blockdef.hpp
2 // Copyright 2014-2015 Ettus Research LLC
4 //
6 //
7
8 #pragma once
9
10 #include <uhd/config.hpp>
12 #include <stdint.h>
13 #include <memory>
14 #include <set>
15 #include <vector>
16
17 namespace uhd { namespace rfnoc {
18
21 class UHD_API blockdef : public std::enable_shared_from_this<blockdef>
22 {
23 public:
24  typedef std::shared_ptr<blockdef> sptr;
25
27  //
28  // This is not the same as a uhd::rfnoc::stream_sig_t. This is used
29  // to describe which ports are defined in a block definition, and
30  // to describe what kind of connection is allowed for this port.
31  //
32  // All the keys listed in PORT_ARGS will be available in this class.
33  class port_t : public uhd::dict<std::string, std::string>
34  {
35  public:
37  static const device_addr_t PORT_ARGS;
38
39  port_t();
40
42  bool is_variable(const std::string& key) const;
44  bool is_keyword(const std::string& key) const;
46  // keywords are not resolved.
47  bool is_valid() const;
49  std::string to_string() const;
50  };
51  typedef std::vector<port_t> ports_t;
52
54  class arg_t : public uhd::dict<std::string, std::string>
55  {
56  public:
58  static const device_addr_t ARG_ARGS;
59  static const std::set<std::string> VALID_TYPES;
60
61  arg_t();
62
64  bool is_valid() const;
66  std::string to_string() const;
67  };
68  typedef std::vector<arg_t> args_t;
69
71
78  static sptr make_from_noc_id(uint64_t noc_id);
79
81  virtual bool is_block() const = 0;
82
84  virtual bool is_component() const = 0;
85
87  virtual std::string get_key() const = 0;
88
90  virtual std::string get_name() const = 0;
91
93  virtual uint64_t noc_id() const = 0;
94
95  virtual ports_t get_input_ports() = 0;
96  virtual ports_t get_output_ports() = 0;
97
99  virtual std::vector<size_t> get_all_port_numbers() = 0;
100
102  //
103  // \throws uhd::runtime_error if args are invalid.
104  virtual args_t get_args() = 0;
105
107  virtual registers_t get_settings_registers() = 0;
108
110  virtual registers_t get_readback_registers() = 0;
111 };
112
113 }} /* namespace uhd::rfnoc */
uhd::rfnoc::blockdef::sptr
std::shared_ptr< blockdef > sptr
Definition: blockdef.hpp:24
uhd::rfnoc::blockdef::args_t
std::vector< arg_t > args_t
Definition: blockdef.hpp:68
device_addr.hpp
config.hpp
uhd::rfnoc::blockdef::arg_t::VALID_TYPES
static const std::set< std::string > VALID_TYPES
Definition: blockdef.hpp:59
Describes arguments in a block definition.
Definition: blockdef.hpp:54
uhd::rfnoc::blockdef::registers_t
uhd::dict< std::string, size_t > registers_t
Definition: blockdef.hpp:70
uhd::rfnoc::blockdef::port_t::PORT_ARGS
A list of args a port can have.
Definition: blockdef.hpp:37
UHD_API
Definition: config.h:87
Describes port options for a block definition.
Definition: blockdef.hpp:33
uhd::device_addr_t
Definition: device_addr.hpp:37
uhd
Definition: build_info.hpp:12
uhd::dict
Definition: dict.hpp:21
Definition: blockdef.hpp:21
uhd::rfnoc::blockdef::arg_t::ARG_ARGS
A list of args an argument can have.
Definition: blockdef.hpp:58
uhd::rfnoc::blockdef::ports_t
std::vector< port_t > ports_t
Definition: blockdef.hpp:51
