12namespace uhd {
namespace rfnoc {
  116    static const uint16_t MINOR_COMPAT;
  117    static const uint16_t MAJOR_COMPAT;
  119    static const uint32_t REPLAY_ADDR_W;
  120    static const uint32_t REPLAY_BLOCK_OFFSET;
  122    static const uint32_t REG_COMPAT_ADDR;
  123    static const uint32_t REG_MEM_SIZE_ADDR;
  124    static const uint32_t REG_REC_RESTART_ADDR;
  125    static const uint32_t REG_REC_BASE_ADDR_LO_ADDR;
  126    static const uint32_t REG_REC_BASE_ADDR_HI_ADDR;
  127    static const uint32_t REG_REC_BUFFER_SIZE_LO_ADDR;
  128    static const uint32_t REG_REC_BUFFER_SIZE_HI_ADDR;
  129    static const uint32_t REG_REC_FULLNESS_LO_ADDR;
  130    static const uint32_t REG_REC_FULLNESS_HI_ADDR;
  131    static const uint32_t REG_PLAY_BASE_ADDR_LO_ADDR;
  132    static const uint32_t REG_PLAY_BASE_ADDR_HI_ADDR;
  133    static const uint32_t REG_PLAY_BUFFER_SIZE_LO_ADDR;
  134    static const uint32_t REG_PLAY_BUFFER_SIZE_HI_ADDR;
  135    static const uint32_t REG_PLAY_CMD_NUM_WORDS_LO_ADDR;
  136    static const uint32_t REG_PLAY_CMD_NUM_WORDS_HI_ADDR;
  137    static const uint32_t REG_PLAY_CMD_TIME_LO_ADDR;
  138    static const uint32_t REG_PLAY_CMD_TIME_HI_ADDR;
  139    static const uint32_t REG_PLAY_CMD_ADDR;
  140    static const uint32_t REG_PLAY_WORDS_PER_PKT_ADDR;
  141    static const uint32_t REG_PLAY_ITEM_SIZE_ADDR;
  142    static const uint32_t REG_REC_POS_LO_ADDR;
  143    static const uint32_t REG_REC_POS_HI_ADDR;
  144    static const uint32_t REG_PLAY_POS_LO_ADDR;
  145    static const uint32_t REG_PLAY_POS_HI_ADDR;
  146    static const uint32_t REG_PLAY_CMD_FIFO_SPACE_ADDR;
  148    static const uint32_t PLAY_CMD_STOP;
  149    static const uint32_t PLAY_CMD_FINITE;
  150    static const uint32_t PLAY_CMD_CONTINUOUS;
  172        const uint64_t offset, const uint64_t size, const
size_t port = 0) = 0;
  180    virtual
void record_restart(const
  222    virtual
void play(const uint64_t offset,
  224        const
size_t port                = 0,
  226        const
bool repeat                = false) = 0;
  235    virtual
void stop(const
  244    virtual uint64_t get_mem_size() const = 0;
  250    virtual uint64_t get_word_size() const = 0;
  260    virtual uint64_t get_record_offset(const
size_t port = 0) const = 0;
  267    virtual uint64_t get_record_size(const
  277    virtual uint64_t get_record_fullness(const
  284    virtual uint64_t get_record_position(const
  291    virtual
io_type_t get_record_type(const
  298    virtual
size_t get_record_item_size(const
  313    virtual
bool get_record_async_metadata(
  324    virtual uint64_t get_play_offset(const
  331    virtual uint64_t get_play_size(const
  338    virtual uint64_t get_play_position(const
  345    virtual uint32_t get_max_items_per_packet(const
  354    virtual uint32_t get_max_packet_size(const
  361    virtual
io_type_t get_play_type(const
  368    virtual
size_t get_play_item_size(const
  383    virtual
bool get_play_async_metadata(
  396    virtual
void set_record_type(const
io_type_t type, const
  415    virtual
void config_play(
  416        const uint64_t offset, const uint64_t size, const
  425    virtual
void set_play_type(const
  436    virtual
void set_max_items_per_packet(const uint32_t ipp, const
  446    virtual
void set_max_packet_size(const uint32_t size, const
  464    virtual
void issue_stream_cmd(
Definition: noc_block_base.hpp:43
Definition: replay_block_control.hpp:112
Definition: time_spec.hpp:31
Definition: config.h:87
std::string io_type_t
Definition: defaults.hpp:30
Definition: build_info.hpp:12
#define RFNOC_DECLARE_BLOCK(CLASS_NAME)
Definition: noc_block_base.hpp:22
Definition: stream_cmd.hpp:40
