node.hpp
1//
2// Copyright 2019 Ettus Research, a National Instruments Brand
3//
4// SPDX-License-Identifier: GPL-3.0-or-later
5//
6
7#pragma once
8
14#include <uhd/utils/log.hpp>
16#include <unordered_map>
17#include <unordered_set>
18#include <boost/graph/adjacency_list.hpp>
19#include <functional>
20#include <memory>
21#include <mutex>
22#include <string>
23#include <tuple>
24#include <vector>
25
26namespace uhd { namespace rfnoc {
27
35{
36public:
37 using resolver_fn_t = std::function<void(void)>;
38 using resolve_callback_t = std::function<void(void)>;
40 std::function<void(const res_source_info&, action_info::sptr)>;
42 std::unordered_map<res_source_info, std::vector<res_source_info>>;
43
47 //(e.g., if it comes from input port 0, forward it to output port 0).
48 ONE_TO_ONE,
50 ONE_TO_FAN,
52 ONE_TO_ALL_IN,
54 ONE_TO_ALL_OUT,
56 ONE_TO_ALL,
58 DROP,
60 USE_MAP
61 };
62
63 static const size_t ANY_PORT = size_t(~0);
64
65 /**************************************************************************
66 * Structors
67 *************************************************************************/
69
70 virtual ~node_t() {}
71
72 /******************************************
73 * Basic Operations
74 ******************************************/
76 // no two nodes cannot have the same ID.
77 //
78 // \returns The unique ID as a string
79 virtual std::string get_unique_id() const;
80
87 virtual size_t get_num_input_ports() const = 0;
88
95 virtual size_t get_num_output_ports() const = 0;
96
97 /******************************************
98 * Property Specific
99 ******************************************/
100
109 std::vector<std::string> get_property_ids() const;
110
126 template <typename prop_data_t>
127 void set_property(
128 const std::string& id, const prop_data_t& val, const size_t instance = 0);
129
162 void set_properties(const uhd::device_addr_t& props, const size_t instance = 0);
163
181 template <typename prop_data_t>
182 const prop_data_t& get_property(
183 const std::string& id, const size_t instance = 0) /* mutable */;
184
200 virtual void set_command_time(uhd::time_spec_t time, const size_t instance);
201
206 virtual uhd::time_spec_t get_command_time(const size_t instance) const;
207
213 virtual void clear_command_time(const size_t instance);
214
215protected:
216 /******************************************
217 * Internal Registration Functions
218 ******************************************/
219 using prop_ptrs_t = std::unordered_set<property_base_t*>;
220
242 property_base_t* prop, resolve_callback_t&& clean_callback = nullptr);
243
279 prop_ptrs_t&& inputs, prop_ptrs_t&& outputs, resolver_fn_t&& resolver_fn);
280
281 /**************************************************************************
282 * Property forwarding
283 *************************************************************************/
305 forwarding_policy_t policy, const std::string& prop_id = "");
306
329
341 template <typename prop_data_t>
342 void set_property(
343 const std::string& id, const prop_data_t& val, const res_source_info& src_info);
344
356 template <typename prop_data_t>
357 const prop_data_t& get_property(
358 const std::string& id, const res_source_info& src_info) /* mutable */;
359
360 /******************************************
361 * Internal action forwarding
362 ******************************************/
376 void register_action_handler(const std::string& id, action_handler_t&& handler);
377
397 forwarding_policy_t policy, const std::string& action_key = "");
398
422
434 void post_action(const res_source_info& edge_info, action_info::sptr action);
435
436 /**************************************************************************
437 * Graph Interaction
438 *************************************************************************/
459 virtual bool check_topology(const std::vector<size_t>& connected_inputs,
460 const std::vector<size_t>& connected_outputs);
461
467 virtual void shutdown();
468
469 /**************************************************************************
470 * Attributes
471 *************************************************************************/
474
475private:
476 friend class node_accessor_t;
477
482 property_base_t* _find_property(
483 res_source_info src_info, const std::string& id) const;
484
490 uhd::utils::scope_exit::uptr _request_property_access(
491 property_base_t* prop, property_base_t::access_t access) const;
492
497 template <typename PredicateType>
498 prop_ptrs_t filter_props(PredicateType&& predicate)
499 {
500 prop_ptrs_t filtered_props{};
501 for (const auto& type_prop_pair : _props) {
502 for (const auto& prop : type_prop_pair.second) {
503 if (predicate(prop)) {
504 filtered_props.insert(prop);
505 }
506 }
507 }
508
509 return filtered_props;
510 }
511
519 property_base_t* inject_edge_property(
520 property_base_t* blueprint, res_source_info new_src_info);
521
535 void init_props();
536
560 void resolve_props();
561
564 void resolve_all();
565
571 void clean_props();
572
576 void set_resolve_all_callback(resolve_callback_t&& resolver)
577 {
578 _resolve_all_cb = resolver;
579 }
580
583 void clear_resolve_all_callback()
584 {
585 _resolve_all_cb = _default_resolve_all_cb;
586 }
587
622 void forward_edge_property(
623 property_base_t* incoming_prop, const size_t incoming_port);
624
625 /**************************************************************************
626 * Action-Related Methods
627 *************************************************************************/
631 void set_post_action_callback(action_handler_t&& post_handler)
632 {
633 _post_action_cb = std::move(post_handler);
634 }
635
644 void receive_action(const res_source_info& src_info, action_info::sptr action);
645
646 /**************************************************************************
647 * Private helpers
648 *************************************************************************/
650 bool _has_port(const res_source_info& port_info) const;
651
652 /****** Attributes *******************************************************/
654 // global property mutex, this only write-protects access to the property-
655 // related containers in this class.
