uhd::rfnoc::vector_iir_block_control Member List
This is the complete list of members for uhd::rfnoc::vector_iir_block_control, including all inherited members.
get_alpha(const size_t chan) const =0uhd::rfnoc::vector_iir_block_controlpure virtual
get_beta(const size_t chan) const =0uhd::rfnoc::vector_iir_block_controlpure virtual
get_delay(const size_t chan) const =0uhd::rfnoc::vector_iir_block_controlpure virtual
get_max_delay(const size_t chan) const =0uhd::rfnoc::vector_iir_block_controlpure virtual
node_t()uhd::rfnoc::node_t
REG_ALPHA_OFFSETuhd::rfnoc::vector_iir_block_controlstatic
REG_BETA_OFFSETuhd::rfnoc::vector_iir_block_controlstatic
REG_BLOCK_SIZEuhd::rfnoc::vector_iir_block_controlstatic
REG_DELAY_OFFSETuhd::rfnoc::vector_iir_block_controlstatic
set_alpha(const double alpha, const size_t chan)=0uhd::rfnoc::vector_iir_block_controlpure virtual
set_beta(const double beta, const size_t chan)=0uhd::rfnoc::vector_iir_block_controlpure virtual
set_delay(const uint16_t delay, const size_t chan)=0uhd::rfnoc::vector_iir_block_controlpure virtual
