than the current
236 // number of ports.
237 void set_num_output_ports(const size_t num_ports);
238
244 void set_tick_rate(const double tick_rate);
245
275
281 void set_mtu(const res_source_info& edge, const size_t new_mtu);
282
293
311 virtual void deinit();
312
313private:
314 friend struct block_initializer;
315
321 void _set_tick_rate(const double tick_rate);
322
328 void shutdown() override;
329
337 void post_init();
338
339 /**************************************************************************
340 * Attributes
341 **************************************************************************/
343 noc_id_t _noc_id;
344
346 //
347 // The framework will guarantee that no one else has the same block ID
348 block_id_t _block_id;
349
351 size_t _num_input_ports;
352
354 size_t _num_output_ports;
355
357 // for all in- and output edges.
358 std::vector<property_t<double>> _tick_rate_props;
359
361 forwarding_policy_t _mtu_fwd_policy = forwarding_policy_t::ONE_TO_ONE;
362
364 bool _mtu_fwd_policy_set = false;
365
367 // for all in- and output edges.
368 std::vector<property_t<size_t>> _mtu_props;
369
371 std::unordered_map<res_source_info, size_t> _mtu;
372
374 chdr_w_t _chdr_w;
375
377 std::shared_ptr<clock_iface> _ctrlport_clock_iface;
378
380 std::shared_ptr<clock_iface> _tb_clock_iface;
381
383 // block had requested and was granted access
384 std::shared_ptr<mb_controller> _mb_controller;
385
387 const uhd::device_addr_t _block_args;
388
390 //
391 // It is mutable because _tree->access<>(..).get() is not const, but we
392 // need to do just that in some const contexts
393 mutable uhd::property_tree::sptr _tree;
394
395}; // class noc_block_base
396
397}} /* namespace uhd::rfnoc */
398
Definition: property_tree.hpp:222
Definition: block_id.hpp:40
Definition: noc_block_base.hpp:43
uhd::device_addr_t get_block_args() const
Definition: noc_block_base.hpp:181
std::unique_ptr< make_args_t > make_args_ptr
Opaque pointer to the constructor arguments.
Definition: noc_block_base.hpp:54
void set_mtu_forwarding_policy(const forwarding_policy_t policy)
Number of output ports. Note: This gets passed outto this block from the.
Definition: noc_block_base.hpp:84
size_t get_mtu(const res_source_info &edge)
void set_mtu(const res_source_info &edge, const size_t new_mtu)
size_t get_max_payload_size(const res_source_info &edge, const bool account_for_ts=true)
Update number of input ports.
Number of input ports. Note: This gets passed into this block from the.
Definition: noc_block_base.hpp:73
Unique ID for an RFNoC block is its block ID.
Definition: noc_block_base.hpp:62
noc_block_base(make_args_ptr make_args)
uhd::property_tree::sptr & get_tree() const
Return a reference to this block's subtree.
Definition: noc_block_base.hpp:187
size_t get_chdr_hdr_len(const bool account_for_ts=true) const
Return a reference to this block's subtree (non-const version)
Definition: noc_block_base.hpp:193
noc_id_t get_noc_id() const
Definition: noc_block_base.hpp:96
std::shared_ptr< mb_controller > get_mb_controller()
Definition: noc_block_base.hpp:48
const block_id_t & get_block_id() const
Definition: noc_block_base.hpp:105
property_base_t * get_mtu_prop_ref(const res_source_info &edge)
Update number of output ports.
Definition: node.hpp:35
forwarding_policy_t
Types of property/action forwarding for those not defined by the block itself.
Definition: node.hpp:45
Definition: property.hpp:26
Definition: register_iface_holder.hpp:19
Definition: config.h:87
uint32_t noc_id_t
Definition: defaults.hpp:49
chdr_w_t
Type that indicates the CHDR Width in bits.
Definition: rfnoc_types.hpp:19
Definition: build_info.hpp:12
Definition: noc_block_make_args.hpp:25
Definition: res_source_info.hpp:18