656 mutable std::mutex _prop_mutex;
657
659 std::unordered_map<res_source_info::source_t,
660 std::vector<property_base_t*>,
661 std::hash<size_t>>
662 _props;
663
665 std::unordered_map<property_base_t*, resolve_callback_t> _clean_cb_registry;
666
667 using property_resolver_t = std::tuple<prop_ptrs_t, prop_ptrs_t, resolver_fn_t>;
669 std::vector<property_resolver_t> _prop_resolvers;
670
672 // has changed, and that a property resolution needs to be performed.
673 resolve_callback_t _resolve_all_cb;
674
676 // method.
677 const resolve_callback_t _default_resolve_all_cb = [this]() {
678 resolve_props();
679 clean_props();
680 };
681
683 // explicitly.
684 //
685 // Dynamic properties include properties defined in the block descriptor
686 // file, as well as new properties that get passed in during property
687 // propagation.
688 std::unordered_set<std::unique_ptr<property_base_t>> _dynamic_props;
689
691 //
692 // The entry with the empty-string-key is the default policy.
693 std::unordered_map<std::string, forwarding_policy_t> _prop_fwd_policies{
694 {"", forwarding_policy_t::ONE_TO_ONE}};
695
697 forwarding_map_t _prop_fwd_map;
698
699 /**************************************************************************
700 * Action-related attributes
701 *************************************************************************/
702 mutable std::mutex _action_mutex;
703
705 std::unordered_map<std::string, action_handler_t> _action_handlers;
706
708 std::unordered_map<std::string, forwarding_policy_t> _action_fwd_policies{
709 {"", forwarding_policy_t::ONE_TO_ONE}};
710
712 //
713 // The default callback will simply drop actions
714 action_handler_t _post_action_cb = [](const res_source_info&,
715 action_info::sptr) { /* nop */ };
716
718 forwarding_map_t _action_fwd_map;
719
720 /**************************************************************************
721 * Other attributes
722 *************************************************************************/
723 std::vector<uhd::time_spec_t> _cmd_timespecs;
724}; // class node_t
725
726}} /* namespace uhd::rfnoc */
727
728#include <uhd/rfnoc/node.ipp>
Definition: dirtifier.hpp:19
Definition: node.hpp:35
Return a unique identifier string for this node. In every RFNoC graph,.
std::vector< std::string > get_property_ids() const
void register_property(property_base_t *prop, resolve_callback_t &&clean_callback=nullptr)
std::unordered_map< res_source_info, std::vector< res_source_info > > forwarding_map_t
Definition: node.hpp:42
void set_action_forwarding_policy(forwarding_policy_t policy, const std::string &action_key="")
void set_prop_forwarding_map(const forwarding_map_t &map)
std::function< void(void)> resolver_fn_t
Definition: node.hpp:37
std::function< void(void)> resolve_callback_t
Definition: node.hpp:38
void register_action_handler(const std::string &id, action_handler_t &&handler)
void post_action(const res_source_info &edge_info, action_info::sptr action)
virtual bool check_topology(const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs)
virtual ~node_t()
Definition: node.hpp:70
void set_action_forwarding_map(const forwarding_map_t &map)
virtual size_t get_num_output_ports() const =0
std::unordered_set< property_base_t * > prop_ptrs_t
Definition: node.hpp:219
void set_properties(const uhd::device_addr_t &props, const size_t instance=0)
forwarding_policy_t
Types of property/action forwarding for those not defined by the block itself.
Definition: node.hpp:45
virtual size_t get_num_input_ports() const =0
void add_property_resolver(prop_ptrs_t &&inputs, prop_ptrs_t &&outputs, resolver_fn_t &&resolver_fn)
std::function< void(const res_source_info &, action_info::sptr)> action_handler_t
Definition: node.hpp:40
static dirtifier_t ALWAYS_DIRTY
A dirtifyer object, useful for properties that always need updating.
Definition: node.hpp:473
void set_prop_forwarding_policy(forwarding_policy_t policy, const std::string &prop_id="")
Definition: property.hpp:26
access_t
Definition: property.hpp:28
Definition: time_spec.hpp:31
std::unique_ptr< scope_exit > uptr
Definition: scope_exit.hpp:25
Definition: config.h:87
Definition: build_info.hpp:12
std::shared_ptr< action_info > sptr
Definition: actions.hpp:32
Definition: res_source_info.hpp:18
source_t
Definition: res_source_info.hpp:21
