38    typedef std::shared_ptr<i2c_iface>
sptr;
   88    enum edge_t { EDGE_RISE =
'r', EDGE_FALL =
'f' };
  124    typedef std::shared_ptr<spi_iface>
sptr;
  152        int which_slave,
const spi_config_t& config, uint32_t data,
size_t num_bits);
  162        int which_slave,
size_t num_bits);
  171    typedef std::shared_ptr<uart_iface>
sptr;
Definition: serial.hpp:36
virtual byte_vector_t read_i2c(uint16_t addr, size_t num_bytes)=0
virtual byte_vector_t read_eeprom(uint16_t addr, uint16_t offset, size_t num_bytes)
virtual void write_i2c(uint16_t addr, const byte_vector_t &buf)=0
i2c_iface::sptr eeprom16(void)
Create an i2c_iface than can talk to 16 bit addressable EEPROMS.
std::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:38
virtual void write_eeprom(uint16_t addr, uint16_t offset, const byte_vector_t &buf)
Definition: serial.hpp:122
std::shared_ptr< spi_iface > sptr
Definition: serial.hpp:124
virtual uint32_t transact_spi(int which_slave, const spi_config_t &config, uint32_t data, size_t num_bits, bool readback)=0
virtual uint32_t read_spi(int which_slave, const spi_config_t &config, uint32_t data, size_t num_bits)
virtual void write_spi(int which_slave, const spi_config_t &config, uint32_t data, size_t num_bits)
Definition: serial.hpp:169
virtual void write_uart(const std::string &buf)=0
virtual ~uart_iface(void)
virtual std::string read_uart(double timeout)=0
std::shared_ptr< uart_iface > sptr
Definition: serial.hpp:171
Definition: config.h:87
Definition: build_info.hpp:12
Definition: byte_vector.hpp:19
Definition: serial.hpp:83
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:94
spi_config_t(edge_t edge=EDGE_RISE)
edge_t
Definition: serial.hpp:88
bool use_custom_divider
Set the clock speed for this transaction.
Definition: serial.hpp:97
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:91
spi_config_t(edge_t edge, size_t divider)
size_t divider
Optionally set the SPI clock divider for this transaction.
Definition: serial.hpp:100
